Clear plastic scratch remover?
by Quattro Pete
11 minutes 3 seconds ago
Parking wars show.
by Chris142
11 minutes 12 seconds ago
set for years
by 93cruiser
19 minutes 3 seconds ago
Looking to replace 2005 Sienna with SUV
by i6pwr
Today at 07:26 PM
Trying to fix chainsaw
by turtlevette
Today at 06:48 PM
tire rotation
by marine65
Today at 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
Today at 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
Today at 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
Today at 06:00 PM
New belt squeal cause damage to belt?
by pda1122
Today at 05:33 PM
Food Safety - If You Have Children
by Zee09
Today at 05:15 PM
Reduce TORQUE to COMPENSATE for lubed threads?
by SumpChump
Today at 05:02 PM
Chain cleaning and lube
by dadinfo
Today at 04:57 PM
Mobil Delvac 1 ESP 5w40 $23.65 at Walmart
by 71Chevyguy
Today at 04:36 PM
diesel oil in older engines- RE: cats etc
by 928
Today at 04:35 PM
2011 F-150 Ecoboost timing chain replacement
by 14Accent
Today at 04:31 PM
My stash of Kendall GT1 almost gone..
by Vern_in_IL
Today at 04:30 PM
mobil 1 rebate check
by Fitter30
Today at 03:52 PM
Cab mount failure
by ram_man
Today at 03:31 PM
02 Saab aero oil?
by Newuser
Today at 03:00 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
99 registered (AZjeff, bdcardinal, 93cruiser, aquariuscsm, 69Torino, Astro14, 9 invisible), 1483 Guests and 61 Spiders online.
65303 Members
67 Forums
285878 Topics
#4591895 - 12/02/17 09:49 AM 2 YEARS ok on FILTER in a stored vehicle?
SumpChump Offline
Loc: Upper Midwest by the Lakes USA
Still recovering from back work...
So mightyvac oil chage is the best I can do on my 5.7L 2005 Hemi Ram.
The Bosch filter has been on a calendar year (cold upper midwest damp winters hot summers). Stored safe and "dry" indoors non climate controlled storage unit.
.Vehicle has seen 500miles at most over that time.
Would leaving it in be ok for storage till springtime? The filter that is.
#4591903 - 12/02/17 10:01 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
maxdustington Offline
Loc: Toronna
If you are healing and the best you can do is an oil extraction OCI, the you don't really have a choice do you? You could take it somewhere but they are just going to screw it up. I would argue that the risk is minimal and you can just swap it when you are done convalescing if you are losing sleep. If you can somehow crawl under or coax someone else to inspect for rust on the filter that would be perfect.
I would also argue that you should change the oil and filter immediately as it is the BITOG way. What happens if you have to move it for some reason, the ABDV in the filter has failed and you get a start up rattle do to low oil pressure at start up? Why I never! *faints*
Edited by maxdustington (12/02/17 10:01 AM)
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
#4591910 - 12/02/17 10:11 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
Bluestream Offline
Loc: Waterloo, ON
Motor oil changes are usually scheduled based on the time in service or the distance that the vehicle has traveled. These are rough indications of the real factors that control when an oil change is appropriate, which include how long the oil has been run at elevated temperatures, how many heating cycles the engine has been through, and how hard the engine has worked. The vehicle distance is intended to estimate the time at high temperature, while the time in service is supposed to correlate with the number of vehicle trips and capture the number of heating cycles. Oil does not degrade significantly just sitting in a cold engine. On the other hand, if a car is driven just for very short distances, the oil is not allowed to fully heat-up, and contaminants such as water accumulates in the oil, due to lack of sufficient heat to boil off the water. Oil of this nature, just sitting in an engine, can cause problems.
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#4591913 - 12/02/17 10:12 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
sir1900 Online   happy
Loc: Regina, Saskatchewan
Yes, it would be just fine.
2015 Infiniti Q50
VAS 5W-30 + FRAM PH6607
2015 Nissan Murano
Mobil1 AFE 0W-20 + FRAM XG6607
#4591922 - 12/02/17 10:19 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
NormanBuntz Online   content
Loc: Outer Banks, NC
Absolutely it's good for another year with only 500 miles of use. I store my Alfa for 7 months a year, driving it about 300 miles a year in Florida. I keep my Donaldson or Bosch standard oil filter on for three years without a concern.
2017 Honda Odyssey SE, 14K
2013 Honda Accord LX, 58K
2007 Honda Ridgeline RTS, 86K
2007 Infiniti M35, 104K
#4591926 - 12/02/17 10:25 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
BrocLuno Offline
Loc: Kalifornia Kollective
Standard fleet recommendation by State of Cali fleet management (after long thorough study) was change filter every other time, unless engine has problems like significant fuel dilution, etc. You have no significant anything. Why even change the oil?
I have let oil be in trucks seldom run for up to five years. Filter every other. So I'm sure yours is fine smile
#4592049 - 12/02/17 12:51 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
Ihatetochangeoil Offline
Loc: On the road Midwest
^^^ +1 Maybe reading this will help you...5 year old oil with low miles...Good UOA with no concerns...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4190879/1992_Surburban_Big_Block_-_M1_
If I were you, I'd relax & recover, and don't lose any sleep over this. I agree with BrocLuno.
2003 Lesabre
2004 Lesabre
2004 Impala
If ur NOT doing UOA then you're throwing away good oil or your engine is already damaged. Choose.
#4592086 - 12/02/17 01:27 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: Bluestream]
Merkava_4 Offline
Loc: Clovis, CA
5000 miles or one year ?
#4592117 - 12/02/17 02:07 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
bugeye Offline
Loc: Pennsylvania
No worries. I go two to three years on oil/filter on seldom run vehicles. Typically less than 3000 miles on synthetic oil.
#4592158 - 12/02/17 02:51 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
JHZR2 Offline
Loc: New Jersey
2 years in a vehicle is not abnormal. My Saab was rated for that back in 2004, and filters have lasted for that ong on vehicles long before any OEM approved it. Honda on our 94 integra rated their filters for 2x7500mi OCI. Given average use of say, 10-12k, the folks below the average were guaranteed to an early two year oci. Nothing new or abnormal here.
#4592173 - 12/02/17 03:08 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: JHZR2]
SatinSilver Offline
Loc: OH
Almost bought a new one back in the day but went with a 1994 Civic coupe instead. Looking I back I probably should bought the Acura since it seemed much nicer. Plus I was into manuals back then. Insurance was quite a bit more as well since I was under 25 at the time.
#4592221 - 12/02/17 04:15 PM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
rooflessVW Online   content
Loc: North Carolina
The oil is fine, and the filter is fine.
"Zed's dead baby, Zed's dead."
#4592853 - 12/03/17 09:31 AM Re: 2 YEARS ok on FILTER in a stored vehicle? [Re: SumpChump]
Patman Offline
Loc: Oakville, Ontario
I have done two year oil changes on my Corvette since I bought it in 2013 and I also did two year oil changes on my mom's VW Golf as well. Same filter kept on both of those cars for those two years, no problems at all (I did UOAs for both cars as well)
2018 Corvette (M1 5w30 ESP & Fram Ultra)
2006 Civic EX Coupe (PUP 5w20 & Fram Ultra)
2010 BMW 328i X-Drive (GC 0w40 & Mann)
