Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
Liquimoly Anti Friction - $6.83 Shipped/ Can
by ad244. 09/19/18 06:57 PM
ACEA spec for old Toyota??
by alexmarjanovic98. 09/19/18 06:54 PM
3.5EB Gen II: Oil & Interval
by Gene K. 09/19/18 06:09 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
21 registered members (FordCapriDriver, Ablebody, Bailes1992, ArrestMeRedZ, BlakeB, 4 invisible), 880 guests, and 43 spiders.
Topics290,698
Posts4,848,443
Members66,021
Most Online3,590
Jan 24th, 2017
Harbor Freight Voltmeter Issue #4595266
12/05/17 06:21 PM
12/05/17 06:21 PM
VA
maverickfhs Offline OP
VA
So my cheap/free HF voltmeter was working fine until last night. Today, I turned it on and display is all wonky and very dim, thought it's a battery.
Tried 2 different new batteries, but no luck. Has anyone experienced anything similar?
Yes, I can get a new one for free and do have a spare one too. But I rather not trash it if it'll work after a battery or some other minor fix.
Thanks for the advice and help.
2006 Civic EX 202K/AT
2006 Acura TSX 180K/AT
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595273
12/05/17 06:30 PM
12/05/17 06:30 PM
Around the corner
koffy Offline
koffy  Offline
Around the corner
I got a couple of those, They break even if you donít use them,,,. Iíve been happy with a $3x.xx craftsman I bought about 4 years ago
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595278
12/05/17 06:36 PM
12/05/17 06:36 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Its porobably a solder joint or connector that is loose. Open it up and wiggle the wires and see if t coes back.
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595279
12/05/17 06:36 PM
12/05/17 06:36 PM
iowa
Traction Offline
Traction  Offline
iowa
Fluke eliminates the issues hands down. Safety alone makes them worth the price.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595286
12/05/17 06:40 PM
12/05/17 06:40 PM
VA
VA
Just figured it out, one of the small screw for PCB was loose, tightened it up and Viola! thumbsup
Thanks all for the help.
Re: Harbor Freight Voltmeter Issue [Re: Traction] #4595294
12/05/17 06:51 PM
12/05/17 06:51 PM
South Carolina
eyeofthetiger Offline
South Carolina
Fluke or Megger are pretty good. The free Harbor Freight meter is one step above running a wire between a lightbulb and a rusty screwdriver. It's actually pretty good for what it is, but I wouldn't trust it.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595310
12/05/17 07:05 PM
12/05/17 07:05 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Get one of their better ones. I got one of theirs that can measure Hz and capacitor and temp in addition to voltage/ohms.
You depend on these things to work. Who wants a piece of [censored] that may or may not work at any given point in time.
2015 Ford F250 w/Powerstroke
Re: Harbor Freight Voltmeter Issue [Re: eyeofthetiger] #4595314
12/05/17 07:08 PM
12/05/17 07:08 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Small hijack here....Anybody ever use the transistor socket? I assume you need leads to connect the contacts to the correct socket.
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595324
12/05/17 07:22 PM
12/05/17 07:22 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I have tested capacitors for my well pump and the 60 Hz of my generator. Those features come in handy.
Re: Harbor Freight Voltmeter Issue [Re: Kira] #4595328
12/05/17 07:25 PM
12/05/17 07:25 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
You can use ohms to test a transistor. Like testing two diodes. It's basic test however.
Re: Harbor Freight Voltmeter Issue [Re: Donald] #4595341
12/05/17 07:40 PM
12/05/17 07:40 PM
VA
VA
Thank you, can you please share a link for it or a model number?
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595414
12/05/17 09:19 PM
12/05/17 09:19 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
I think I have 1/2 dozen of those free HF multi-meters. All still working except one that I smoked the Ohms function on by putting 115 VAC across it. LOL Still works on all the other functions though.
Re: Harbor Freight Voltmeter Issue [Re: ZeeOSix] #4595417
12/05/17 09:20 PM
12/05/17 09:20 PM
VA
VA
That's hilarious! Lol
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595426
12/05/17 09:29 PM
12/05/17 09:29 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Whenever I pick one of those up I blacken in the little "dot" on the switch handle with a Sharpie pen so it's easier to see what function it's set too. Might save the Ohms function down the line. smile
Re: Harbor Freight Voltmeter Issue [Re: maverickfhs] #4595469
12/05/17 10:10 PM
12/05/17 10:10 PM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Ive got a few of the free ones. They do go funny after a while - D.C. Readings are all over the place, very noisy, inaccurate.
