Any news on what happened to this plane?
by Exhaustgases
06/18/18 02:36 AM
E4OD fluid ?
by Exhaustgases
06/18/18 02:23 AM
Update password ?
by meadows
06/17/18 11:59 PM
Delayed Sleep Phase Disorder
by Reddy45
06/17/18 11:56 PM
Nissan DLR put 0w20 in car that specs 5w30. worry?
by CrAlt
06/17/18 10:40 PM
revive Nicd battery
by Donald
06/17/18 10:27 PM
Need help finding an apartment for friend
by RazorsEdge
06/17/18 10:07 PM
ceratec with redline 5w30?
by 08z06
06/17/18 09:53 PM
does your COMCAST modem have weak wifi??
by edwardh1
06/17/18 09:50 PM
I hate stuck thermostats
by jakewells
06/17/18 09:49 PM
Mag1 75w90
by SavagePatch
06/17/18 09:32 PM
Old batteries at HD
by bbhero
06/17/18 09:27 PM
Buying a CPO Toyota - still get inspected?
by Parlay_Slow
06/17/18 09:08 PM
Water Pump Paper Gasket With RTV? Longevity?
by nobb
06/17/18 08:22 PM
Who makes Briggs & Stratton oil?
by spk2000
06/17/18 08:13 PM
Shure stylus replacement
by aquariuscsm
06/17/18 07:54 PM
Any 'crazy UCL overdose' fans out there?
by addyguy
06/17/18 07:11 PM
Source for Castrol Edge Supercar 5w50 oil?
by Rainier42
06/17/18 06:50 PM
Cherry vs orange hand cleaner
by JHZR2
06/17/18 06:27 PM
Why buy low mileage tires?
by HowAboutThis
06/17/18 05:49 PM
mostdecent, T1TN, Piper58, dunlop0078, Truth_Syrup
65258 Registered Users
26 registered (d00df00d, Buzzinhalfdozen, BoiseBound, Brad_C, discobob, Deltona_Dave, 3 invisible), 740 Guests and 30 Spiders online.
65258 Members
67 Forums
285504 Topics
#4596841 - 12/07/17 07:53 AM Trailer brakes work better sometimes than others?
motor_oil_madman Offline
Loc: Houston, Texas
This is on a Dexter axle. I don't know if they're out of adjustment or if it's just the difference between cold brakes and warm brakes. Trailer weights 2000 pounds with a load of 2000 pounds. I keep the controller on 5.5 and boost at 1 if you turn the boost off you have to crank power up to 9 or 10 to get the same braking effect.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#4596871 - 12/07/17 08:29 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Probably need adjusted-I usually pull the drum to look at everything, then adjust the shoes to get a tiny scraping noise as the drum is rotated. On mine, there's a huge difference between cold & hot brakes, I try to warm them up with the manual lever before I take the trailer out on the road.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4596884 - 12/07/17 08:39 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
mk378 Offline
Loc: USA
From your other thread about this, and reading the instructions for the brake controller:
* Boost is not recommended when the trailer is lighter than the truck.
* Establish the power setting by test driving at 25 mph and pulling the manual lever. Set the power to just below what makes the trailer brakes lock up. Then leave it there.
#4596977 - 12/07/17 09:51 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
Loc: Houston, Texas
I could set it at the max setting with no boost and they wouldn't lock up.
#4596989 - 12/07/17 10:08 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
Loc: Houston, Texas
That's the part that doesn't sound right to me. For such a light trailer I shouldn't have to run at such a high setting.
#4596991 - 12/07/17 10:10 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
CT8 Offline
Loc: Idaho
When a problem is suspected you have to start with basics.
"Don't let your preconceived notions get in the way of facts."Geoff Metcalf"
#4597006 - 12/07/17 10:20 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
Linctex Offline
Loc: Waco, TX
Make SURE your wire connections and contacts are all PERFECT.
If there is any corrosion anywhere that affects resistance of the circuit, you'll never have consistent brakes.
#4597074 - 12/07/17 11:47 AM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
BrianF Offline
Loc: Sask, Canada
+1 on checking the wiring. I run a 2001 Trailswest 5 horse gooseneck.... well my wife does. I just get to fix it. Double check all wiring, grounds and connectors. A loose/corroded ground will cause a mess of problems that can be a pain to track down. We had ours rewired but still ran into inconstant brake performance. I cleaned up some connections in the junction box and cleaned the grounds at the junctions boxes between the wheels. It really helped but then I ran into more problems. I ripped each drum off and found 3 out of 4 brakes had the shoes delaminate completely. They looked to be original brakes, lots of friction material left its just that they let go. The friction material is bonded on to the backing. 4 new 7,000lb 12x2" Dexter backing plates were installed. Once they were adjusted and run in they seem to work great now.
Check the wiring and check the brake mechanicals!
2006 Trailblazer LT. Castrol Edge with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. It has oil and still runs
#4597165 - 12/07/17 01:49 PM Re: Trailer brakes work better sometimes than others? [Re: motor_oil_madman]
mk378 Offline
Loc: USA
Using the manual lever? In that case, there's a problem.
