m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
48 registered members (ammolab, adams355, bbhero, Aero540T, BlakeB, 4 invisible), 1,494 guests, and 62 spiders.
Topics298,352
Posts5,133,568
Members70,043
Most Online3,589
Nov 2nd, 2019
Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI #4591756 12/02/17 07:34 AM
DuckRyder Offline OP
HMM...
Couple of things, the indicated mileage is estimated with exception of the 198 miles last time and the mileages on this run and are since the engine build. I had misplaced the records but have since found them.
I strongly suspect the fuel pump is leaking internally as well as externally and that there is more than a trace of fuel in this sample, going to fix that.
The advice to listen for a ticking sound it a little amusing since it is a solid roller... It doesn’t make any abnormal noise and runs strong.
All 338 miles of this run was back and forth to the landfill with yard debris and several loads (like 2 tons worth) of egg rock...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9ā€¯ 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4591768 12/02/17 07:47 AM
B
bullwinkle Offline
B
Those are some pretty high lead & copper numbers-I hope you're not losing a bearing.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4591775 12/02/17 07:50 AM
spasm3 Offline
Were the cam bearings replaced at rebuild? If so that explains the copper. Sometimes it takes a while to see them come down.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles synpwr 5w30
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4591805 12/02/17 08:15 AM
Chris142 Online Content
Online Content
It dont like mobil-1. I would try a dino such as pennzoil or castrol. 10w40 or a 15w40.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: spasm3] #4591824 12/02/17 08:35 AM
Me too, I guess if it is then I’ll just change them, if it wiped the crank - I guess that would be as good of excuse as any to turn it into a 445.
They were, in fact nearly everything was replaced. The block and head casting were reused and a 390 rotating assembly was reconditioned, It makes 10.6:1 compression, cobra jet valves, crower solid roller...
I’ve got to go back and find the info on the bearings, they were either Clevite or Speed Pro “High Performance”.
Robert
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4591840 12/02/17 08:52 AM
R
Ram02 Offline
R
Try Valvoline 10w30 you might get a better UOA
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: Ram02] #4591850 12/02/17 08:58 AM
4WD Offline
Might be all mechanical but a 40 grade would be worth a go …
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4591925 12/02/17 10:25 AM
B
bullwinkle Offline
B
My only experience with the FE big blocks was in my brother's old '68 F-100 Ranger, a 360. We rebuilt it and ran VWB 10W40 (this was back in the day, I'm sure SE or SF, and it ran until the body finished rusting off of it. I'm with the guys above, and I wouldn't think that even VR1 20W50 and a shot of LiquiMoly MOS2 wouldn't be a bad idea-the oils back in those days were pretty loaded with it.
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: Chris142] #4591943 12/02/17 10:57 AM
L
littleant Offline
L
+1 Go to a dino
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4592072 12/02/17 01:15 PM
A
aquariuscsm Offline
A
I'm with the other posters,try a fill of PYB or QSAD.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4592289 12/02/17 05:53 PM
Are you guys looking at the dates? I’m not inclined to move away from Mobil, though I did consider putting 10/40HM in it...
The bearing clearances are relatively tight on it and it is full roller (Roller cam, Roller rockers, roller thrust bearing on the cam... so it really shouldn’t have any “Old engine” requirements.
One thing I did remember is that two of the rods in it appear to be copper plated, this isn’t particularly uncommon though no one has ever been able to really explain the reason, at least not that I recall. The beams on the rods were ground and polished, everything was shot peened as well... The pistons are forged flat top Speed Pro with skirt coating.
Robert
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #4592330 12/02/17 06:50 PM
M
MParr Offline
M
Have you considered a 10W30 or 10W40 blend? It may be a little early for an HM oil.
As far as fuel dilution, installing an external electric fuel pump may solve that problem.
2019 VW Tiguan SE Now: Castrol Professional OE LL IV 0W20 & OE VW/Mann
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #5144867 06/26/19 03:30 PM
So, who thinks based on this UOA I should tear into the motor?
Robert
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #5145264 06/27/19 04:07 AM
B
bbhero Online Content
Online Content
B
I just about guarantee that this motor is just fine....
Still breaking in... Hardly no miles on this truck motor really in the past 8 years.
If this truck had seen the average of 15k miles a year... It would be at or near 120k miles on it.
Nissan Altima 3.5 Coupe
Napa full synthetic 5w30 Wix 57356 Oil filter
"Treat your family like your friends and treat your friends like your family."
Re: Mobil 1 10W/30 EP 338mi 1972 F100 RangerXLT 390CI [Re: DuckRyder] #5282953 12/02/19 01:32 PM
I guess since I kinda let the cat outa the bag on another thread, I can bring this one to a close:
[Linked Image from rangerxlt.com]
Robert
