Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Optimal Compression Ratio for 91 Octane Fuel
by NICAT. 09/25/18 02:01 PM
Anyone used Amsoil DZF 0w40 ?
by ofelas. 09/25/18 01:33 PM
No more Turo - What now?
by dogememe. 09/25/18 01:08 PM
Military small arms ammo
by Camprunner. 09/25/18 12:03 PM
Pennzoil must not be selling , OR ?
by Kjmack. 09/25/18 11:51 AM
New black car, light swirls and water spots
by Redright9. 09/25/18 11:37 AM
Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Peppz, Jfa02, ibsfusion, Fearcat707, Perseo
66069 Registered Users
94 registered members (Ablebody, 53' Stude, 28oz, ad244, 2002 Maxima SE, AMC, 7 invisible), 1,415 guests, and 32 spiders.
Topics291,006
Posts4,854,205
Members66,069
Most Online3,590
Jan 24th, 2017
any hvac/heat pump experts here? #4596716
12/07/17 01:46 AM
12/07/17 01:46 AM
austin, texas
mikeinaustin Offline OP
austin, texas
i have a 7 year old carrier heat pump. tonight was the first night cold enough to turn heater on (about 40 outside). by chance, i happened to be near the outdoor unit when it came on. it turned on and fan spun for about 10 seconds then shut off for 5 seconds then back on, etc. i then turned thermostat way down and attempted to get it to output cold air instead of heat. this worked fine, the unit outside turned on and stayed on, no problems at all. i then retested heat mode and it once again started short cycling.
any ideas?
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4596797
12/07/17 07:53 AM
12/07/17 07:53 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I would try resetting the breaker and see if it somehow resets itself. As long as you set a temp indoors that is high enough (higher than indoor ambient air, it should work. Im not a hvac tech though.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4596804
12/07/17 08:03 AM
12/07/17 08:03 AM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
It's hard to diagnose from several states away.
Which of the two motors was coming on and going off? Fan or compressor? Or both?
If the compressor is coming on and staying on, and only the fan is cycling, it could be a motor problem (thermal overload tripping in the motor itself).
It could be a system problem (pressure switch not sensing, or low refrigerant for the HP cycle).
It could be a host of other small things.
I realize that's not what you want to hear; makes it hard to DIY this problem. But it's not easy to troubleshoot without being there to poke and observe.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4596827
12/07/17 08:32 AM
12/07/17 08:32 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
The electric booster coils are in the air handler inside the house. You need an HVAC guy with a schematic. The heat pumps are sophisticated units. There is also some defrost that happens. Maybe that's happening.
2015 Ford F250 w/Powerstroke
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4596879
12/07/17 09:35 AM
12/07/17 09:35 AM
USA
mk378 Online content
mk378  Online Content
USA
In a defrost cycle, the compressor runs with the reversing valve in the cooling mode (to pump heat outside and thaw the outdoor coil) with the outside fan stopped. Also the electric heaters inside are turned on so cold air doesn't come from the vents in the house. This should only happen for a few minutes at a time then it will switch back to pumping heat inside.
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4596934
12/07/17 10:12 AM
12/07/17 10:12 AM
TN
TTK Offline
TTK  Offline
TN
What he described is not the defrost cycle. A defrost cycle does not turn on and off like that. When it turns on it continues for the prescribed time( usually a few minutes) then reverses back to heating. May be a reversing valve issue.
2010 Volvo V70-3.2
Current Fill:Castrol Magnatec 5w-30
2018 Subaru Forester, 0w-20 Subaru oil
2001 Chevrolet Prism:Castrol Magnatec 5w-30
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4597176
12/07/17 03:02 PM
12/07/17 03:02 PM
austin, texas
austin, texas
just to close this thread. it was low on refrigerant. too low for heat cycle to work, but just high enough for cooling to work. cooling would have started to short cycled too as more refrigerant was lost over time.
Re: any hvac/heat pump experts here? [Re: mikeinaustin] #4597453
12/07/17 08:27 PM
12/07/17 08:27 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Where did the refrigerant go?
I too have a Carrier heat pump. 6 years old and A/C wasn’t cooling that well this summer. Turns out the evaporator is leaking. 10 year warranty on parts so I’m working on that.
2015 Hyundai Sonata 2.4L 84k Mobil 1 AFE 0w30 & OEM
2000 Toyota Camry 2.2L 230k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: any hvac/heat pump experts here? [Re: dnewton3] #4597591
12/07/17 10:52 PM
12/07/17 10:52 PM
Indianapolis, IN
dnewton3 Offline
dnewton3  Offline
Indianapolis, IN
Originally Posted By: dnewton3
... or low refrigerant for the HP cycle).
Well maybe I was a bit more accurate in diagnosis than I first imagined!
Glad it's working now.
