Royal purple 75-140 in a subaru rear
by 91camarosRS
06/19/18 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
67 registered (91camarosRS, 1foxracing, 69Torino, advocate, adamrc, AndyB, 6 invisible), 1222 Guests and 39 Spiders online.
65265 Members
67 Forums
285582 Topics
#4593348 - 12/03/17 06:41 PM LG TV 47LN5750-UH Repair?
maverickfhs Offline
Loc: VA
So have a nice LG TV from 2014 and looks like LED strips are out, based on these symptoms: https://www.youtube.com/watch?v=T2FboV-1PJg and https://www.youtube.com/watch?v=YgaL6X6eSaU
Has anyone tried repairing it and is it worth doing it and dumping money into it?
Thanks for any help and advice thumbsup
2006 Civic EX 200K/AT
2006 Acura TSX 177K/AT
#4593408 - 12/03/17 07:37 PM Re: LG TV 47LN5750-UH Repair? [Re: maverickfhs]
danez_yoda Offline
Loc: texas
I repaired my 2008 Panasonic 58" plasma in 2012. Was P???ed that a $3000 TV died after 4 years.
Shop Jimmy had replacement boards at reasonable priced. Everything in the TV is modular so if
you follow the video and ground yourself to an electricians wrist strap you should be fine.
Be sure that you know the problem before you go blindly replacing parts. Also wiggle some connections to make sure they are not loose.
Since Shop Jimmy has a video on it, it must be a frequent failure.
Unfortunately if you fixit sellit and get new. the new TVs are way less expensive than the older ones were so they must have figured out
how to reduce the quality of the parts and still get passed the warranty period.
My 2008 is still going after the repair (it is the left side driver board) but I replaced the power supply as well since it was a common problem.
Works fine.
If you bring it in to get fixed at a repair place, this is all they will do. swap parts until it works.
#4593417 - 12/03/17 07:48 PM Re: LG TV 47LN5750-UH Repair? [Re: danez_yoda]
maverickfhs Offline
Loc: VA
Works fine.
Honestly, I won't take it anywhere. Troubleshoot and replace it on my own or just get rid of it!
Thanks for your advice.
#4593545 - 12/03/17 10:13 PM Re: LG TV 47LN5750-UH Repair? [Re: maverickfhs]
ZeeOSix Offline
Loc: PNW
Modern TVs are typically more to have repaired than a new one would cost, unless it's still under warranty, or can repair yourself. Same goes with a lot of appliances.
#4593765 - 12/04/17 09:03 AM Re: LG TV 47LN5750-UH Repair? [Re: maverickfhs]
WyrTwister Offline
Loc: Texas
I have heard a common failure is the capacitors in the power supply . That is probably not the problem with the OP's TV .
Wyr
God bless
#4593766 - 12/04/17 09:06 AM Re: LG TV 47LN5750-UH Repair? [Re: maverickfhs]
maverickfhs Offline
Loc: VA
Yeah, it's definitely LED.
#4617958 - 12/29/17 04:52 PM Re: LG TV 47LN5750-UH Repair? [Re: maverickfhs]
maverickfhs Offline
Loc: VA
After all I was able to fix it and it's running like a champ smile
