Toyota brand conventional (TGMO)
by Jaha24k
06/20/18 01:45 PM
Any synthetic oil rebates currently or soon?
by 07Piloteer
06/20/18 01:32 PM
2018 Hyundai elantra motor oil
by kapama
06/20/18 01:00 PM
SN Plus on shelves
by 03s
06/20/18 12:23 PM
Group 90 Battery - 45 vs 60aH rating
by The Critic
06/20/18 12:19 PM
Tire on Church 15 Passenger Van
by Gebo
06/20/18 11:58 AM
Battery Disconnect Switch?
by Pike51
06/20/18 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
06/20/18 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
06/20/18 11:08 AM
2006 Prius
by Kira
06/20/18 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
06/20/18 10:18 AM
Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
nmac9, Theraven, battleman13, Shassis, Santo
65277 Registered Users
93 registered (AZjeff, bdcardinal, BAJA_05, beast3300, 07Piloteer, 03s, 13 invisible), 1653 Guests and 35 Spiders online.
65276 Members
67 Forums
285653 Topics
#4596112 - 12/06/17 01:02 PM Rear Wheel Bearing Hub with ABS
Recalculating Offline
Loc: New York
Getting constant rear wheel bearing groan on the below listed 2007 Buick Lacrosse. Sounds like right rear and will take the time to check out in the garage shortly. Vehicle has 50k on it with new struts on all four put on last year. Will replace both sides. Am reaching out for recommendations likely using Rockauto.
Am seeing a large number of name brands with varied range in price.
Thanks.
2009 Honda CR-V EX-L 55k
2007 Buick Lacrosse 52k
#4596126 - 12/06/17 01:16 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
Kestas Offline
Loc: The Motor City
I looked at what is available. Except for the AC Delco, they all look like aftermarket hub units.
How long are you planning on keeping the car? Have you looked into OEM from the dealer? They are typically the best quality and longest lasting.
#4596130 - 12/06/17 01:20 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
ls973800 Offline
Loc: Lake County, Ohio
I have used the ECCPP brand from Amazon several times for different vehicles. Very affordable and can find free shipping with Prime membership if you belong. If not, perhaps a neighbor or co-worker has a membership and can order for you. Most reviews have been very good. I have never had any go bad that I have purchased.
The ones on my son's Rendezvous (known for going thorugh bearings) have been on for about 50000 miles now with no problems. I had replaced both fronts for him.
Here is a pair of them for $75.99
https://www.amazon.com/ECCPP-Bearing-Assembly-2006-2009-Compatible/dp/B074354QTN/ref=sr_1_72
Edited by wwillson (12/07/17 07:37 AM)
Edit Reason: fix URL
#4596187 - 12/06/17 02:19 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
SatinSilver Offline
Loc: OH
SKF has excellent bearing hubs and the pricing seems very good on Rock for those. Which engine do you have, the 3.6 or the 3.8? Probably better than the oem ones.
#4596387 - 12/06/17 06:40 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
eljefino Offline
Loc: ME
Look on ebay too.
#4596437 - 12/06/17 07:37 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
14Accent Offline
Loc: MN
I would pick up the SKF for $77.79. The only other option worth while would be the ACD Original Equipment, not the Advantage line. Is it worth an extra $23? That's your call. It's most likely made by SKF or Timkin, anyhow.
Edited by 14Accent (12/06/17 07:39 PM)
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
#4596475 - 12/06/17 08:04 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
Loc: New York
Thanks for the input. I do have PRIME. I have already replaced the left front with AC Delco via Rockauto.
The vehicle is a 2007 with the Series 3 3800 @ only 50k. Amazed with the amount of work put in to keep it running quiet. Struts, brakes, emissions parts. Glad I have acquired the skills for DIY. The costs for replacement parts are much lower than paying for a new vehicle and or payments.
I do most of my own vehicle maintenance so I especially enjoy members with 3800s posting their endeavors going down the trail with replacing plastic elbows and intake manifold gaskets and the like. Been there.
Again thanks. If further, pile it on. Iíll reason through the input for my choice.
#4596517 - 12/06/17 08:27 PM Re: Rear Wheel Bearing Hub with ABS [Re: ls973800]
Merkava_4 Offline
Loc: Clovis, CA
This is the correct way to post a link without creating a side scroll bar for the whole thread:
Amazon LINK
#4596638 - 12/06/17 10:03 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
Trav Offline
Loc: MA, Mittelfranken.de
SKF is very good but there are lots of NOS Timken around for these and they are also top shelf. Rock has lower prices but shipping cost.
https://www.amazon.com/Timken-HA590092-Axle-Bearing-Assembly/dp/B000VKN4X4/ref=au_as_r
Edit: Not to be viewed with small 15" monitors.
Edited by wwillson (12/07/17 07:38 AM)
#4596668 - 12/06/17 10:50 PM Re: Rear Wheel Bearing Hub with ABS [Re: Trav]
Merkava_4 Offline
Loc: Clovis, CA
Trav - I tried your link over at the Test Forum. At the advice of a very technically skilled BITOG member by
the name of Linctex, if you delete everything that's in bold, the link will still work without causing a side scroll.
https://www.amazon.com/Timken-HA590092-Axle-Bearing-Assembly/dp/B000VKN4X4/ref=au_as_r?_encoding=UTF8&Make=Buick%7C45&Model=LaCrosse%7C2543&Year=2007%7C2007&ie=UTF8&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive
Example Below:
#4596675 - 12/06/17 11:08 PM Re: Rear Wheel Bearing Hub with ABS [Re: Merkava_4]
Linctex Offline
Loc: Waco, TX
Example Below:
Glad it is working out for you!
MOST (not always, but most) of the time you see a question mark, everything after it (including the ?) are not necessary when posting a link.
#4715288 - 04/03/18 03:06 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
Loc: New York
Just a followup post to the original 12/6/17 post. Putting the cheap mechanic's stethoscope to the culprit hub verified the needed change.
Completed the R&R of the passenger rear ABS wheel bearing hub. Purchased the SKF from Rockauto as recommended. Maybe a hour to change including a good brass wire clean out of the housing and applied dielectric grease to seal the ABS connection from the elements. Slammed out the studs from the old hub and bagged and tagged for possible future need.
Wheel now quiet. Thanks for the replies.
Edited by Recalculating (04/03/18 03:07 PM)
#4715404 - 04/03/18 05:48 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
andyd Offline
Loc: Marshfield , MA
Thanx for follow up grin2
Thick oil is better grin2
#4715472 - 04/03/18 06:54 PM Re: Rear Wheel Bearing Hub with ABS [Re: Recalculating]
Trav Offline
thumbsup And saved some money for beer too.
