White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
35 registered members (c502cid, carlprop, Black_Thunder, Blkstanger, BlakeB, bubbatime, 4 invisible), 882 guests, and 30 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles #4594964
12/05/17 12:54 PM
12/05/17 12:54 PM
CA
The Critic Offline OP
CA
This car has seen 7-10k oil change intervals with 5W-20 synthetic (mostly Mobil 1) since the 30K mile mark. I have done most of the oil services on this car. When this oil was installed at 143K, a valve clearance adjustment and a spark plug replacement were also performed.
Also, this oil fill was Mobil 1 High Mileage 5W-20, not regular Mobil 1. The Oil Life Monitor was at 40%. This car sees mostly highway stop-and-go driving and the fill was in service for about 5 months. The air filter was a Wix that has been in service for 20K. Oil Filter was Genuine Honda.
I think the Fuel Dilution is due to the oil sample being taken when the engine was not fully warmed up. The car was here for a starter replacement and I only ran the car for about 5-10 minutes before taking the oil sample.
2011 Toyota Prius - 181k - M1 EP/EP HM Mix 0W-20
2007 Honda Accord 2.4 - 134K - Mobil 1 EP HM 5W-30
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4594976
12/05/17 01:03 PM
12/05/17 01:03 PM
Louisiana
camryrolla Offline
camryrolla  Offline
Louisiana
This Honda fit engine is as low-wearing as the Toyota's. I would run the OLM down to 0% and do another UOA to see if the iron ppm will break double digit.
'11 Camry 2.5L 160K mi
'07 Corolla 1.8L 220K mi
Always Fram XG filter.
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595005
12/05/17 01:29 PM
12/05/17 01:29 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
How the trans oil? I had to replace mine yearly due to "shearing"
This is for MT only.
Too bad I put LubriMoly in my 20?? and killed it. I knew I shouldn't have caved to the additive fanboyz around here.
Lesson Learned (Again!)
does the 09 have the firmer suspension before they slopped it?
Doe that have the real power VTEC?
2019 VW Jetta S,6M OCI#0 62mi-Castrol Edge Prof VW508+OE Filter; '17 Subaru Crosstrek CVT OC#5 37K mi-SOA/Idemitsu 0w20 + SOA Filter
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595015
12/05/17 01:38 PM
12/05/17 01:38 PM
WA
John_Dude Offline
John_Dude  Offline
WA
Despite the fuel dilution, the viscosity was still perfect. Very low metal wear numbers, nice run. I would definitely stretch out the interval to 9-10k, seeing how the TBN is still at 5.1
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595053
12/05/17 02:04 PM
12/05/17 02:04 PM
N.H, U.S.A.
N.H, U.S.A.
Numbers are low car has a lot of oil for its swept volume. Hard wear is captured the filter ( and the pickup screen if they are BIG bits) Most of the noted wear in the UOA is chemical etching and EP conversion.
IIRC 3.5L sump The Critic?
Engine is def worn in but likely not OUT yet smile
How is static compression?
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595059
12/05/17 02:08 PM
12/05/17 02:08 PM
N.H, U.S.A.
N.H, U.S.A.
There is a formula IV racing version of this motor.
Note: No exhaust manifold - same on production FITs but with close coupled catalyst.
Also note COP ignition thru the exhaust runners cast in head. YIKES!
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595144
12/05/17 03:02 PM
12/05/17 03:02 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Very good looking numbers. Looks like a bit of fuel dilution.
You might extend your OCI a bit but I'd look at 7500 before going to 10K.
2004 Corolla 128276
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74615
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595154
12/05/17 03:11 PM
12/05/17 03:11 PM
CA
raytseng Offline
raytseng  Offline
CA
What was the MM % when you sent it in. 40%? That would be the best usage of this data point to see if it lines up.
Especially since you are driving regularly this seems like a very conservative oci you haven't even exceeded honda rec.
If I recall for the 2nd gen Fit, in typical freeway use you could get about 12000 miles before the mm called for a change on conv. With a premium synthetic i wouldn't expect any issues until 15k.
Given this is an efficient higher MPG car this doesn't seem as crazy if you switch to a fuel used metric instead of miles.
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: JohnnyJohnson] #4595375
12/05/17 07:38 PM
12/05/17 07:38 PM
CA
CA
This was an unusually short run. The oil usually gets changed at about 10-11k. The car was here for a starter, so I changed the oil at the same time.
Yes, and the TBN is only 8 when the oil is new. Mobil seems to be doing a very good job with blending oils that are capable of long drains.
Not sure on the VTEC, but the suspension is fairly firm.
Sump capacity is 3.6L or 3.8 quarts. I drain and refill the auto trans oil every 20-30k with Honda ATF-DW1. Looking back at the records, it has been done 7 times.
Not a bad idea. Yes, 40% remaining when sample was taken. The engine was very clean when I did the valve clearance adjustment. I will see if I can find a picture.
Re: 2009 Honda Fit, Mobil 1 HM 5W-20, 7,128 miles [Re: The Critic] #4595381
12/05/17 07:42 PM
12/05/17 07:42 PM
CA
CA
Here is a picture of the engine at 143K when I performed the valve clearance adjustment.
