Mobil 1 Filter Clearance - Wal Mart
by sdude2k2000. 03/22/19 10:01 AM
STP VI trans fluid
by acme. 03/22/19 09:37 AM
Increased oil capacity = lower pil temps ?
by SavagePatch. 03/22/19 09:15 AM
2007 Corolla - P0441 and P0455 codes
by Bama. 03/22/19 08:44 AM
Oldmoparguy1
by cjcride. 03/22/19 08:23 AM
Check engine light
by rtrdad. 03/22/19 08:21 AM
Super Tech 5W30 Synthetic With GDI Engine ?
by ChrisD46. 03/22/19 07:00 AM
Venol A.M.G brand
by headoff93. 03/22/19 05:51 AM
Anyone use this oil?
by lawnguy. 03/22/19 05:47 AM
Amalie Elixir Full Synthetic ?
by lawnguy. 03/22/19 02:23 AM
All 2's tomorrow or Saturday
by Marco620. 03/22/19 01:28 AM
Mobil 1 0W-16
by The Critic. 03/22/19 01:06 AM
2007 Escape - TCC solenoid?
by Burks21. 03/21/19 11:52 PM
Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Anton93, FrancescoO, russrie, scottjeffrey, Mowata
67582 Registered Users
103 registered members (b1amgm47, ARCOgraphite, Ag76, Altima2, AZjeff, acme, 12 invisible), 1,951 guests, and 61 spiders.
Topics286,231
Posts4,904,742
Members67,582
Most Online2,967
Mar 10th, 2019
Help....2 cycle oil, Marine 2 stroke oil, ....??? #4592278
12/02/17 06:39 PM
12/02/17 06:39 PM
ohio
fins Offline OP
fins  Offline OP
ohio
I thought 2 stroke oil was two stroke oil..............but I read about 2 stroke, 2 cycle, motorcycle 2 stroke oil, Marine 2 stroke oil, 2 cycle chain saw etc, etc....
I have been using Pennzoil Marine semi-synthetic in all my 2 stroke motors.......Outboard motor, chain saw, Lawnboy mower, weed wacker, snow blower.
What is the difference in the oils ? Am I harming one of the above engines ??
Re: Help....2 cycle oil, Marine 2 stroke oil, ....??? [Re: fins] #4592382
12/02/17 08:40 PM
12/02/17 08:40 PM
Wishin' I was in Wi
mjk Offline
mjk  Offline
Wishin' I was in Wi
I thought part of it has to do with the designed temperature the engine runs at.
Re: Help....2 cycle oil, Marine 2 stroke oil, ....??? [Re: fins] #4592387
12/02/17 08:48 PM
12/02/17 08:48 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Hey fins, I have lots of 2 cycle outdoor power equipment experience (chainsaws, trimmers, blowers,etc.) but no experience with marine 2 cycle oil. This is a learning experience for me also. This following lengthy post is pretty educational: https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2714912
Keeping things simple, there seems to be a minimum of at least three different types of 2 cycle oil: water cooled only, air cooled only, and multipurpose that claim to cover both water and air cooled.
Water Cooled: Marine engines run cool and require an ashless additive package to avoid fouling.
Air Cooled: Outdoor power equipment runs hotter and at higher RPM's, requiring a low ash additive package to meet their needs.
Multi-Purpose 2cycle: The type claims to meet the requirements of both water and air cooled engines. Our resident expert Molakule stated in one post that they can do this by using advanced synthetic base oil stock.
I checked out the Pennzoil site and it seems that your oil is not the dual rated multi-use type. It probably is not the best product for your outdoor power equipment air cooled engines, something that may not affect you IF you rarely use your equipment or don't work it under hard conditions. Personally, I would choose a different oil for air cooled 2 cycle engines.
http://www.pennzoil.com/en_us/products/o...2NhbGU9ZW5fdXM=
Others will chime in and offer much more help. Very high performance 2 cycle engines seem to have even different needs??
Re: Help....2 cycle oil, Marine 2 stroke oil, ....??? [Re: fins] #4592522
12/02/17 11:19 PM
12/02/17 11:19 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
There is more to it than that - you left out the motorcycle 2-stroke race crowd that runs modestly big CC cylinders at outrageous power levels with extreme prejudice laugh
Chain Saw Race motors are about the same, but don't run 45 minute moto's, or 8 hours of desert racing ... However, they do turn 11 to 14,000 RPM laugh
Turns out that the oils that will work well there, will do well in most places/motors. Motul 710 and above are very good for most 2-stroke scenarios. JASO FC or FD (ISO-EGD) is a good spec to start with smile
But, outboards are a breed apart. TC-W3 for them. Mercury Premium Performance outboard oil is very good for many motors. Some require their own special lube ...
Rule #1 - some oil is better than no oil ... In a pinch, most will run a while on any 2-stroke oil. But peak power will not happen on less than the best.
Re: Help....2 cycle oil, Marine 2 stroke oil, ....??? [Re: fins] #4592643
12/03/17 05:36 AM
12/03/17 05:36 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Help....2 cycle oil, Marine 2 stroke oil, ....??? [Re: fins] #4593182
12/03/17 05:10 PM
12/03/17 05:10 PM
Cave City KY
jakewells Offline
jakewells  Offline
Cave City KY
you can use multi purpose oil in your 2 cycle but i do not recommend pennzoil because of carbon build up. valvoline multi purpose burns cleaner imo.
1994 Ford F150 302 4R70
Chevron Delo SAE 30 CF/SL Fram XG8A
1978 Chevy Nova 250 I6 Borg Warner T5
Rotella 10W40 Fram XG5
