Mixing oils
by bfleeman. 12/15/18 10:51 AM
Ebay 10% off Tech 15% off everything else*.
by demarpaint. 12/15/18 10:39 AM
Milwaukee Fuel M12 Ratchet 1/4” vs 3/8”
by Snagglefoot. 12/15/18 10:16 AM
Hifly Hf 805
by chrisri. 12/15/18 10:00 AM
Preferred 5.3L L83 Oil Filter
by zfasts03. 12/15/18 09:58 AM
sonata plastic fork starter failed three times.
by JustinH. 12/15/18 09:17 AM
HVAC Problems
by WTJackalope. 12/15/18 09:15 AM
Rough Idle after short trip
by Datarock. 12/15/18 09:07 AM
Homelite 360
by mobilaltima. 12/15/18 09:04 AM
Lovin' the Etec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Spkrdctr, torchredone12, JNG, Edmundo, NEKGuy
66688 Registered Users
81 registered members (4WD, 92saturnsl2, 94astro, 2002 Maxima SE, Ag76, 2004tdigls, 11 invisible), 2,068 guests, and 38 spiders.
Topics295,105
Posts4,927,867
Members66,688
Most Online2,553
Oct 27th, 2018
Removing blade adaptor hub. #4595811
12/06/17 08:55 AM
12/06/17 08:55 AM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
I wanted to put a new belt on my old 21" exmark mower and to do this you have to remove the blade, slide the hub off and then remove the crankshaft protector. Takes all of three minutes to do. I don't know if the key sheared or if it's just rusted on, but I used a 2 jaw puller and all that did was bend the the adaptor hub. Opinions? I was just trying to put a new belt on it so I could sell it. This mower is old and dirty, but still works good.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4595818
12/06/17 09:03 AM
12/06/17 09:03 AM
Houston, Texas
Houston, Texas
Any ideas on how to remove it? I don't know if that's something you want to apply heat to.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4595832
12/06/17 09:18 AM
12/06/17 09:18 AM
Texas
wag123 Offline
wag123  Offline
Texas
If you have access to an air compressor, an air chisel will get it off. You don't cut the blade adapter, you use a blunt chisel attachment using some force from the side and down/away from the engine, and just "vibrate" it off. Fast and easy.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4595841
12/06/17 09:30 AM
12/06/17 09:30 AM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
Sounds like you need some heat. I'd heat up the outside of it (part that goes around the crankshaft) and also spray it with some penetrating oil like Kroil, PB Blaster, or a 50/50 mix of acetone and ATF. Then try the puller.
2000 Jeep Cherokee 4.0L (181k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (36k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4595918
12/06/17 10:29 AM
12/06/17 10:29 AM
Houston, Texas
Houston, Texas
I think I'm going to cut off the flat flange so I can get the crankshaft protector off and get more access.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596016
12/06/17 11:36 AM
12/06/17 11:36 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
Yep, I'd try some good penetrating oil, heat or I like the air chisel idea too.
Worst case you can slit it with a cutoff wheel and pop it off.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596050
12/06/17 12:02 PM
12/06/17 12:02 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I bang on them with a hammer; of course that's not good for the crankshaft or the bearings.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596222
12/06/17 02:59 PM
12/06/17 02:59 PM
Houston, Texas
Houston, Texas
I have an air chisel, the problem is that crankshaft protector only allowed me to chisel the very end where the blade attaches. So if I cut that flimsy flat part off I can get more access to hit it with the chisel. Or maybe then I can hook the puller to the shaft instead which is more solid.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596233
12/06/17 03:16 PM
12/06/17 03:16 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yep.
As I get older, I hate fighting with stuff.
Cut a slit, pop old junk one off, replace with new adapter hub.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596328
12/06/17 05:26 PM
12/06/17 05:26 PM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
time + belt + new adapter = more than mower is worth??
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596352
12/06/17 06:02 PM
12/06/17 06:02 PM
Houston, Texas
Houston, Texas
Maybe. It was $1100.00 When new. I'm hoping to get $150 for it with a new belt. $75 as is.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596403
12/06/17 07:00 PM
12/06/17 07:00 PM
ME
eljefino Offline
eljefino  Offline
ME
Maybe you could get one of those link-belts that you assemble in place?
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596525
12/06/17 08:31 PM
12/06/17 08:31 PM
Texas
wag123 Offline
wag123  Offline
Texas
I have done a thousand of these! Just hit the side of it with the air chisel. No heat. Don't cut the flange off, it will make the removal more difficult. I promise you that it will come off.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596856
12/07/17 08:11 AM
12/07/17 08:11 AM
Houston, Texas
Houston, Texas
The only part I can access is the flange and I'd rather not put the air hammer on that part.i need to take the crankshaft protector off to hit it closer to the sump. I'm afraid I'll bend it if I just hammer at the other side.
Re: Removing blade adaptor hub. [Re: motor_oil_madman] #4596944
12/07/17 09:18 AM
12/07/17 09:18 AM
Texas
wag123 Offline
wag123  Offline
Texas
I know it is difficult to get to it with a crankshaft protector, but as long as you use a blunt fork-type bit in the air hammer you wont damage the blade mounting flange. You can also use a ball joint separator in the air hammer. Either way, the vibration of the air hammer will get it off of the shaft. I have done this a thousand times, trust me, it will work. Give it a try.
