Tire on Church 15 Passenger Van
by Gebo
06/20/18 11:58 AM
Battery Disconnect Switch?
by Pike51
06/20/18 11:35 AM
03 Maxima Cam sensor questions
by LeakySeals
06/20/18 11:09 AM
Wood Fairing?? Yes, and it's beautiful!
by webfors
06/20/18 11:08 AM
2006 Prius
by Kira
06/20/18 11:06 AM
Amsoil XL 5w30, 10K OCI, 2006 Expeditition
by meborder
06/20/18 10:18 AM
Mouse Visiting Car
by Ifixyawata
06/20/18 10:07 AM
Hit a shopping cart at 30mph
by LeakySeals
06/20/18 10:00 AM
Let's Talk Bed Pillows
by LoneRanger
06/20/18 09:21 AM
Changed Speedo Gear on 700r4 Tailshaft
by Pike51
06/20/18 09:20 AM
Which do you prefer: ZL-1 Camaro or GS Corvette ?
by Mr Nice
06/20/18 08:41 AM
CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
86 registered (03s, billt460, ARB1977, BillyTheKid, 2015_PSD, 14 invisible), 1644 Guests and 38 Spiders online.
65276 Members
67 Forums
285649 Topics
#4594279 - 12/04/17 06:21 PM Oil filter bypass valve
littleant Offline
Loc: Vermont
Hi folks. Ran Mobil 1 5w30 with a Mobil 1 filter and currently running QSUD 5w30 with a fram ultra. When temperature is above 30 the oil light goes out about 1 second after engine starts. When temperature hits 20 and lower the oil light goes out when the engine is cranking. This happens with either oil and filter. Am I correct in assuming this is a function of the bypass valve. Never any noise
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
#4594313 - 12/04/17 06:52 PM Re: Oil filter bypass valve [Re: littleant]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Nope-the oil is thicker & builds up pressure more quickly.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4594337 - 12/04/17 07:09 PM Re: Oil filter bypass valve [Re: bullwinkle]
littleant Offline
Loc: Vermont
Thanks bullwinkle
#4594397 - 12/04/17 08:14 PM Re: Oil filter bypass valve [Re: bullwinkle]
CR94 Offline
Loc: Western S.C. since 1996
Yes, because you get enough pressure to shut off the idiot light even at cranking speed.
2011 Toyota Prius now at 88K
#4595695 - 12/06/17 06:18 AM Re: Oil filter bypass valve [Re: littleant]
dnewton3 Offline
Loc: Indianapolis, IN
To be a bit more detailed ...
The oil filter BP valve has nothing to do with the engine oil pressure sensor. However, the cold thick lube will have an effect on the overall engine oil system pressure and how it interacts with the pump BP relief. Pressure is the resistant to flow in hydraulics. The pump is a positive displacement system, the oil is going to move somewhere, somehow. So if you are getting pressure a few seconds sooner, it's because it's resisting flow and building up pressure sooner. That does not mean it's getting no flow, but it's likely getting a reduced flow, contrasted to a warm oil.
Don't panic though; it really does not matter. I've not seen any evidence that this topic actually matters in terms of wear-rate data. You don't have a lot of ability to control this. You can select a thinner lube (typically down one grade, if you want), but that, too, does not really affect wear in a discernible manner. If you're already at a 20 grade, there's not much room to go lower anyway.
Edited by dnewton3 (12/06/17 06:19 AM)
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
#4595834 - 12/06/17 09:20 AM Re: Oil filter bypass valve [Re: dnewton3]
littleant Offline
Loc: Vermont
Thank you dnewton3 for the detailed info. With my 02 jeep with the 4.0 tractor engine with 170,000 miles I never worry about 5w30 HM every 5,000 its good. The mountaineer with the 4.0 with all the timming chains I watch it like a hawk. 68,000 miles
