Brakes not working - brake pedal sinks
by tookien
49 minutes 1 second ago
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
Walmart Tightening up Returns
by John_K
Yesterday at 10:21 PM
flare nut wrench set
by spasm3
Yesterday at 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
Yesterday at 09:45 PM
How much is too much?
by Sealbilly
Yesterday at 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
Yesterday at 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
Yesterday at 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
Yesterday at 08:33 PM
PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
Yesterday at 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
Yesterday at 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
Yesterday at 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
Yesterday at 06:13 PM
2011 Chevy equinox overheating
by hardcore302
Yesterday at 06:00 PM
Are my rotors warped?
by Dylan1303
Yesterday at 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
Yesterday at 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
Yesterday at 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
Yesterday at 04:38 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
32 registered (1WildPig, ctechbob, Backwoods41695, clinebarger, David2431, 2015_PSD), 887 Guests and 46 Spiders online.
65265 Members
67 Forums
285573 Topics
#4593117 - 12/03/17 02:40 PM Replacing fluid by weight
RichardS Offline
Loc: Melbourne, Florida
The caliber is coming up on 120,000, and it's time to replace the CVT fluid.
The process, as most of you know, is a little absurd with special dip sticks, temperature charts, and some voodoo. The local dodge dealer (with their impressive 1.5 star service dept rating) wants $334 plus tax to replace the 13 quarts of CVT+4 fluid.
This might seem a little stupid, but couldn't I vacuum pump out the old fluid, and replace it with the equivalent weight of new fluid?
Would that eliminate the volume discrepancies from different temperature fluids, or is the possibility of wear material being significant enough to throw off the addition of the correct amount of new fluid?
2008 Dodge Caliber SE 2.0 117k
4qt Imeditsu 0w-20, 1/2qt Mobil SS 5w-20 Fram HM
2003 Buick Century 107k
4.5q Havoline 5w-30 HM Fram XG
#4593118 - 12/03/17 02:45 PM Re: Replacing fluid by weight [Re: RichardS]
SatinSilver Offline
Loc: OH
You could draw out the atf and measure what comes out and replace that amount. Just do it cold.
Where all the complexity comes in is when a car arrives hot/warm at the dealer/service facility. The hot/warm fluid that comes out has to match the temperature of the new fluid going in. Which can be tricky.
#4593121 - 12/03/17 02:47 PM Re: Replacing fluid by weight [Re: RichardS]
JC1 Offline
Loc: Oshawa, Ontario Canada
I don't see why not. I checked youtube, but there aren't any great detailed videos for the Caliber CVT tranny fluid change.
https://www.youtube.com/watch?v=ZY7ZM4C8o1A
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4593138 - 12/03/17 03:04 PM Re: Replacing fluid by weight [Re: RichardS]
doitmyself Offline
Loc: MI
You can check out videos and sites for the Jeep Compass and Patriot also. They share the same drive train.
#4593171 - 12/03/17 03:48 PM Re: Replacing fluid by weight [Re: RichardS]
RichardS Offline
It's pretty direct, the changing part.
You take off the pan, and drain it out. I believe the TC drains at the same time, as you replace roughly 13 quarts.
the last time I looked, admittedly a while ago, the dipstick for the fill tube was like $90 bucks, add that to the unnecessarily expensive MOPAR CVTF+4, and I'm not saving enough to make the personal labor worth it
#4593321 - 12/03/17 06:19 PM Re: Replacing fluid by weight [Re: RichardS]
JC1 Offline
Can't you get an aftermarket ATF dipstick from Dorman for much cheaper?
#4593329 - 12/03/17 06:24 PM Re: Replacing fluid by weight [Re: RichardS]
Kestas Offline
Loc: The Motor City
I've done changes by measuring the volume of fluid that is drained. But you have to account for clingage losses.
All the better if you can do it by weight.
#4593340 - 12/03/17 06:31 PM Re: Replacing fluid by weight [Re: RichardS]
Wolf359 Offline
Loc: MA
Isn't there also a filter and a magnet that won't get changed/cleaned out if you just suck out the old fluid?
#4593566 - 12/03/17 10:42 PM Re: Replacing fluid by weight [Re: RichardS]
RichardS Offline
JC1,
Yes, there are aftermarket sticks, and a quick glance found one for $30. But that seems a silly price tag for something I'll use one time if there is a potential, equally effective, and cheaper method.
Kestas,
That's why I was think about weighing it. I'd have to account for the fluid stuck in the extractor, but I'd imagine that wouldn't be more than 3-5 ounces. I figured a gram scale weight of the tubing before and after would give me a close enough estimate of fluid to replace when adding the new oil in.
Wolf359,
I'm not sure, honestly. I can find filter part numbers, but both a cartridge and in-sump version that come up. I'm fairly sure it isn't a cartridge, so there may be one in the pan. But JATCO doesn't even recommend servicing the fluid in a privately owned vehicle, so I'm sure filters are treated with the same "life time" interval. I'd be plenty happy with just a fluid swap via whatever I can suction out.
#4593569 - 12/03/17 10:50 PM Re: Replacing fluid by weight [Re: RichardS]
Nick1994 Offline
Loc: Phoenix, AZ
I think people sometimes use the engine oil dipstick to check the level. Mark your current level on your oil dipstick after inserting into the transmission. Or use a ruler and measure the distance from the bottom.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4593637 - 12/04/17 04:06 AM Re: Replacing fluid by weight [Re: RichardS]
greasegunn Offline
Loc: NY
This is how I do it on my daughters Mazda 6. For this procedure to work correctly, you have to be at the appropriate fluid level when you do the drain. I use a scale from Harbor Freight.
#4593830 - 12/04/17 10:36 AM Re: Replacing fluid by weight [Re: RichardS]
Whimsey Offline
Loc: The Garden State
Or another option is take what you can remove cold with suction and put into a bucket that has measurements in it. Then just put back the same amount with new cold fluid. I did this with our 2017 Explorer and it worked out well. The Explorer does not have a pan, just a drain plug and a fill hole without a dipstick, hence the need to measure what drains out cold to refill the same amount cold. If you do a pan drop you'll likely spill/lose enough fluid to not get an accurate volume measurement.
Whimsey
#4594487 - 12/04/17 10:02 PM Re: Replacing fluid by weight [Re: RichardS]
Wolf359 Offline
Loc: MA
JC1,
Kestas,
Wolf359,
I don't know about your particular make, but Mercedes did the same thing with their transmissions. First they claimed it was a lifetime fluid, then later they backtracked and said that it should be changed every 40k. Even their new models still call for fluid changes. So I'm not sure I'd believe in anything that really says the fluid is lifetime. They always had a filter available even when it was lifetime and they even make you replace the bolts when dropping the pan as they're one time use bolts. At least there's only 6 of them and they don't cost that much.
