When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
98 registered members (2009Edge, 2whlgeezer, 2015_PSD, 53' Stude, 11 invisible), 2,121 guests, and 59 spiders.
Topics286,160
Posts4,903,317
Members67,569
Most Online2,967
Mar 10th, 2019
My First Oil Change On a Low Slung Car #4593820
12/04/17 11:26 AM
12/04/17 11:26 AM
New England
Virtus_Probi Offline OP
New England
I did the oil/filter for my daughter's '15 Impreza over the weekend and it was quite an eye opener for me.
I have only changed my Forester prior to this and it is pretty easy, I get plenty of clearance just by jacking up one side and then putting jack stands on both sides...hadn't touched my ramps in a while. I tried jacking up one side of the Impreza and didn't have nearly enough room to work, plus the other side didn't seem to come up that much and I wasn't very comfortable with how it looked (maybe my Forester is stiffer and the left/right stay more even?). I busted the ramps out and thought I could get it done then, but it was still quite tight and I was not able to operate my torque wrench very effectively as the drain plug sat at a pretty severe angle. I figured that I could get it off with a shorter wrench, but I really like to use a torque wrench for tightening the plug. To top it all off, I had assumed that the Impreza drain plug would be the same as mine and it wasn't, so I didn't have the right size of crush washer ready to go...I punted and decided to think about things before proceeding.
I was skiing the next day when it hit me that I had a darned oil extractor in the garage! I used it for the change later in the day with no issues.
The bad news is that the drain plug on the Impreza looked pretty bad when I checked to see if I had the right size of socket for it, rounded off somewhat and also gouged a bit. I'm not sure if I'm going to try to deal with that myself or let a dealer take care of it next time it's in for a major service.
Really didn't expect the little car to be such a hassle, guess I've been pretty fortunate with how easy it is to drop the plug on my car.
2014 Forester XT, 95000 miles
Last Change;
M1 0W30 AFE d1G2
Tokyo Roki 15208AA170 filter
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593829
12/04/17 11:35 AM
12/04/17 11:35 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Oh boy
Me: 13' VW GTI 3 door 6 speed manual
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593839
12/04/17 11:53 AM
12/04/17 11:53 AM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
I feel your pain, my Fiat is a challenge to get under too, and there's a belly pan with like 10 bolts that need to come off to access the drain plug. I drove one wheel up on a 2x6 and it gave me enough room to work but it was tight!
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593842
12/04/17 11:56 AM
12/04/17 11:56 AM
Marshfield , MA
andyd Online content
andyd  Online Content
Marshfield , MA
Considering it was the first go round on a new (to you).car. You handled the situation. Hooray for the oil extractor. Now you have an entire OCI to plan the next move. I'm glad I did a little research prior to changing the Camry's oil+ filter.
Thick oil is better grin2
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593851
12/04/17 12:09 PM
12/04/17 12:09 PM
Minnesota
JoelB Offline
JoelB  Offline
Minnesota
I will avoid jacking a car up at all costs. I can change both our household cars and my mother's dodge journey just by using my long arms. It certainly isn't the easiest way to do it but I'm paranoid about the jack or jackstands cracking or removing paint and exposing a spot for rust.
Mine: 2019 Chevy spark 1.4 Non-turbo
Factory Fill
Factory filter
Wife's: 2018 Chevy spark (Blue) 1.4 Non-turbo
Mobil 1 0w20 AFE
ACDelco UPF64R
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593855
12/04/17 12:13 PM
12/04/17 12:13 PM
NC
fenixguy Offline
fenixguy  Offline
NC
The most fun I had with a low car was a friend's 1990ish Nissan 300Z. They're already a low car and this one was lowered. Had to pull it on some 2x8s just to get a low profile jack under it.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593865
12/04/17 12:19 PM
12/04/17 12:19 PM
N.H, U.S.A.
ARCOgraphite Online content
ARCOgraphite  Online Content
N.H, U.S.A.
Some of the early FB engines came with very soft oil drain bolts that would round off if you used a box wrench - even expertly. I had a long thread with Al in forester dot org about it a while back. Made in china sub- component pan and bolt garbage IIRC.
I had to buy a new drain plug bolt from the dealer and they wouldn't even give it to me for free. The replacement bolt was fine.
Now: Was the '15 impreza head a 17 or a 14mm? Was ther a platic undertray with a small cutout for the DP?
At least the spin on FILTER was on top of the engine!
2019 VW Jetta S,6M OCI#0 1136mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593877
12/04/17 12:35 PM
12/04/17 12:35 PM
Danh Offline
Danh  Offline
I think the Impreza has a top-mounted oil filter. Why not combine this with an oil extractor (Mityvac, etc) and do the whole thing "topside"? You may not even have to change clothes!
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593888
12/04/17 12:52 PM
12/04/17 12:52 PM
Central NY
Miller88 Offline
Miller88  Offline
Central NY
I used to have to jack up the focus and get it on stands to do the oil change.
It's awfully geared transmission meant it couldn't climb ramps.
I am spoiled by the F-350 and cherokee.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593915
12/04/17 01:34 PM
12/04/17 01:34 PM
Columbus Nebraska
old1 Offline
old1  Offline
Columbus Nebraska
I hate jacking modern cars, and even my 65 mustang. So I built ramps unlike anything you buy. I made them from 2x12 and 3/4 inch plywood, all screwed together with long screws. It is 8 ft long and 12 inches high. EEEAsy to drive up on, and lots of room even for an old fat guy like me. And yes, it is STRONG. It will easily hold twice the weight of any car. If I could post pix here, I could show the construction. They are heavy, but I can drag them around, and stand them on end for storage.
2017 Nissan Frontier 4.0 5w30
1965 Mustang 200 c/4 10w30 QS defy
1964 Ford Ranchero 302 c/4 15/40 Delo
1929 ford model A No filters, and 15/40 oil
Re: My First Oil Change On a Low Slung Car [Re: ARCOgraphite] #4593925
12/04/17 01:46 PM
12/04/17 01:46 PM
New England
New England
The Impreza had a 17mm head and my Forester is 14mm. I suppose the dimensions of the threaded area might possibly be the same, but I doubt it because I bought a 17mm head plug for my car by accident a few years back and it looked like a totally different deal from my 14mm. There was an undertray with a small port for drain plug access and it was kind of in the way, but I didn't try to take it off because I decided it wasn't the root cause of my problems.
Yep, the filter on top made it such that I didn't really have to get under the car at all. I checked the air filter and I thought it would be a lot easier to crack open the Impreza's air box because there is so much more room around it than in my Forester, but it was still a PITA and a lot of wrestling to get back together. The filter looked nearly pristine.
Last Change;
M1 0W30 AFE d1G2
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593946
12/04/17 02:06 PM
12/04/17 02:06 PM
Canada
i_hate_autofraud Offline
Canada
"I did the oil/filter for my daughter's '15 Impreza over the weekend and it was quite an eye opener for me."
If it was tough for you, I'd worry how bad a dealer or lube shop would be! Techs are rushed to max and pushed
hard so they make mistakes at your expense!
As a DYI, you'll do a better job and own the results, dealers don't take responsibility at all!
The 'big-time' GM Chevrolet / Corvette dealer in my area screwed up my last under warranty work,
destroyed the oil plug! then replaced it! I wasn't even in for an oil change! What idiots! SAD!
Re: My First Oil Change On a Low Slung Car [Re: fenixguy] #4593981
12/04/17 02:35 PM
12/04/17 02:35 PM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Haha yep!! Z32's sit so low they're impossible to get under without ramps. And they sit too low to just drive them up on ramps. I have two pieces of wood,two bricks,and then the ramps. But oil changes are a piece of cake!! Everything is right there in plain sight. I can't do it in about 10 minutes.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum HM 10W30
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593994
12/04/17 02:42 PM
12/04/17 02:42 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Wow! You managed to make a simple oil change sound like a complicated engine replacement procedure. grin
Re: My First Oil Change On a Low Slung Car [Re: Virtus_Probi] #4593998
12/04/17 02:48 PM
12/04/17 02:48 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I would not be too concerned about using a tq wrench on the bolt. Just snug is fine for this.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
