Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
21 registered members (edhackett, dishdude, Danno, Dylan1303, clinebarger, 2 invisible), 988 guests, and 38 spiders.
Topics295,007
Posts4,925,876
Members66,664
Most Online2,553
Oct 27th, 2018
Recommend me an OEM look foglight kit 2015 Cruze #4593838
12/04/17 10:52 AM
12/04/17 10:52 AM
Union County, PA
2James1 Offline OP
2James1  Offline OP
Union County, PA
Recently bought a 2015 Cruze 1LT. Please recommend me a high quality OEM look foglight kit. I was told that the car will not allow a switch from a car that came with foglights to be used...unfortunatly
2005 Chevrolet Malibu V6
Castrol Edge HM 10w-40/ Purolator Pureone
2015 Cruze LT 1.4T
Dealer Oil/Filter
Re: Recommend me an OEM look foglight kit 2015 Cruze [Re: 2James1] #4593906
12/04/17 12:19 PM
12/04/17 12:19 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
Aside from the cosmetic look, most "factory fog lights" don't actually contribute to better visibility.
http://www.danielsternlighting.com/tech/lights/fog_lamps/fog_lamps.html
I am not sure that you wee told correct information. It can be a bit of work to install factory fogs into their factory places using factory switches and wiring...but it usually involves finding the wiring block and plugging everything where it is supposed to go, which can be quite involved but possible.
If you are set on them, why not just get the OEM 'foglights' and wire them with an after-market harness?
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: Recommend me an OEM look foglight kit 2015 Cruze [Re: 2James1] #4594227
12/04/17 05:25 PM
12/04/17 05:25 PM
IL
Vern_in_IL Offline
Vern_in_IL  Offline
IL
factory fogs are designed up to 40 mph. anything faster and fogs off will be better, increases your field of view.
I would look at Hella/Optilux fogs, they have several designs.
