Valvoline 2 Cycle TC-W3 Marine Oil - 6qt - $20
by Jimzz
06/25/18 10:45 AM
Plumbing/Bldg Experts: Cause of Wet Slab?
by LoneRanger
06/25/18 10:13 AM
How to CONFIRM the Country of Manufacture
by Ed_Flecko
06/25/18 09:58 AM
Replacing trans oil seal
by redhat
06/25/18 09:50 AM
VW diesels sitting in huge lots waiting......
by ZZman
06/25/18 09:09 AM
DTD/DT Independence Day Promos
by Sayjac
06/25/18 08:39 AM
It's AMSOIL®, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
94 registered (853okg, 2015_PSD, ALR, 1JZ_E46, 2012AccentSE, 5 invisible), 1632 Guests and 52 Spiders online.
65319 Members
67 Forums
285965 Topics
Page 1 of 2 1 2 >
#4591846 - 12/02/17 08:56 AM Ford Power Transfer Unit issues
Toros Offline
Loc: Chadds Ford
Bought a 2009 Lincoln MKX in early July. 55K on it in excellent condition. Got it from a Ford Lincoln dealership. Everything fine for 12k miles until I smelled a strange burnt fluid odor after I stopped driving. Took a look underneath and there it was. PTU fluid weeping from the right side PTU ...known issue. Got a great mechanic who was familiar and had done them with the Ford specific seal kit. So $300 later it's fixed and flushed and filled with new 75-140 synthetic fluid. Along with a transmission drain and fill and coolant flush and fill it's definitely quieter and smoother like McConaghey says a Lincoln should be.😀
There is no drain plug only a fill plug. Considering having them drill and tap the PTU or not and just let them suck/pump the fluid every 25k and refill. Thoughts?
Edited by Toros (12/02/17 08:59 AM)
#4591856 - 12/02/17 09:04 AM Re: Ford Power Transfer Unit issues [Re: Toros]
4WD Offline
Loc: Texas
Not sure if there is room for a nipple style Fumoto valve … but always figured you could drain and bottom fill like a lower unit on an outboard …
#4591905 - 12/02/17 10:05 AM Re: Ford Power Transfer Unit issues [Re: 4WD]
Whimsey Online   content
Loc: The Garden State
Actually the early PTU's did not have a drain plug because they were considered a "lifetime" fill, a very short lifetime with the factory fill in many cases. If you wanted to change the fluid, which is synthetic 75W-140 gear oil, you had to suck it out of the nearly impossible to reach fill plug. Unfortunately many of the PTU's turned the gear oil into solid "tar" long before 100,000 miles. Newer model years received a larger gear oil capacity, ~24 oz vs ~17 oz, PTU with a drain plug and some have water jacket cooling I heard to help with the fluid life. Although I think they now call for 150,000 mile gear oil change. Though chances of it making 150,000 miles on the factory fill are slim. As mentioned there is a worthwhile modification of adding a drain plug if you plan on doing regular fluid changes. If you plan to keep the vehicle outside of the warranty it's a good idea to change the gear oil in the PTU. For our 2017 Explorer I had the factory fill changed at 9,000 miles and will have it done again at 25,000 miles and then every 25,000 miles after that. That maybe overkill but these PTU's do not respond well to infrequent fluid changes if you intend to keep the vehicle for a long time, like we do. Replacement PTU's are costing in the ~$1600-$2000 range.
Whimsey
#4592027 - 12/02/17 12:27 PM Re: Ford Power Transfer Unit issues [Re: Toros]
andyd Offline
Loc: Marshfield , MA
It is stories like this that make me want rush right out and buy a Ford..NOT! If a PTU requires water cooling for normal usage, then it isn't up to the task it is being used for. Lousy product development and testing, pushed into production, only to fail in use results in an erosion of your customer base. As a business model, it stinks.
Thick oil is better grin2
#4592034 - 12/02/17 12:34 PM Re: Ford Power Transfer Unit issues [Re: andyd]
SatinSilver Offline
Loc: OH
A front wheel drive NA Fusion should be reliable and on CR's recommended list. Unlike it's GM cousin the Malibu.
#4592626 - 12/03/17 03:05 AM Re: Ford Power Transfer Unit issues [Re: SatinSilver]
Toros Offline
Loc: Chadds Ford
Not applicable to FWD only AWD.
#4592645 - 12/03/17 04:38 AM Re: Ford Power Transfer Unit issues [Re: Toros]
Toros Offline
Loc: Chadds Ford
Well it's been about 200 miles and it's either leaking at the new seal or overflowing from bring a bit overfilled. Will drive it another 300 miles or do and see.
#4592647 - 12/03/17 04:48 AM Re: Ford Power Transfer Unit issues [Re: 4WD]
Toros Offline
Loc: Chadds Ford
It's not a bad idea. But I need to make sure that the newly replaced seal will not be leaking.
#4592848 - 12/03/17 09:26 AM Re: Ford Power Transfer Unit issues [Re: Toros]
4WD Offline
Loc: Texas
Folks have been “gurgling” oil in from the top via a tiny air vent hose …
So that same hose should help you to drain and bottom fill …
The super syringe holds about 6 ounces so you’d have to inject and close the valve enough times …
They have volume markers too … filling them is very fast …
They could also help suck thick contaminated oil out …
(I have three of them) …
#4592871 - 12/03/17 09:46 AM Re: Ford Power Transfer Unit issues [Re: Toros]
Soggydog Offline
Loc: South Louisiana
The PTU issues steer me away from considering a new $40k 2017 explorer sport a local dealer is trying to clear out
Currently running...
2011 Ford F250 4x4 6.7L, 2011 Toyota Camry SE 2.5L, 2002 Dodge Caravan 3.3L,
2012 Honda Rincon,2012 Honda Rancher AT,09 Honda Trx90
#4592873 - 12/03/17 09:47 AM Re: Ford Power Transfer Unit issues [Re: Soggydog]
4WD Offline
Loc: Texas
It’s 4WD for $40k?
#4592889 - 12/03/17 09:58 AM Re: Ford Power Transfer Unit issues [Re: Toros]
Soggydog Offline
Yeah, ecoboost, sport, awd. Ill see if i can find a link
Found it
http://robinsonbrothers.com/ford-explorer-sport-4wd-2017-baton-rouge-la-290exr7
Edited by Soggydog (12/03/17 10:02 AM)
#4592934 - 12/03/17 10:54 AM Re: Ford Power Transfer Unit issues [Re: 4WD]
Toros Offline
Loc: Chadds Ford
I think you need to extend the tube to do that.
#4593875 - 12/04/17 11:34 AM Re: Ford Power Transfer Unit issues [Re: Soggydog]
The 2017 Explorer Sport, which is EcoBoost SHOULD have a drain plug on the bottom of the PTU, allowing a drain and fill. Our 2017 XLT with the 2.3 EcoBoost has a drain plug on the PTU, which I had the dealer do a drain and fill on. Also these newer PTU units have have a greater fluid capacity and mechanical redesigns that are suppose to help with longevity compared to the earlier units. They still say it's "lifetime" except for "severe" service where it's 30,000 miles. I'd use the 30,000 mile PTU service no matter what your service is, unless you're leasing or don't plan to keep it for the long haul.
Whimsey
#4593985 - 12/04/17 01:36 PM Re: Ford Power Transfer Unit issues [Re: Soggydog]
4WD Offline
Loc: Texas
0.53L in the PTU per an online owners manual … I’d have the salesman ask the shop what the capacity is and what a fluid change costs …mine was 18 oz… but only drains about 15 oz
Think the first change is the most important
Page 1 of 2 1 2 >
