UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Went 100% debt free today
by BeerCan. 04/25/19 10:04 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
116 registered members (240_Ed, AirBull, Andygold, ad_infinitum, Amenhotep, 01rangerxl, 11 invisible), 2,164 guests, and 20 spiders.
Topics288,045
Posts4,939,805
Members67,902
Most Online2,967
Mar 10th, 2019
What's Your Opinion on Transmission Line Boosters? #4597493
12/07/17 09:15 PM
12/07/17 09:15 PM
North Dakota
mphilleo Offline OP
mphilleo  Offline OP
North Dakota
Like the title says, what do you think? Do they extend the life of good transmissions and condemn ailing ones? I'm debating getting one for my 545RFE.
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4597501
12/07/17 09:28 PM
12/07/17 09:28 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Never heard of them. Headin to google now
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4597503
12/07/17 09:32 PM
12/07/17 09:32 PM
Chris142 Offline
Chris142  Offline
Ok. Google helped. The trans cooler is not a high pressure line. The higher pressures are in the trans and valve body. I do not see how restricting the flow to the cooler would make a trans last longer.
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4597515
12/07/17 09:41 PM
12/07/17 09:41 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Depends on many factors.....Health of the unit, Health of the pump, Is the cooling system up to the task? More pressure equals more heat!
I don't build many 545RFE's but I've built quite a few of it's big sister...The 68RFE, I use the Sonnax line booster kits on every one!
2001 Chevy Camaro L92/4L80E
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4597516
12/07/17 09:46 PM
12/07/17 09:46 PM
South Carolina
eyeofthetiger Offline
South Carolina
I do not understand what these boosters do.
I think the money is better spent on a large transmission cooler.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4597538
12/07/17 10:03 PM
12/07/17 10:03 PM
North Dakota
mphilleo Offline OP
mphilleo  Offline OP
North Dakota
They're supposed to increase the transmission line pressure, resulting in faster, crisper shifts without a tuner (and the RFEs would defeat a tune). Theoretically, this results in reduced clutch wear if yours aren't slipping already. That's when they're not do good.
See, I have a 2008 Commander with the 545RFE and towing package, so what isn't an issue for me since I mostly DD it. I do have an occasional annoying firm or hanging (not slipping) shift I'm hoping to improve. I'll probably do a filter change and series of drains and fills first though. I was trying to see what others thought first, though.
Re: What's Your Opinion on Transmission Line Boosters? [Re: clinebarger] #4597605
12/07/17 11:05 PM
12/07/17 11:05 PM
BC Canada
Farmer Offline
Farmer  Offline
BC Canada
I've used that line booster before. It does absolutely nothing for line pressure. It's a waste of money unfortunately. Line pressure is still at 160. However with a properly built 68RFE you can go to 225-250.
Re: What's Your Opinion on Transmission Line Boosters? [Re: clinebarger] #4597731
12/08/17 05:51 AM
12/08/17 05:51 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
This statement ends the whole thread without the line boosters in the equation. "How long will my transmission last?"
That said, if something is on it's last leg, I don't think much can be done at this point..
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: What's Your Opinion on Transmission Line Boosters? [Re: Farmer] #4598441
12/08/17 08:02 PM
12/08/17 08:02 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
My mechanical pressure gauge disagrees with you......LOL
If you are trying to read the line boost via a scan tool, It will read the same as stock.
The Sonnax line booster is placed between the TCM & Pressure Transducer, The TCM will now see a lower pressure vs commanded PCS duty cycle. The TCM will now command increased PCS duty cycle to compensate for the false readings.
Of coarse this will not produce 250 psi of max forward line pressure that a 68RFE behind a 900# torque modified Cummins will require, Nor was it ever meant to. But it WILL produce the 20-25 psi increase.
Re: What's Your Opinion on Transmission Line Boosters? [Re: clinebarger] #4598528
12/08/17 09:19 PM
12/08/17 09:19 PM
Malaysia
zeng Offline
zeng  Offline
Malaysia
I tend to concur with Farmer that this line pressure booster is a waste of money.
Agreeing that a line pressure booster does provide increased line pressure (depending on the spring rate in use), however this increased line pressure does nothing (borrowing a word from Farmer) to the varying actuating pressures of the respective clutch pistons (of various speed) as these clutch actuating pressures are generally very far lower than that of factory set line pressure.
Transmission supply line pressures are not actuating pressures of combinations of various clutch housings/pistons of various (gear) speeds.
Re: What's Your Opinion on Transmission Line Boosters? [Re: zeng] #4599334
12/09/17 08:37 PM
12/09/17 08:37 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
The Chrysler "RFE" series transmissions DO NOT operate in that manner, They don't even have a "Actuator Pressure Circuit"
Main Line Pressure is applied directly to the clutch apply pistons by the shift solenoids, The Solenoids are NOT modulated by the TCM either, They are "ON" or "Off" (Though the LR/CC Solenoid CAN BE modulated by the TCM in 2nd-6th gear for converter clutch operation).
The VPS/PCS (Pressure Control Solenoid) of course IS modulated by the TCM.
Re: What's Your Opinion on Transmission Line Boosters? [Re: mphilleo] #4599345
12/09/17 08:53 PM
12/09/17 08:53 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Some units (The Allison 1000 for example) do use clutch actuation pressure that IS separate from Main Line Pressure. This eliminates the need for hydraulic Accumulators/Compensators.....I believe this is the type of control system your referencing here Zeng?
Then there are units that use a "Actuator Feed Limit" just for Solenoid & shift valve operation & is regulated to a lower static pressure mechanically, However.....Main Line IS used for actual clutch actuation (The 4T60E, 4L60E, 4L80E are examples).
