Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
75 registered members (allgm59, 97prizm, Aichiguy, 2010Civic, beanoil, 8 invisible), 1,244 guests, and 61 spiders.
Topics286,216
Posts4,904,436
Members67,579
Most Online2,967
Mar 10th, 2019
Grease for CV to hub splines #4594829
12/05/17 11:08 AM
12/05/17 11:08 AM
Nashville, TN, United States
Mossyoakglock Offline OP
I need to replace my CV axles on my 2008 Silverado 4wd. What is a good grease to use for the splines that go into the hub?
I have a can of the old GM grease (part # 12345718). Would that work or should I use something like a marine grease? I want use something that I can get at the local parts store.
2008 Chevrolet Silverado
5.3L / 4L60E
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4594843
12/05/17 11:20 AM
12/05/17 11:20 AM
New England
gathermewool Offline
New England
I've only replaced a few CV axles. Never used any grease. The splines are locked into place with the tranny, unlike differential gears, which mesh and unmesh continuously.
Wouldn't grease from the inner spline contaminate the ATF?
'14 Forester XT FA20DIT (Cobb Stage 1)
Edge 0W-40 + FU filter (64,774 miles)
'15 Legacy FB25 (OEM Stage, uh, neg. 7?)
Edge 0W-20 + FU filter (40,803 miles)
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4594851
12/05/17 11:26 AM
12/05/17 11:26 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Use a little never seize on the splines where it goes through the hub, it works well in the salt belt at keeping the corrosion out of the splines so the axles can be easily removed later.
Re: Grease for CV to hub splines [Re: gathermewool] #4594856
12/05/17 11:29 AM
12/05/17 11:29 AM
This is what my CV looks like.
The attachment on the diff side is bolted on with a flange and there is a seal between the flange and the diff/fluid so only one side has splines.
5.3L / 4L60E
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4594865
12/05/17 11:35 AM
12/05/17 11:35 AM
Trav Offline
Trav  Offline
Yep NS on the splines and a smear of grease where the seal rides is all that needs. You can use NS on everything but I prefer regular common grease with no particles (aluminum, copper, moly, etc) where the seal rides.
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4594920
12/05/17 12:46 PM
12/05/17 12:46 PM
I know I have some grease at the house already but I can't remember what kind it is. If I don't have an NS is it safe to use a high-temp/marine grease on the splines?
I have the GM grease but I think the other is Valvoline grease.
5.3L / 4L60E
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4594936
12/05/17 12:59 PM
12/05/17 12:59 PM
Trav Offline
Trav  Offline
Sure, that will be fine.
Re: Grease for CV to hub splines [Re: Mossyoakglock] #4595318
12/05/17 07:14 PM
12/05/17 07:14 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I used anti-seize on the splines is what I did.
Re: Grease for CV to hub splines [Re: Merkava_4] #4595353
12/05/17 07:49 PM
12/05/17 07:49 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
a little goes a long ways.
Re: Grease for CV to hub splines [Re: Vern_in_IL] #4596079
12/06/17 01:32 PM
12/06/17 01:32 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Yes that's why I apply it with an acid brush so that just a thin coat gets applied.
