Supertech VS Redline - Project Farm
by StevieC. 03/18/19 03:01 PM
How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
122 registered members (2012AccentSE, ABerns, 1978elcamino, 2015_PSD, 11 invisible), 2,401 guests, and 53 spiders.
Topics286,019
Posts4,900,886
Members67,548
Most Online2,967
Mar 10th, 2019
'07 Suburban: post-TB clean idle woes #4597211
12/07/17 03:43 PM
12/07/17 03:43 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
A friend's '07 Suburban (5.3, 184K) threw P0121 yesterday. Another friend who's plenty capable with all things post-2000 Chevy trucks scanned it, cleared the code, and sent him to me to clean the throttle body.
No CEL when I got it, no strange behavior as I pulled it into the shop. Took the throttle body off the intake but left it plugged in (caught the carb. cleaner and goo in a container) thinking that would avoid having to re-learn the throttle body. Upon startup, idle jumps to 1,700 but doesn't immediately come back down, instead staying right there, then slowly climbing up toward 2,500. Plugged in the scanner to watch the data, played with it for a minute, then took it for 6-mile drive. Runs fine, settles down to idle when in gear, and doesn't jump up high when moved from drive or reverse back to park. However, just like clockwork, when I tap the gas pedal in park the idle jumps up again and doesn't come back down until I put it in gear again. Also, startup idle is still just as high. Data shows desired idle @ 650-700 and actual at whatever speed it's revving, most of the time being ~2,400. Just to check it off the list I pulled the connectors on the TB and gas pedal sensor, inspected and applied dielectric grease - no change. Still no CEL, either.
Any wisdom?
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597230
12/07/17 04:00 PM
12/07/17 04:00 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
Does the service manual specify an idle relearn procedure?
2018 Hyundai Elantra VE
2013 Honda Pilot EX-L 4WD
2002 Honda Accord EX-L
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597231
12/07/17 04:00 PM
12/07/17 04:00 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Sounds like you need to relearn the idle with a bidirectional scantool. shrug
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597232
12/07/17 04:01 PM
12/07/17 04:01 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I have heard of this but never experienced it myself.
1.Disconnect the battery and hold the + and - leads together for a few seconds.
or
2.Simply give it more time
I am sure you do not need any special toolsl
Hope you didn't over apply any cleaner to the throttle body. You don't want cleaner in the motor/gears
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597235
12/07/17 04:07 PM
12/07/17 04:07 PM
Campbellsville, KY
Alex_V Offline OP
Alex_V  Offline OP
Campbellsville, KY
The guy that pulled the codes said he's sure it just needs relearned. He needed it this evening but it'll be back tomorrow for rear brakes so I'll do a proper re-learn then if it hasn't straightened itself out.
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597246
12/07/17 04:18 PM
12/07/17 04:18 PM
NE Florida
Throt Offline
Throt  Offline
NE Florida
I know it's not a Ford but I've done this a few times and I know it does what he says it does because I've done it.
https://www.youtube.com/watch?v=hZAsoqmqhdM
'18 Honda Accord Touring, 1.5T, 6,200, PPPP 5w30 w/ FU
'17 Elantra, 2.0L, 25,000, QS Ult. 0w20 w/ FU, hers (lease)
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597276
12/07/17 04:59 PM
12/07/17 04:59 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: Alex_V
Any wisdom?
Yes. It helps if you remove all the sensors from the throttle body before you start cleaning it. GM uses a Tamperproof T20.
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597283
12/07/17 05:12 PM
12/07/17 05:12 PM
ON, Canada
yugrus Offline
yugrus  Offline
ON, Canada
You should never open the throttle plate by hand if you don't have the scanner to follow the re-learn procedure. It is easier to have an assistant to open the plate by stepping on the pedal with key on, engine off, while TB is still on the car. This way you can clean the front, then remove the TB and clean the back. Get the shaft area good, so it doesn't stick. Clean as much of the intake as you can get, while there.
If the shaft isn't sticking, the idle will come down with time. Disconnecting the battery is another option, as previously suggested.
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597297
12/07/17 05:42 PM
12/07/17 05:42 PM
MN
TmanP Offline
TmanP  Offline
MN
My GM has a procedure to relearn the idle (after the battery is disconnected). I don't have the repair manual on me but it's so many seconds with the key on but the engine off, so many seconds with the engine running, then shut off.
I'd look for a similar procedure online, disconnect the battery and try again.
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597462
12/07/17 08:34 PM
12/07/17 08:34 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Sounds like the TPS. i replaced my TB a couple years ago for something similar. They are relatively cheap to shotgun if you want to Hitachi TB W/TPS
Clearing codes is fools gold. Doesn't fix the problem, doesn't make it go away. Makes it harder to fix a problem. Most codes will clear on their own when fixed. A relearn procedure should not be necessary if the engine is running good. When you reset power, it resets to factory original config. Should not be any noticeable changes if things are good. Learning is continuous and ongoing. So there is no point.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 162k ST HM 10w30
05 Malibu Classic 108k Unk
Re: '07 Suburban: post-TB clean idle woes [Re: Alex_V] #4597836
12/08/17 09:19 AM
12/08/17 09:19 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Here is the relearn procedure you HAVE to do and with a Tech2 or similar high end scan tool:
Scan Tool Idle Learn or Idle Learn Reset Procedure Performed after the throttle body is cleaned or replaced
1. Ignition ON, engine OFF, perform the Idle Learn or Idle Learn Reset in Configuration/Reset or Module Setup.
2. Engine idling, observe the scan tool Throttle Body (TB) Idle Airflow Compensation parameter. The TB Idle Airflow Compensation value should equal 0% and the engine should be idling at a normal idle speed.
3. Clear the DTCs and return to the diagnostic that referred you here.
