recommendation on ball joints for an old Mazda?
Winnipeg MB CA
Hello all -
'97 Mazda MPV, 2WD (RWD), 335K km (> 200K miles)
Broken & separated ball joint on passenger side!
I'm looking for advice on what's a good replacement part (balancing availability, quality, and price).
NAPA locally has only the part for the 4WD, which is quite a bit different.
On-line choices (in every case, LCA w/ ball joint):
Beck-Arnley 102-4528 $103.84
Dorman 520-830 $103.68
Mevotek GK9651 $61.53
Mevotek CMK9651 $129.46
All prices are in C$.
Thoughts on any of the above? I do prefer to buy CAN/US/1st-world-manufactured parts when possible.
Thanks in advance!
Do you need to repair it right away? I would check rockauto if you can wait. We get ripped off with prices for those small parts.
It looks like a lower front control arm, with the ball joint included, is all that RockAuto can do for you, too. A Beck-Arnley control arm, in "daily driver" quality, is $58 (U.S.) RockAuto Mazda MPV Control Arm and it's another $15 (U.S.) to get to Winnepeg in a week or so, if you can make-do without the vehicle for that long.
Moog in Problem Solver series - you'll get a 555 Sankei as Trav mentioned. Otherwise, I'd look for OEM.
Those are all made in china/turkey/czech so unless you go OEM, which would probably be Japan, I don't know of any USA made ones. JTC1566 is the TRW replacement, that might have a better chance of higher quality manufacturing.
I'd stay away from Dorman and Mevotek if it is going into a car to be kept for long. B&A may be a hit or miss but I'd not want to ship something so heavy back.
Moog problem solver would be your best bet other than OEM.
