Hello and goodbye to my old job
by Motorking. 03/22/19 01:52 PM
Ichiro Suzuki retiring from baseball.
by PimTac. 03/22/19 12:40 PM
91 Caprice door wont fully latch...
by columnshift. 03/22/19 12:30 PM
Denso Platinum TT for 2004 Corolla?
by zorobabel. 03/22/19 11:16 AM
What should I run in the 09 rabbit trans
by ram_man. 03/22/19 10:32 AM
Chevy express van for towing
by Fitter30. 03/22/19 10:24 AM
Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
113 registered members (2015_PSD, aquariuscsm, 77GrandPrix, Audios, Alfred_B, Astro_Guy, 9 invisible), 2,077 guests, and 60 spiders.
Topics286,237
Posts4,904,952
Members67,582
Most Online2,967
Mar 10th, 2019
7.3 Powerstroke Racor fuel filter #4592967
12/03/17 12:27 PM
12/03/17 12:27 PM
Golden Meadow, LA
mobilaltima Offline OP
Golden Meadow, LA
After doing a bit of reading and talking to friends who have done the same, I've decided to install a Racor pre-pump fuel filter on my 99 Ford. While it has gone 231k miles with nothing more than the factory valley mounted fuel filter, I figured a little more protection cant hurt. I plan on keeping it until the frame gets to the point where its not structurally sound (I had mentioned before it was quite rusty in two areas, I plan on coating the rust in either fluid film or used diesel oil as needed). There is a kit made by Racor specifically for the 7.3, with either a 2, 10, or 30 micron filter, and then theres a kit made for gas outboards that is recommended by the guy who owns PowerstrokeHelp(many videos on youtube powerstrokehelp.com). I'm undecided on which one I should run.
http://www.parker.com/parkerimages/Racor/7570%20(7.3L%20Powerstroke%20Products%20-%2007-08-2005).pdf
this is the one made by racor for the 7.3, its under primary fuel filter mounting kit
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4592968
12/03/17 12:29 PM
12/03/17 12:29 PM
Golden Meadow, LA
Golden Meadow, LA
http://racorstore.com/racor-320r-rac-01-filter-w-head-gas-clear-bowl.html
this is the one recommended by the guy at powerstrokehelp. its a gas filter but i dont see any reason diesel cant be filtered through it.
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4592979
12/03/17 12:40 PM
12/03/17 12:40 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Id want one rated for diesel in case the materials differ.
Your racor size rating should be based upon the rating of your subsequent filters. Are you removing the OE primary to install this?
Typically you would sequence to reduce the load on the downstream filters.
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4592988
12/03/17 01:01 PM
12/03/17 01:01 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Some of the farmers out here use toilet paper for gasoline, diesel fuel, and oil for operating in dusty conditions out in the fields. They do take time to engineer the installations for proper flow and easy servicing with plumbing that does not leak and claim that nothing gets through the toilet paper. The media is cheap enough to encourage frequent changes.
One farmer said he does not admit to using toilet paper because he keeps hearing how the paper will dissolve and destroy the fuel or oil system.
These self-proclaimed experts don't realize how good these farmers are at maintaining their equipment. They fix things themselves and keep the machinery running.
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4741154
04/28/18 03:03 AM
04/28/18 03:03 AM
Kansas
jacobs Offline
jacobs  Offline
Kansas
The original Racor fuel filter manufactured by Rogers Filtration Systems back in the late 1960's used a roll of paper towels for an element but later changed to a pleated paper element for “repeat business”.
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4742568
04/29/18 04:41 PM
04/29/18 04:41 PM
Sask, Canada
BrianF Offline
BrianF  Offline
Sask, Canada
If you cant find what you are looking for from Racor at a decent price, cross reference to Baldwin/Hastings as they are all owned by the parent company Hannifin. I found that the rear filter/water separator on my Ram Cummins was made by Racor but costly. I found (verified by Hannifin) that the Racor filter was just painted and labeled different to be called Baldwin or Hastings.
2006 Trailblazer LT. QSUD with Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30 with Hastings LF608.
1993 GMC 1500. QSAD with Fram PH5
Re: 7.3 Powerstroke Racor fuel filter [Re: mobilaltima] #4777186
06/04/18 12:15 PM
06/04/18 12:15 PM
South
WMW0505 Offline
WMW0505  Offline
South
You've probably already installed your filter (s) but if you haven't, consider the kit available from Strictly Diesel. It's a kit to do the "hutch mod" but incorporates a frame mounted pre pump filter. If you're looking for only filtration, consider a post pump filter that guys use when installing a regulated return (fuel bowl delete). You don't have to delete your fuel bowl to add a post pump filter. Strictly diesel kit below:
www.strictlydiesel.com/p-2662-driven-diesel-fuel-tank-pre-pump-kit-hutch-mod.aspx
