How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
109 registered members (4WD, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,294 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
Question for Trav Re Torque Wrench #4594282
12/04/17 07:21 PM
12/04/17 07:21 PM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
Trav, canít find the post but I believe you once said you would only use a split beam torque wrench. What brand do you like? I am considering CDI or Precision Imstruments.
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4594307
12/04/17 07:45 PM
12/04/17 07:45 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Both of those are excellent tools buy the one that fits your needs as far as scale and budget goes. I use Stahlwille Manoskop but wouldn't pay US prices for them.
Amazon.de will ship this one for example to the USA and doesn't charge MwSt (German sales tax) so it will probably be less than $200. You add the attachments you want/need for $50 for the ratchet end, if you are interested in a Manoscop let me know, I can put one together to order for you.
https://www.amazon.de/Schraubenschl%C3%BCssel-Drehmomentschl%C3%BCssel-Schnelleinstellung-QuickRelease-Sicherheitsverriegelung-
Einsteckwerkzeuge/dp/B06XP57NFZ/ref=sr_1_sc_2?ie=UTF8&qid=1512433571&sr=8-2-spell&keywords=Stahlewille+Manaskop%2C
https://www.amazon.de/s/ref=sr_pg_2?rh=n%3A80084031%2Ck%3Astahlwille+manoskop+%5Cc&
page=2&keywords=stahlwille+manoskop+%2C&ie=UTF8&qid=1512433724&ajr=2
https://www.amazon.de/s/ref=sr_pg_2?rh=n%3A80084031%2Ck%3Astahlwille+Einsteckwerkzeuge%5Cc&page=2&keywords=s
tahlwille+Einsteckwerkzeuge%2C&ie=UTF8&qid=1512434625&ajr=2
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4594567
12/05/17 02:51 AM
12/05/17 02:51 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Re: Question for Trav Re Torque Wrench [Re: Linctex] #4594584
12/05/17 03:50 AM
12/05/17 03:50 AM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
Originally Posted By: Linctex
This my problem. The PI 1/2Ē are 40-250 and I mostly use around 75-80. PI assures me no problem using at low end of range but I am concerned. Would rather have a 20-150. The link you provided is the model I was considering. CDI equivalent has same range.
Re: Question for Trav Re Torque Wrench [Re: Trav] #4594595
12/05/17 04:14 AM
12/05/17 04:14 AM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
Thanks Trav for the offers but this looks a little too complicated for me plus wonder about service and warranty support.
PS Wonder why this thread has such small font?
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4594876
12/05/17 11:52 AM
12/05/17 11:52 AM
Trav Offline
Trav  Offline
I can understand that with the warranty. Just for information, what I like about that system is you can put any size drive ratchet you want on the end and use open end and box pieces without compensating for a crows foot.
If you don't need these features its sort of a waste. Buy either of the two brands you mention, both are very good.
Re: Question for Trav Re Torque Wrench [Re: Trav] #4596285
12/06/17 05:21 PM
12/06/17 05:21 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
How It's Done:
Amazon Link 1
Amazon Link 2
Amazon Link 3
Re: Question for Trav Re Torque Wrench [Re: Merkava_4] #4596386
12/06/17 07:40 PM
12/06/17 07:40 PM
Trav Offline
Trav  Offline
Go play with your hemorrhoids or something.
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4597173
12/07/17 02:55 PM
12/07/17 02:55 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Interesting, I was looking for a new torque wrench just yesterday. I had also decided that my next one would be a split beam model, and similarly, my needs are in the 70-80 ft-lb range (for lug nuts).
The 3/8" Precision Instruments model is a little less expensive than the 1/2" and goes up to 100 ft-lbs, which would work for us.
I have no doubt the 1/2" model (22") would work, but my old spring type 1/2" torque wrench (20") was occasionally longer than I needed (bumping into bodywork while torquing), and thus a little unwieldy. The 3/8" is almost perfect at 17" long, except for the 3/8" drive over the 1/2" drive, which a simple adapter would fix. However, I would get the flex ratchet head if I were to get the 1/2" split beam model, so the size may not be an issue.
Re: Question for Trav Re Torque Wrench [Re: Merkava_4] #4597704
12/08/17 03:57 AM
12/08/17 03:57 AM
Kennett Square, PA
artbuc Offline OP
artbuc  Offline OP
Kennett Square, PA
How It's Done:
Amazon Link 1
Amazon Link 2
Amazon Link 3
How did you do that? Every once in a while I would like to change the display name of a url link. I look up instructions and find them unintelligible and just say forget it...not worth the effort. Even if I learned how, I will forget how to do it by the time I want to do it again.
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4597880
12/08/17 10:04 AM
12/08/17 10:04 AM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
There's not too much to it, when you want to insert a link, click the icon ( ) and paste the URL there, then type in the text in the second box. Don't just copy/paste the URL into the text box.
Re: Question for Trav Re Torque Wrench [Re: artbuc] #4598624
12/08/17 11:37 PM
12/08/17 11:37 PM
WA (USA)
Y_K Offline
Y_K  Offline
WA (USA)
In Merkava's defence: the man confessed a few times in past that he has some problems and it's not easy to live in his walking torture chamber. Just in case anybody missed that and wonders why he sounds so annoyingly out of place sometimes.
