1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
115 registered members (AndyB, 4WD, 2009Edge, 240_Ed, 2015_PSD, Altima2, 8 invisible), 2,256 guests, and 64 spiders.
Topics286,399
Posts4,907,608
Members67,614
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Pennzoil Euro L no longer VW Approved? #4597195
12/07/17 03:22 PM
12/07/17 03:22 PM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Back in 2014ish, when I had a TDI, I used Euro L. It was 504/507 approved, so perfect. As I look for a moderately priced, low SAP, decent NOACK oil, I thought that maybe this would be a good choice.
Then...realized NO VW approvals. Zero. Any news I missed? Looks like the only Pennzoil Approved, lower SAP oils are AV. AV doesnít look too impressive on paper, so I am shying away
Interesting that L carries the LL-04 rating, as well as MB 229.31 and 229.51. I thought these specs were more stringent that VW specs.
Perhaps Pennzoil just didnít want pay for certification due to TDIs no longer being produced?
Would love to use this, and feel pretty confident doing so, but wanted to see if anyone had any color on this.
Thanks.
2018 Honda Accord Sport 2.0T/10 Speed
Modern Steel Metallic/Black
Factory Fill/Filter
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4597198
12/07/17 03:27 PM
12/07/17 03:27 PM
Chicago / IN
vinu_neuro Offline
vinu_neuro  Offline
Chicago / IN
This would make sense. It's probably been reformulated.
Or 504/507 changed and it no longer passes, like what happened with M1 0W-40 and LL-01. But I don't think VW reuses a spec numbers when they change the specifications, the way BMW does. So it's probably what you stated above.
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4597210
12/07/17 03:36 PM
12/07/17 03:36 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Pennzoil has a Platinum Euro LX 0w-30 product that carries VW 504.00/507.00 approval. Apparently easier to find in Canada than it is in the US.
https://bobistheoilguy.com/forums/ubbthr...w30#Post4098396
I'm wondering if this is a dealer-only type product in the US.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4597278
12/07/17 05:03 PM
12/07/17 05:03 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'm convinced what is contained in the add pack for VW 504/507 oils will not show up in a UOA or VOA.
However, quattro Pete once said something about an engineer telling him low-saps oils barely make spec while
full-saps oils can far exceed the specified wear requirements such as a VW 502 oil.
Me: 13' VW GTI 3 door 6 speed manual
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4597360
12/07/17 06:52 PM
12/07/17 06:52 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
VW 504.00/507.00 has most stringent wear requirement for 0/5W30 oils.
MB229.51 and LL-04 are more stringent in deposit/NOACK/oxidation requirements.
15' Toyota Sienna AWD (Mobil1 5W30 EP+OEM filter).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4597396
12/07/17 07:31 PM
12/07/17 07:31 PM
Illinois
BTLew81 Offline OP
BTLew81  Offline OP
Illinois
Good stuff guys. Wish this was vw Approved.
Factory Fill/Filter
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4598065
12/08/17 01:54 PM
12/08/17 01:54 PM
North Carolina, USA
sohccammer427 Offline
North Carolina, USA
Penn Euro formulations are A3/B3 in all grades (0w-40, 5w-30, 5w-40) and that's fine.
Where is gets confusing is the Euro "x" formulations.
Euro L 5w30 is Dexos2 but has no VW approvals.
Euro LX 0w30 is VW 504/507 but no Dexos 2
Euro AV 5w-30 is VW 502.00/505.01/505.00
I am perplexed as why Penn can't/won't make their Euro L 5w30 both Dexos2 AND VW 504/507. Mobil1 does it with their ESP 5w30 formulation.
My Passat calls for 507.00, my Li'l Durmax Dexos2. I can use M1 ESP in both but it's harder to come by, but Euro L at WalMart (and it's cheap) only has one approval.
OEM approvals. A nightmare.
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4598233
12/08/17 04:35 PM
12/08/17 04:35 PM
Chicago / IN
vinu_neuro Offline
vinu_neuro  Offline
Chicago / IN
How much is the Castrol 504/507 oil from the VW dealer?
Re: Pennzoil Euro L no longer VW Approved? [Re: sohccammer427] #4598693
12/09/17 05:01 AM
12/09/17 05:01 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
The 5w-30 A3/B4 is a phantom product. But yes, the C3 type line is confusing. wink
Plain, simple Garak.
Re: Pennzoil Euro L no longer VW Approved? [Re: Garak] #4598846
12/09/17 10:31 AM
12/09/17 10:31 AM
Great Lakes
Great Lakes
In the US, it does exist...
http://a.co/irA9lJg
But the price is almost twice as what we pay for Edge 0w-40 here.
Re: Pennzoil Euro L no longer VW Approved? [Re: Quattro Pete] #4598848
12/09/17 10:33 AM
12/09/17 10:33 AM
Garak Offline
Garak  Offline
I meant the Pennzoil one. I can get the 5w-30 A3/B4 Castrol here, too, in 1 litre bottles.
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4598856
12/09/17 10:44 AM
12/09/17 10:44 AM
Great Lakes
Great Lakes
Ooops. My bad. Sorry.
Re: Pennzoil Euro L no longer VW Approved? [Re: Quattro Pete] #4598905
12/09/17 11:57 AM
12/09/17 11:57 AM
Garak Offline
Garak  Offline
Oh well. The Castrol 5w-30 A3/B4 is probably double the price of our 0w-40, too. wink
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4599471
12/10/17 01:08 AM
12/10/17 01:08 AM
Albury, NSW
JFAllen Offline
JFAllen  Offline
Albury, NSW
VW 504/507 oils almost by default meet A3/B3/B4, despite the fact that many don't list that spec. All VW oils must have a HTHS of >3.5. This is one example available in Aus. Pennzoil Euro LX (Helix Ultra ECT C2/C3 in other markets,) is a great (though expensive) oil. Been using that along with Helix Ultra ECT C3 (Dexos2) (Pennzoil Euro L in the US) in my Saab 9-5 for the last few years and have been having great economy and cleanliness. jsut keeping a stock when they go on sale as +$80 in Aus for 5-Litres crazy.
Also Dexos2 requires a HTHS of >3.5, which is why it's often recomended for GM cars (by the dealer) if you plan on taking them to the track, as they don't thin out as much as Dexos1 (CAFE) oils whcih must be >2.9? HTHS.
Regards
Jordan
Re: Pennzoil Euro L no longer VW Approved? [Re: BTLew81] #4599487
12/10/17 01:47 AM
12/10/17 01:47 AM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
Weird. 507.00 is low saps, and last time I checked ACEA A3/B4 asked for SAPS between 1.00 and 1,6 (also a min TBN of 10).
So clearly something fishy here (ACEA is/was self certifying).
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Page 1 of 3 1 2 3
