Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Bailes1992, billt460, A1O, Billbert, bbhero, 6 invisible), 643 guests, and 25 spiders.
Topics287,672
Posts4,932,028
Members67,838
Most Online2,967
Mar 10th, 2019
moog tie rods with no grease fittings :( #4596143
12/06/17 02:43 PM
12/06/17 02:43 PM
Ohio
izz Offline OP
izz  Offline OP
Ohio
I thought they all came with it, guess not, what does this mean I have to install them manually, wow, no other brands have them either on this car...
i need this, I don't care that it comes with lifetime warranty...
Re: moog tie rods with no grease fittings :( [Re: izz] #4596152
12/06/17 02:52 PM
12/06/17 02:52 PM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
What? In my experience the non-greaseable ones are of a higher quality than the ones with fittings. I'd take them any time over the others.
The only ones I've ever had prematurely fail were Moog "Problem Solver" greaseable ends.
Whatever you do, do not drill holes in the ones you have now and put in fittings.
1994 BMW 530i, 241K
1996 Honda Accord, 267K
1999 Toyota Sienna, 410K
2000 Toyota ECHO, 280K
Re: moog tie rods with no grease fittings :( [Re: izz] #4596229
12/06/17 04:06 PM
12/06/17 04:06 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
Some do not have them (OEM or aftermarket) for clearance reasons.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: moog tie rods with no grease fittings :( [Re: kschachn] #4596238
12/06/17 04:21 PM
12/06/17 04:21 PM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
That's my experience too. Especially true for U-joints.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: moog tie rods with no grease fittings :( [Re: Silverado12] #4596246
12/06/17 04:29 PM
12/06/17 04:29 PM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
Originally Posted By: Silverado12
[quote=kschachn]What? In my experience the non-greaseable ones are of a higher quality than the ones with fittings. I'd take them any time over the others.
And I would believe this is because the NON Zerk (u-joint) does NOT have the internal passage-ways for the grease to travel.
The OP was referring to Tie Rods. But good point about NOT reworking u-joints.
Back when all suspension parts had zerks, how long did they last ?
Today, 'sealed' (no zerk) is the way to go.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: moog tie rods with no grease fittings :( [Re: izz] #4596260
12/06/17 04:50 PM
12/06/17 04:50 PM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
Are they reboxed, or made in USA?
Re: moog tie rods with no grease fittings :( [Re: izz] #4596263
12/06/17 04:52 PM
12/06/17 04:52 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
What the [censored] is a grease fitting? smile
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: moog tie rods with no grease fittings :( [Re: mightymousetech] #4596267
12/06/17 05:00 PM
12/06/17 05:00 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
A.K.A 'Grease Zerk'
Re: moog tie rods with no grease fittings :( [Re: izz] #4596309
12/06/17 06:03 PM
12/06/17 06:03 PM
Western Ma.
rollinpete Offline
rollinpete  Offline
Western Ma.
I like the grease fitting's, every year just before I go for an inspection sticker,
I pump full of grease all the ones I can find, makes them nice and tight... happy
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive187k miles
03 Saturn Ion 2.2 L4 5spddrive238K miles
PPHM 50/50 5w30 and Fram Ultra x 2
Currently under the influence of oil shocked2
Re: moog tie rods with no grease fittings :( [Re: kschachn] #4596351
12/06/17 07:01 PM
12/06/17 07:01 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
This is the fact of the matter. Making a part more serviceable may not give longer life.
Re: moog tie rods with no grease fittings :( [Re: izz] #4596363
12/06/17 07:14 PM
12/06/17 07:14 PM
pa
benjy Offline
benjy  Offline
pa
moog has always been top of line! remember when GM trucks hsd tie rod issues with OE TRW imported junk, my buddys alignment shop was busy, he said that the new OE replacements were even worse than worn ones at times!!! Moog was more $$$$ but a LOT better
Re: moog tie rods with no grease fittings :( [Re: izz] #4596409
12/06/17 08:12 PM
12/06/17 08:12 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
How do you drill for a zerk fitting without contaminating it with shavings?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: moog tie rods with no grease fittings :( [Re: motor_oil_madman] #4596415
12/06/17 08:19 PM
12/06/17 08:19 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Put grease on your drill bit.
Re: moog tie rods with no grease fittings :( [Re: motor_oil_madman] #4596855
12/07/17 09:09 AM
12/07/17 09:09 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
You don't. Do not drill fittings that aren't already greaseable. You're going to wreck them and it's completely unnecessary.
1994 BMW 530i, 241K
