So I got the names of 2 more shops today and was able to stop by one of them cause I was in the area.
This shop only does remanufactured engine installations. They don’t like Jasper so they use ATK instead. The owner was a very personable guy and gave me a tour of their large work area where they had about 7 or 8 engines installs going on. Impressive shop from what I could tell: neat, organized, clean considering what's going on there and well lit. Lots of room between jobs. The kind of work environment I’d like to be in if that was my occupation.
He went over several options with me including remaned, new heads, rebuilding my engine and used . Reman is the only thing that seems to make sense to me so far.
This engine is a fairly technical piece of equipment, enough so that it drives up the cost. Just pulling the heads off isn’t so easy with 3 timing chains and head mounted cams. Whether its new heads , which is a gamble cause I don’t know the condition of the pistons and walls, or a remanufactured engine, it looks like it’s gonna cost me some bucks if I want to keep my Jeep.
Just pulling the engine out and dropping another one in isn’t too bad but the engine itself is.
The ATK reman would run about $4,800 pl tax installed. Better than $5,900 but still a lot.
I’ll check another shop on Friday if I can. My Jeep is back home for now and I’m driving another car for the time being so that takes some of the urgency out of the equation which helps a lot.
I’ll keep you all posted.
Thanks again to everyone for your input.
