Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
95 registered members (69Torino, 94astro, ABomb369, ad244, 14 invisible), 1,750 guests, and 42 spiders.
Topics290,714
Posts4,848,926
Members66,021
Most Online3,590
Jan 24th, 2017
What Viscosity? #4592618
12/03/17 03:08 AM
12/03/17 03:08 AM
South Wales, UK
Bailes1992 Offline OP
South Wales, UK
Completely over thinking this, but I'm good at over thinking!
Wife is expecting so we changed her little 2013 Polo for a 2016 Dacia Duster with a Renault/Nissan 1.5DCi engine. My Wife drives cars quite hard however only does short journeys. She drives around 5-10miles a day on average which doesn't give the engine time to heat up properly or give the emissions equipment time to do what it needs. When the baby is here it will be doing more mileage but still not the right mileage for a diesel. I wouldn't have purchased a diesel however we had settled on the Duster and I couldn't find a petrol example with four wheel drive and I don't see the point in a 2WD 'SUV'.
I try to ensure once every 2-3 weeks I take it for a run up the motorway to ensure the DPF can regen and to get the oil temperature nice and high to burn off any water. I also only use BP Ultimate or Shell V-Power diesel in it. I'm hoping these two measures are enough to keep it clean and running top for the next 4 or 5 years.
The car asks for an ACEA C3 oil in any viscosity. When I picked up the car a few weeks ago I changed the oil and filled it up with Shell Helix Professional 5w30 Dexos2 ACEA C3 and fitted a genuine Renault filter.
Here in the UK, ambient temperatures bottom out about -10°c (14°F) with a maximum of around 30°c (86°F).
Having had lots of UOA done on my previous cars and seeing significant reductions in wear materials running a 40 weight over a 30 weight I'm keen to use a *w40 of which there's many options. I'm most interested in Castrol Edge 5w40 or Mobil1 0w40 ESP. These oils meet ACEA C3, BMW LL04, VW502/505 among others.
I'm sure the above oils will look after the engine perfectly fine for many years to come. However, if I run a 5w30 oil I can have an oil that meets VW504/507 which is a brilliant specification to have. It would probably be either Castrol Edge 5w30 or Mobil1 ESP 5w30.
So, if you were in my situation would you run a *w30 and gain 504/507 or loose 504/507 and run the thicker oil?
'13 Suzuki Jimmny - '16 Dacia Duster 1.5DCi 4WD
'96 LR Defender 300TDi - '12 BMW 320d
Engine Oil - Fuchs Titan XTL GT1 5w40
Gearbox Oil - Fuchs Sintofluid 75w80
Diff Oil - Fuchs Sintopoid 75w90
Re: What Viscosity? [Re: Bailes1992] #4592619
12/03/17 03:20 AM
12/03/17 03:20 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
Judging by your use, short trips mainly, maybe a thinner oil? But you will probably get some fuel in the oil, so...
Another option, 5W30 C4 oil grin
(Also you can use Purflux filters, if you can get cheaper than the Purflux made Renault)
96 Barchetta, Motul 300V 5W40 | 98 Barchetta, Quartz 9000 energy 5W40
05 Forfour 95, SHU 0W40 (gf's car) | 10 Colt Ralliart, 300V 0W40
Re: What Viscosity? [Re: Popsy] #4592629
12/03/17 04:33 AM
12/03/17 04:33 AM
South Wales, UK
South Wales, UK
I will definatley look for cheaper filter options. Genuine Renault filter are £15/each! I was looking at some bypass filter options to add some extra capacity to the system. Just replace the bypass filter every 2nd OCI.
I'd prefer not to go for a lower SAPS oil, mid SAPS is bad enough. If it wasn't for the DPF I'd be running an A3/B4 oil!
Re: What Viscosity? [Re: Bailes1992] #4592636
12/03/17 05:01 AM
12/03/17 05:01 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
My choice would be Mobil 1 0w40 ESP, for the marginally better cold start performance? Definitely wait for other advice.
As for filter, Purflux or Renault, both made in France (with the zigzag pleats), unless you go oversize, which shouldn’t be too difficult to do, if you have the place. What is the ref of the filter (LS something ?)?
On the other hand, these engines will run for a long time, even with factory OCI and neglectful owners smile
Re: What Viscosity? [Re: Popsy] #4592639
12/03/17 05:28 AM
12/03/17 05:28 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
You need 0W at -10C ???
That's 20-30C off the limits of pumpability for either grade...
Re: What Viscosity? [Re: Bailes1992] #4592640
12/03/17 05:32 AM
12/03/17 05:32 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Cant get full link...
https://www.euroton.si/en-us/avtodeli/shoppingcart.aspx
Mann w79 filter
Oil.....anything in xW40 with a low saps specs...
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: What Viscosity? [Re: Shannow] #4592642
12/03/17 05:35 AM
12/03/17 05:35 AM
South Wales, UK
South Wales, UK
Not at all but ACEA C3 oils are only available in 0w and 5w grades. The climate in the UK a 15w would suffice, a 10w is overkill.
If I didn't have a warranty and the car didn't burn oil (not that it does) I'd probably look at a 10w30 or 15w40 mineral or semi synth HDEO with a SAPS of 1% or less.
Re: What Viscosity? [Re: Bailes1992] #4592646
12/03/17 05:39 AM
12/03/17 05:39 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Dont complicate... There are many 5w40 oils with C3 spec (repsol...castrol...shell...)
Re: What Viscosity? [Re: Bailes1992] #4592649
12/03/17 05:56 AM
12/03/17 05:56 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
No, I was responding to the 0W40 for "better cold start"
I'm hearing you...
Re: What Viscosity? [Re: Bailes1992] #4592661
12/03/17 06:45 AM
12/03/17 06:45 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
I should have explained myself better (rough Sunday morning, as it seems), not better cold start, but more like more smoothness and fuel economy, considering the mostly short trip use. Although 5w vs 0w won’t make much of a difference.
Of course not, come on...
But it doesn’t mean my diesel doesn’t start noticeably smoother at -10º with 5W40 vs 15W40. If I had mostly short trips, I’ll surely pick the thinnest thing, cost factor not considered of course, and probably durability and wear also.
Re: What Viscosity? [Re: Popsy] #4592666
12/03/17 06:55 AM
12/03/17 06:55 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Given the two mobil ECT offerings mentioned...check the data sheet...there's going to be zero difference, before you even TRY to measure it.
Re: What Viscosity? [Re: Bailes1992] #4592669
12/03/17 06:58 AM
12/03/17 06:58 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
That’s why I used « marginally », put a quest Mark, and add to wait for other advice. Wasn’t feeling like looking at pdf on this very Sunday morning, guess I should have restrained myself from posting, haha smile
Re: What Viscosity? [Re: Bailes1992] #4592681
12/03/17 07:38 AM
12/03/17 07:38 AM
South Wales, UK
South Wales, UK
Castrol Edge 0w30 ACEA C3 appears to be a 'full PAO' synthetic looking at the German label. Can't find any HTHS information though.
All the oils I'm looking at are all around the same price range.
Re: What Viscosity? [Re: Bailes1992] #4592894
12/03/17 11:05 AM
12/03/17 11:05 AM
AZ
ron17571 Offline
ron17571  Offline
AZ
Don't overthink it all. Look at your manual if all else fails.Most of the oils you listed are fine.Don't skimp on good filters.
2003 Dodge Caravan 140.000 miles
1992 Ford f-250 217,000 miles
Re: What Viscosity? [Re: Bailes1992] #4593110
12/03/17 03:32 PM
12/03/17 03:32 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Just click all the data fields.....Dacia/Duster/2016/1.5dCi 4x4.....
https://www.opieoils.co.uk/c-2354-lookup-results.aspx?vehicleid=26419&variantlist=99086:0,98561:0,98655:0,170502:0,167700:0,263086:0,198069:0&yearFilter=2016
