Recommend me an OEM look foglight kit 2015 Cruze
Union County, PA
Recently bought a 2015 Cruze 1LT. Please recommend me a high quality OEM look foglight kit. I was told that the car will not allow a switch from a car that came with foglights to be used...unfortunatly
Aside from the cosmetic look, most "factory fog lights" don't actually contribute to better visibility.
http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
I am not sure that you wee told correct information. It can be a bit of work to install factory fogs into their factory places using factory switches and wiring...but it usually involves finding the wiring block and plugging everything where it is supposed to go, which can be quite involved but possible.
If you are set on them, why not just get the OEM 'foglights' and wire them with an after-market harness?
factory fogs are designed up to 40 mph. anything faster and fogs off will be better, increases your field of view.
I would look at Hella/Optilux fogs, they have several designs.
