Back to Basics III
by MolaKule. 12/15/18 05:30 PM
Castrol Edge 0W40 vs. 5W40...Liqui Moly?
by TiGeo. 12/15/18 04:56 PM
Schumacher XCS15 voltage
by sweezy722. 12/15/18 04:19 PM
Solar battery tenders?
by slybunda. 12/15/18 04:10 PM
Bad Fuel Pressure Regulator.
by NICAT. 12/15/18 04:07 PM
Misfire = clogged cat
by Eric Smith. 12/15/18 04:00 PM
Cellphone Reliability
by Warstud. 12/15/18 03:29 PM
No email notification of replies anymore?
by atikovi. 12/15/18 03:07 PM
Crane EE 5301 Humidifier
by maverickfhs. 12/15/18 02:38 PM
I have sinned
by 901Memphis. 12/15/18 01:57 PM
Milwaukee m12 in vanhaus ratchet
by pda1122. 12/15/18 01:19 PM
Klein dikes
by Donald. 12/15/18 01:03 PM
Help Soldering 3.5mm mono microphone plug
by Brybo86. 12/15/18 01:02 PM
Small Trolling Motors
by wings&wheels. 12/15/18 12:49 PM
Toyota Corolla, good and bad?
by jongies3. 12/15/18 12:35 PM
Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
95 registered members (53' Stude, 69GTX, 71Chevyguy, 2004tdigls, 2003f7, 12 invisible), 1,940 guests, and 35 spiders.
Topics295,124
Posts4,928,119
Members66,688
Most Online2,553
Oct 27th, 2018
Maxima tie bar/lower radiator replacement #4596481
12/06/17 08:07 PM
12/06/17 08:07 PM
Hudson, NH
LeakySeals Offline OP
Hudson, NH
I have a Maxima torn apart waiting for an OEM lower radiator support to be delivered. Wondering if anyone went with just the bolts rather than put all the spot welds back.
Yep somebody tried to hide it with Bondo.
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: Maxima tie bar/lower radiator replacement [Re: LeakySeals] #4596659
12/06/17 10:32 PM
12/06/17 10:32 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I think I see what you did, you just drilled out the spot welds to disconnect the radiator support, correct ?
If you don't have a spot welder, you can do what's called a 'plug weld.'
You just put a hole in one of the pieces to be joined and then put that piece with the hole over top of the other piece. Fill in the hole with MIG wire. It works like a spot weld only on a larger scale.
Re: Maxima tie bar/lower radiator replacement [Re: Merkava_4] #4596849
12/07/17 08:00 AM
12/07/17 08:00 AM
Hudson, NH
Hudson, NH
Yes, there are also 5 large bolts per side. So I should pre drill, then fasten, then get someone to weld?
Re: Maxima tie bar/lower radiator replacement [Re: LeakySeals] #4596853
12/07/17 08:07 AM
12/07/17 08:07 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I've done it three times, and once on a Nissan Maxima as well. All three times I bolted the support to the body, generally it is most securely attached through the bumper mounts. I've never had a problem later and it's been nearly 10 years on the Accord.
1994 BMW 530i, 238K
1996 Honda Accord, 266K
1999 Toyota Sienna, 407K
2000 Toyota ECHO, 280K
Re: Maxima tie bar/lower radiator replacement [Re: LeakySeals] #4597336
12/07/17 05:30 PM
12/07/17 05:30 PM
USA
slacktide_bitog Offline
USA
When you get the new one, make sure to spray Krown on it, or something similar.
I still have my OEM radiator support that I have to take to a local body shop. It is going to cost about $600 for the install.
Re: Maxima tie bar/lower radiator replacement [Re: slacktide_bitog] #4597425
12/07/17 06:59 PM
12/07/17 06:59 PM
Hudson, NH
Hudson, NH
Thats a fair price. Because half the nuts bolts will snap off during the removal of the nose. So make sure you get that price firm. I used https://www.nissanpartsdeal.com/ for misc hardware. Ended up replacing $90 worth of nuts bolts, hose clamps, hoses, etc. Still drilling and tapping snapped bolts after a week. Other bolts are currently bathing in evapo-rust while I wait for UPS to find the front support which is currently listed as "Exception" Just my luck the main part of the whole job. Expensive huge part.. MIA at UPS.
Re: Maxima tie bar/lower radiator replacement [Re: LeakySeals] #4597429
12/07/17 07:03 PM
12/07/17 07:03 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I'm thinking if you're able to bolt it on securely, then by all means do so.
Re: Maxima tie bar/lower radiator replacement [Re: LeakySeals] #4598514
12/08/17 07:59 PM
12/08/17 07:59 PM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
By all means, plug weld it. If you don't have a welder, find a shop you can drive it to, and have them plug weld it for you. A real body guy could plug weld it for you in less than an hour, well prolly a lot less, but they will charge you an hour of flag time. $35.00
I would not want to have a front end collision with that car without the core support properly welded back on the car. It is a structural part of the unibody/chassis, really, its more important than you might think! It ties both frame rail togather! Not only is it important for structural integrity, but everything attached to it, like radiator, ect. will be vibrating.
Me, bodyman, painter, bodyshop owner 30 years
08 Tribeca 86k PUP 5w30 wix
06 Accord Hybrid 134k PPHM 0w20 wix
02 Chevy k3500 99k Delvac 1 esp 5w40 wix
00 F350 136k Delvac 1300 15w40 wix
