Smart charges/time
by Duffyjr. 12/13/18 08:24 AM
7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
85 registered members (bfleeman, aquariuscsm, 4WD, aba4430, Bailes1992, 12 invisible), 1,749 guests, and 42 spiders.
Topics295,012
Posts4,925,993
Members66,664
Most Online2,553
Oct 27th, 2018
'07 Honda Odyssey - brake fluid capacity #4593669
12/04/17 05:48 AM
12/04/17 05:48 AM
Germany
GYGuy81 Offline OP
GYGuy81  Offline OP
Germany
Hi,
my 07' Odyssey shows Maintenance Minder A135 and I need to replace:
- Engine oil (going to use Castrol Magnatec 5W30 A5)
- Transmission fluid (using RAVENOL ATF Type Z1 Fluid)
- Engine Coolant (using RAVENOL HTC Hybrid Technology Coolant Protect MB 325.0)
- Brake Fluid (using RAVENOL DOT 4)
Except for the brake fluid, all capacity levels are specified in the Owners Manual.
Does anyone know the amount of brake fluid that needs to be replaced during service?
Regards,
Nils
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4593683
12/04/17 06:19 AM
12/04/17 06:19 AM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Because some will get lost in the flushing process, brake fluid capacities are not listed.
One liter will work unless your system needs a little more flushing due to being really dirty.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: '07 Honda Odyssey - brake fluid capacity [Re: skyactiv] #4593753
12/04/17 08:35 AM
12/04/17 08:35 AM
Germany
GYGuy81 Offline OP
GYGuy81  Offline OP
Germany
Okay, cool. Thx a lot for the reply. So I will order 2 Liter, just in case.... its just 6,99EUR / Liter, its not that expensive.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4593777
12/04/17 09:19 AM
12/04/17 09:19 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
I just did a flush of our '14 Odyssey. I'm sure the system is different, but given the size of the vehicle I imagine the brake line lengths are similar.
I used just under 36oz to do the flush, the other weekend.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4593874
12/04/17 11:31 AM
12/04/17 11:31 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Just FYI, when we do a flush at the dealer, we only use the factory 354 mL bottle. There is not that much fluid in a brake system.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4594066
12/04/17 02:30 PM
12/04/17 02:30 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
354 Ml sounds like a brake bleeding rather than a true flush where you replace ALL the old fluid. Ed
CX5 Touring 2.5L :-)
Re: '07 Honda Odyssey - brake fluid capacity [Re: Eddie] #4594187
12/04/17 04:24 PM
12/04/17 04:24 PM
Ontario, Canada
Ontario, Canada
There is not that much fluid in the system. If all the caliper pistons are pushed completely in, there is basically no fluid in the calipers. So the total system volume is what is in the reservoir and master cylinder. The 354 ml bottle is about the total volume. A few cars are a little more, most are less.
Mighty Mouse Tech
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4594241
12/04/17 05:36 PM
12/04/17 05:36 PM
California
nthach Offline
nthach  Offline
California
Get a 1L bottle, if you suck the reservoir clean to fill it up with fresh fluid and push fluid until clean through the master cylinder, ABS/ESP modulator and each wheel, expect to use nearly that whole liter.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4594636
12/05/17 06:20 AM
12/05/17 06:20 AM
Germany
GYGuy81 Offline OP
GYGuy81  Offline OP
Germany
There was a Service Bulletin from Honda (http://techinfo.honda.com/Rjanisis/pubs/SB/A10-069.PDF) mentioning that brake fluids from other vendors are bad and you should ONLY use the Genuine Honda DOT 3 Brake Fluid:
BACKGROUND
A cup seal in the master cylinder is sensitive to the type of brake fluid used in the brake system. If the brake fluid is replaced with anything other than Honda Genuine DOT 3 Brake Fluid, and the brakes are manually bled, the cup seal may twist in its retention groove and create a small leak. The brake fluid can then leak into the brake booster, and the brake system indicator will eventually come on because the brake fluid level is low. If the customer continues to drive the vehicle without refilling the brake fluid reservoir, he or she may notice the brake pedal feels low or spongy. The customer should not rely on refilling the brake fluid reservoir to address the problem. A prolonged leak would eventually cause one of the two brake system hydraulic circuits to fail.
Is that something to really worry about?
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4594646
12/05/17 06:36 AM
12/05/17 06:36 AM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I've heard that before, but Honda is clearly overcomplicating the matter. If ordinary DOT 3 isn't good enough, then they shouldn't call OEM Honda fluid DOT 3. That just creates confusion. It's DOT 3, or it's not, right?
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: '07 Honda Odyssey - brake fluid capacity [Re: Garak] #4594657
12/05/17 06:49 AM
12/05/17 06:49 AM
Germany
GYGuy81 Offline OP
GYGuy81  Offline OP
Germany
I assume that DOT3 is just a specification for the brake fluid ... so every brake fluid that supports that specification should be fine.
However you don't get DOT3 brake fluid in Germany. The best I can get is DOT4. This is what I bought: http://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-dot-4.html
Because of the special formulation of RAVENOL DOT 4 the international specifications SAE J1703, ISO 4925 and the safety regulations FMVSS 116 DOT3 and DOT4 from the United States of America are exceeded.
What I found in the internet that DOT4 has more aggressive ingredients and could damage rubber sealing. However DOT4 is fully backwards compatible to DOT3.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4595236
12/05/17 04:21 PM
12/05/17 04:21 PM
California
nthach Offline
nthach  Offline
California
DOT brake fluid specs are all published US DOT specs for fluids - but the formulations can be different from vendor to vendor.
Honda and Toyota source their production and service fill fluids from CCI. They meet DOT 3 specs but their fluid is closer to a DOT 4 since it does incorporate some borate esters for moisture resistance.
We don't know if that Honda recall is only for the North American Odyssey and not the international model. Honda does say DOT 3 and 4 can be used.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4595632
12/06/17 03:35 AM
12/06/17 03:35 AM
Garak Offline
Garak  Offline
One should think so. Speaking of DOT 4 being compatible with DOT 3 applications, the G37 calls for DOT 3, but the dealer only sells DOT 4, so it's like Germany. wink
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4595640
12/06/17 04:34 AM
12/06/17 04:34 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
It depends how thorough you are. A quart should be plenty to do all four wheels.
The "thinking" man's friend.
Re: '07 Honda Odyssey - brake fluid capacity [Re: GYGuy81] #4596612
12/06/17 09:34 PM
12/06/17 09:34 PM
Ottawa, Ont CANADA
2K2AcuraTL Offline
2K2AcuraTL  Offline
Ottawa, Ont CANADA
- Transmission fluid (using RAVENOL ATF Type Z1 Fluid)...
as well as the rear Diff DPSF fluid... no one offers a comparable product from OEM other than Ravenol..
When I was looking for a suitable [better] fluid from OEM.. I did find Ravenol on the web..
but its NOT available / distributed in Canada.. frown
I did find the Petro-Can Duradrive synth AFT right in my own back yard.. happy with it so far.
DPSF - no other option other than Acura dealer.
j.
02 Acura TL-P
13 Acura MDX-Elite
Both on PP and PP Ultra & Petro-Can Duradrive synth ATF
