Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
Are there any cable techs here?
by Reddy45. 09/19/18 06:02 PM
VIRGIN ST2 STP FILTER CUT OPEN
by 53' Stude. 09/19/18 05:08 PM
Chrysler HOAT at 9 years...
by burla. 09/19/18 04:34 PM
Septic Tank pumping question
by wormwood1978. 09/19/18 03:46 PM
A5/B5 or A3/B3
by ka9mnx. 09/19/18 03:27 PM
LingLong
by sloinker. 09/19/18 02:42 PM
2018 Grand Caravan review
by tiger862. 09/19/18 02:39 PM
Diagnosing gas furnace
by Oro_O. 09/19/18 01:16 PM
Let's talk dipsticks and oil capacity
by csandste. 09/19/18 12:32 PM
Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
108 registered members (2013ecof150, 07hemi, 2004tdigls, 16HC, 11 invisible), 1,700 guests, and 37 spiders.
Topics290,679
Posts4,848,247
Members66,019
Most Online3,590
Jan 24th, 2017
frame rust #4597181
12/07/17 03:06 PM
12/07/17 03:06 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
As mentioned before, I have two spots on my F250 where the frame is rusted pretty bad. While the rust is bad, it still drives fine and is in no danger of breaking in half or anything like that anytime soon. I was considering 3 options, which would be the best? I'll be pulling the fuel tank down soon to do the 7.3 Hutch mod to the fuel tank, so I'll have complete access to the drivers side rust also. I was thinking of spraying down the rusted areas with either Fluid film OR used diesel oil cut down with diesel so it wouldnt be too thick, with a potato pump every 2 months or so, or I was considering grinding off the flaking rust and coating it good with POR 15. which would be thee best solution?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: frame rust [Re: mobilaltima] #4597204
12/07/17 03:30 PM
12/07/17 03:30 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I would probably do both. Clean and rust protect (POR15 or something like it) the areas you can get to, then when you're all done, spray it all with Fluid film or the like, in both areas you painted, and everywhere else you didn't paint.
Re: frame rust [Re: mobilaltima] #4597219
12/07/17 03:49 PM
12/07/17 03:49 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
If there is an issue of weakened steel that needs to be repaired.
POR15 or Eastwood Rust Encapsulator require prep to the metal area in order for it to work. That is sometimes easy and sometimes not.
Fluid Film or CarWell will seep through the rust and protect against future rust. Just clean off any large rust flakes or dirt first.
2015 Ford F250 w/Powerstroke
Re: frame rust [Re: mobilaltima] #4597220
12/07/17 03:50 PM
12/07/17 03:50 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
How big??? Quarter size? Dollar bill size? Bigger?
At minimum, Id likely try to grind off any major, loose rust, then etch properly with ospho or one of the other converters, then paint.
POR can be good stuff, but its all about how good of a bond it has, and how moisture can creep under. Im not convinced that its always the best solution.
If its too big, Id probably want to consider welding extra metal to the frame, not sure how much benefit it would have, but Id assume some...
Id do appropriate spraying with Krown, FF, or a waxy coating, depending upon how moisture can access the frame in those areas.
Re: frame rust [Re: mobilaltima] #4597288
12/07/17 05:21 PM
12/07/17 05:21 PM
Golden Meadow, LA
Golden Meadow, LA
can someone PM their number so I can text pics of the rust, to get a better opinion?
Re: frame rust [Re: mobilaltima] #4597296
12/07/17 05:41 PM
12/07/17 05:41 PM
Ceciltucky Maryland
Oldtom Offline
Oldtom  Offline
Ceciltucky Maryland
I Fluid Filmed an older Toyota Tacoma with the Kellesport pro gun specifically designed for Fluid Film. I paid about $120 for the gun and nozzles and the entire job took only a few hours. The great advantage of the Kellesport gun is the 36 inch flex nozzle. I was able to snake the nozzle into every frame hole, pull the trigger and pull it out slowly. The gun left a super heavy coat of fluid film INSIDE the box frame. This may be less critical in a truck with a C channel frame. Fluid Film can be applied over existing rust with no surface prep, just spray yearly if you live in a road salt area. Quick, easy, cheap ( $45 per gallon ) Sorry if I sound like a salesman for fluid Film, the stuff flat out works.
But wait, there's more!
Once you have the pro spray gun, you can rust proof vehicles for extra cash. One gallon will do 2 vehicles.
Re: frame rust [Re: mobilaltima] #4597339
12/07/17 06:31 PM
12/07/17 06:31 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
CarWell gives you a warranty if their shop does your car when new and then yearly.
The shop has experience as to where to drill holes for the body cavities.
Re: frame rust [Re: Oldtom] #4597341
12/07/17 06:33 PM
12/07/17 06:33 PM
Toronna
maxdustington Online content
maxdustington  Online Content
Toronna
Wire wheel on an angle grinder (not a cup brush on a drill) and acid or sandblast and acid. Sandblasting + acid is the only method to stop the rust from coming back ever short of immersion according to my research. When I wanted to remove rust on my car, I sandblasted it with a handheld blaster with a hopper, applied ospho and then painted it.
Ospho is pretty expensive, so you could wire wheel it and hit it with pickling vinegar or some type of acid from a building supply store.
I think the acid is the key, as it converts available rust into something else I forget the name of. It turns the rust from red to black. I think sulfuric acid is the active ingredient in most "rust converters". Acid also etches surrounding steel to improve paint adhesion.
If you get most of the rust and do a good job painting, you will probably never have to worry again. If you caught it early enough.
EDIT: "bad" frame rust should really be cut out and patched, having rusty quarters or fenders will not cause your car to bend in half like a rusty frame could.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: frame rust [Re: mobilaltima] #4597478
12/07/17 08:55 PM
12/07/17 08:55 PM
AZ
ron17571 Offline
ron17571  Offline
AZ
I used Coro- seal. You could grind off the rust the best you can.Brush the Coro-seal on. Looks great.
2003 Dodge Caravan 140.000 miles
1992 Ford f-250 217,000 miles
Re: frame rust [Re: maxdustington] #4597492
12/07/17 09:13 PM
12/07/17 09:13 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
I'm pretty sure what you want is phosphoric acid (not sulphuric acid). I expect it converts rust (iron oxide) into iron phosphate.
There are good and cheap phosphoric acid products. As I recall Naval Jelly is one. It's all nasty stuff so you need gloves, goggles, long sleeves and a good supply of water to dip/drench yourself as necessary.
When you grind out rust there are always little pits of rust left. You have to "neutralize" the rust in those pits or it just reappears, initially as dots of rust through your paint. I treated a rust patch on an older Buick with surface grinding, then application after application of phosphoric acid and then just painted it. The rust never reappeared. A friend took a Mercedes 300D with an almost identical patch of rust to a reputable body shop. It looked great initially but within 6 months or so the rusty dots were coming back through the paint. He was disgusted.
Nowadays I'd use POR-15 after the phosphoric acid treatment, then paint.
But I'm not an expert on any of this so feel free to correct and add.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
Re: frame rust [Re: ecotourist] #4597506
12/07/17 09:34 PM
12/07/17 09:34 PM
Toronna
Toronna
You nailed it, buddy. Rust gets into the pores of the metal that wire wheeling and even sandblasting leave behind.
I'm not a pro at all but I have researched a ton as I think I live in the rust belt? I love cars and rust are both of our main enemies. Ospho is phosphoric acid, I checked the label. Same stuff that is in delicious Coca-Cola.
Re: frame rust [Re: maxdustington] #4597587
12/07/17 10:50 PM
12/07/17 10:50 PM
ecotourist Offline
ecotourist  Offline
I'm pretty sure it's actually Carbonic acid (CO2 + H20) in Coca Cola. Phosphoric acid would do really really really bad things to your stomach. Drinking a very small amount might be fatal - and a horrible death too.
When the Carbonic acid in Coca Cola breaks down, you get CO2 and water. The CO2 gives you bubbles, and burps.
2000 BMW 528i 5MT
Re: frame rust [Re: mobilaltima] #4597596
12/07/17 10:57 PM
12/07/17 10:57 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
get good Gloves and a bunch of Dollar store sponges with the green scrubbie attached, and a square of Naplins/ paper towels.
Apply and scrub and clean the steel with the scrubbie sponge saturated in Ospho. Brown rust will turn blackl, bare steel turns grey, painted surfaces get etched rust under paint will lift the paint above, but good paint is not removed, but it will change color slightly
Once the rust turns black, one can take a sharpish chisel they no longer care about and remove the black, and rescrub with the sponge. The rust spots will eventually turn to pitted steel if the process is repeated. One can speed up the brown to black conversion with a hairdrier.
Or one can paint over the black Iron phosphate instead of trying to remove it to get more Rust vcconverted and removed as much as they want until they are left with rust free bare etched steel.
The Ospho really preps the surface well for adhesion, when applied with the scrubbie, scrubbed and wiped off, with fresh applied and allowed some time to etch and convert. Scrubbing with Ospho is strangely cathartic.
I tried scrubbing with Naval Jelly, and was disappointed.
LA 318 Roller Cam
Pennzoil Platinum 10w-30
Fram ultra XG8A
Fram Ultra XG16 on remote transmission filter mount
Re: frame rust [Re: ecotourist] #4597603
12/07/17 11:04 PM
12/07/17 11:04 PM
ecotourist Offline
ecotourist  Offline
In case I wasn't absolutely clear about it, I'm pretty sure there is no phosphoric acid in Coca Cola or any other beverage.
2000 BMW 528i 5MT
Re: frame rust [Re: mobilaltima] #4597614
12/07/17 11:11 PM
12/07/17 11:11 PM
california
wrcsixeight Offline
wrcsixeight  Offline
california
Coca cola ingredients:
Ingredients: Carbonated Water, Sugar, Colour (Caramel E150d), Phosphoric Acid, Natural Flavourings Including Caffeine.
http://www.coca-cola.ie/drinks/coca-cola/coca-cola
LA 318 Roller Cam
Fram ultra XG8A
