2018 VW Atlas 3.6 4 Motion Reliability?
by GZRider - 09/16/19 11:48 PM
Account and posts removal
by newbe46 - 09/16/19 10:00 PM
Yamaha EF2800i break-in
by Uregina09 - 09/16/19 09:43 PM
Adding TCW3 to Gas Tank?
by maverickfhs - 09/16/19 08:45 PM
Motul 75w90 1L 12 pack $13.25
by wkcars - 09/16/19 08:36 PM
2019 Ford Fusion vs used?
by FL-400S - 09/16/19 08:33 PM
What is the reasoning for 2-fuel tanks on a rv?
by RazorsEdge - 09/16/19 07:54 PM
Thoughts and opinions on family haulers
by ram_man - 09/16/19 07:53 PM
2018 Silverado 5.3L M1 AFE 0W-20 5,065
by K20FA5 - 09/16/19 07:43 PM
18 Jeep 3.6 PPU 0w20 5k OCI
by IndyFan - 09/16/19 07:06 PM
Federal 9mm 115g FMJ Brass - $7.97/50 @ Walmart
by blupupher - 09/16/19 06:47 PM
Motorcraft FL-1995W different than than non-W?
by Cubey - 09/16/19 05:31 PM
1973 Bronco w/original 302
by BKinSD - 09/16/19 05:18 PM
B&S 21hp burning oil
by Mike141 - 09/16/19 04:28 PM
Prime Guard POF2222 C&P...
by AnthemBassMan - 09/16/19 03:36 PM
Verizon FIOS direct connect HD local channels
by Vikas - 09/16/19 02:36 PM
Bentonite grease abrasive properties?
by berlyn - 09/16/19 02:19 PM
R0CKETMAN, Southbend9, Bigaledge32, emilio15, Kokopelli34179
69303 Registered Users
46 registered members (ctechbob, carlprop, burla, chiefcook, A_A_G, BlakeB, 3 invisible), 1,181 guests, and 29 spiders.
Topics294,668
Posts5,064,166
Members69,303
Most Online3,532
Jul 30th, 2019
moog tie rods with no grease fittings :( #4596143 12/06/17 02:43 PM
I
izz Offline OP
I
I thought they all came with it, guess not, what does this mean I have to install them manually, wow, no other brands have them either on this car...
i need this, I don't care that it comes with lifetime warranty...
Re: moog tie rods with no grease fittings :( [Re: izz] #4596152 12/06/17 02:52 PM
K
kschachn Offline
K
What? In my experience the non-greaseable ones are of a higher quality than the ones with fittings. I'd take them any time over the others.
The only ones I've ever had prematurely fail were Moog "Problem Solver" greaseable ends.
Whatever you do, do not drill holes in the ones you have now and put in fittings.
1994 BMW 530i, 246K
1996 Honda Accord, 280K
1999 Toyota Sienna, 420K
2000 Toyota ECHO, 281K
Re: moog tie rods with no grease fittings :( [Re: izz] #4596229 12/06/17 04:06 PM
blupupher Offline
Some do not have them (OEM or aftermarket) for clearance reasons.
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5W-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: moog tie rods with no grease fittings :( [Re: kschachn] #4596238 12/06/17 04:21 PM
Silverado12 Offline
That's my experience too. Especially true for U-joints.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: moog tie rods with no grease fittings :( [Re: Silverado12] #4596246 12/06/17 04:29 PM
M
MasterSolenoid Offline
M
Originally Posted By: Silverado12
[quote=kschachn]What? In my experience the non-greaseable ones are of a higher quality than the ones with fittings. I'd take them any time over the others.
And I would believe this is because the NON Zerk (u-joint) does NOT have the internal passage-ways for the grease to travel.
The OP was referring to Tie Rods. But good point about NOT reworking u-joints.
Back when all suspension parts had zerks, how long did they last ?
Today, 'sealed' (no zerk) is the way to go.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: moog tie rods with no grease fittings :( [Re: izz] #4596260 12/06/17 04:50 PM
Z
zzyzzx Offline
Z
Are they reboxed, or made in USA?
Re: moog tie rods with no grease fittings :( [Re: izz] #4596263 12/06/17 04:52 PM
M
mightymousetech Offline
M
What the [censored] is a grease fitting? smile
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2013 BMW 135i M Sport Edition Motul 0W40, MTL/MT-LV
2010 BMW 328i X-Drive, Castrol 0W40, MT-LV
Re: moog tie rods with no grease fittings :( [Re: mightymousetech] #4596267 12/06/17 05:00 PM
M
Merkava_4 Offline
M
A.K.A 'Grease Zerk'
Re: moog tie rods with no grease fittings :( [Re: izz] #4596309 12/06/17 06:03 PM
rollinpete Offline
I like the grease fitting's, every year just before I go for an inspection sticker,
I pump full of grease all the ones I can find, makes them nice and tight... happy
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spd 188k miles
03 Saturn Ion 2.2 L4 5spd 239k miles
PP, PPHM 50/50 5w30
Currently under the influence of oil shocked2
Re: moog tie rods with no grease fittings :( [Re: kschachn] #4596351 12/06/17 07:01 PM
V
Vern_in_IL Offline
V
This is the fact of the matter. Making a part more serviceable may not give longer life.
Re: moog tie rods with no grease fittings :( [Re: izz] #4596363 12/06/17 07:14 PM
B
benjy Offline
B
moog has always been top of line! remember when GM trucks hsd tie rod issues with OE TRW imported junk, my buddys alignment shop was busy, he said that the new OE replacements were even worse than worn ones at times!!! Moog was more $$$$ but a LOT better
Re: moog tie rods with no grease fittings :( [Re: izz] #4596409 12/06/17 08:12 PM
M
motor_oil_madman Offline
M
How do you drill for a zerk fitting without contaminating it with shavings?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: moog tie rods with no grease fittings :( [Re: motor_oil_madman] #4596415 12/06/17 08:19 PM
M
Merkava_4 Offline
M
Put grease on your drill bit.
Re: moog tie rods with no grease fittings :( [Re: motor_oil_madman] #4596855 12/07/17 09:09 AM
K
kschachn Offline
K
You don't. Do not drill fittings that aren't already greaseable. You're going to wreck them and it's completely unnecessary.
1994 BMW 530i, 246K
