Float chargers?
by buck91. 04/21/19 05:32 PM
Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
96 registered members (alphadog, AdditiveOCD, 2015_PSD, 53' Stude, 2009Edge, AndyB, 9 invisible), 1,940 guests, and 24 spiders.
Topics287,854
Posts4,935,613
Members67,865
Most Online2,967
Mar 10th, 2019
Extension cords #4591500
12/01/17 10:05 PM
12/01/17 10:05 PM
Texas
4WD Offline OP
4WD  Offline OP
Texas
I’m going to set up a 15 amp saw about 60 feet from the plug to do a weekend project …
Have three 25’ cords: 10awg, 12 awg, 14 awg …
What is best order to avoid drop in the line?
Re: Extension cords [Re: 4WD] #4591504
12/01/17 10:08 PM
12/01/17 10:08 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
You're better off using the 10 and the 12 but forget about the 14.
Re: Extension cords [Re: 4WD] #4591505
12/01/17 10:09 PM
12/01/17 10:09 PM
Central Maryland
HangFire Offline
HangFire  Offline
Central Maryland
You'll get the same drop in any order.
Various musings: http://hangfire.net
Re: Extension cords [Re: 4WD] #4591516
12/01/17 10:19 PM
12/01/17 10:19 PM
TX
KJSmith Offline
KJSmith  Offline
TX
Dude, cordless, step up to the 2000's.
14awg is good for 15amps, use all three and your fine.
If it was me, I would have the 10awg closest to the house and the 14 at the end.
The only reason I say that is if one is going to get warm it should be the 14.
If its at the end, its furthest away from the house, closest to you and gives you the best chance of catching it.
Re: Extension cords [Re: KJSmith] #4591524
12/01/17 10:30 PM
12/01/17 10:30 PM
Texas
4WD Offline OP
4WD  Offline OP
Texas
Ha, I have a number of cordless tools … just for the Dewalt saw and my treated lumber looks pretty soggy …
Thanks …
Re: Extension cords [Re: Merkava_4] #4591526
12/01/17 10:32 PM
12/01/17 10:32 PM
Texas
4WD Offline OP
4WD  Offline OP
Texas
Then I should just go buy another 12 … left too many of them at the bay house …
Re: Extension cords [Re: 4WD] #4591561
12/01/17 11:45 PM
12/01/17 11:45 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That depends on how special your saw is. The saw is going to do its job whether its using Voltage or Amps. It just so happens that in the absence of Voltage, the saw is going to pull more Amps. When it pulls more Amps, the windings in the motor heat up. Heat up too much and your motor is toast.
I think you're probably good with 12AWG up to 50ft.
Re: Extension cords [Re: 4WD] #4591719
12/02/17 07:55 AM
12/02/17 07:55 AM
ME
eljefino Offline
eljefino  Offline
ME
Your internal house wiring could be another 50 feet of 14 AWG and we all assume that it's "perfect" at the outlet. Use what you've got, and stop work if it sounds different from normal.
I ran an air compressor off 100 feet of 16 AWG extension cord and it worked fine for a while until the cord heated up and its resistance went up. For intermittent use of a saw you shouldn't have this problem.
Re: Extension cords [Re: 4WD] #4591759
12/02/17 08:38 AM
12/02/17 08:38 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
100% correct.
AC power goes looking for "the weakest link in the chain"
Is it a miter saw?
Like on for a few seconds, then off for many minutes?
You should be fine.
A continuous load, like a big shop vac or air compressor, would test the 14 gauge cord to it's limits.
Remember, intermittent loads are always calculated on a different chart than continuous loads.
Re: Extension cords [Re: 4WD] #4591761
12/02/17 08:39 AM
12/02/17 08:39 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Yes. I would buy a 50' #12. The cheesy plugs and outlets are the weak parts of most extension cords. Best would be to buy a 75' and replace the plug and outlet.
2015 Ford F250 w/Powerstroke
Re: Extension cords [Re: 4WD] #4591762
12/02/17 08:39 AM
12/02/17 08:39 AM
One Step Beyond
MasterSolenoid Offline
One Step Beyond
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Extension cords [Re: Donald] #4591763
12/02/17 08:42 AM
12/02/17 08:42 AM
Texas
4WD Offline OP
4WD  Offline OP
Texas
Thanks ~ will do … the wall outlet is a new 20 amp 110v “homerun” from a 220V panel … (GFCI too)
Re: Extension cords [Re: MasterSolenoid] #4591766
12/02/17 08:44 AM
12/02/17 08:44 AM
Texas
4WD Offline OP
4WD  Offline OP
Texas
Interesting ~ was just there yesterday too ~ bet somebody got a bonus for that name too wink
Re: Extension cords [Re: 4WD] #4591956
12/02/17 12:07 PM
12/02/17 12:07 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
It should be fine to use it all in any order.
My dad used to weld for an hour at a time on a 100’ extension cord plugged into an outlet 50’ from the breaker box.
2015 Hyundai Sonata 2.4L 93k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Extension cords [Re: 4WD] #4591981
12/02/17 12:34 PM
12/02/17 12:34 PM
Central Texas
sleddriver Offline
sleddriver  Offline
Central Texas
Order doesn't matter as it will be a series connection. Use the 10 + 12g to get close.
As you're doing a weekend project, don't worry about wire gauge resistance consequences. It's not worth it. In a permanent installation, used day-in/day-out, with heavy use, then it would matter and should be considered.
1998 Volvo V70 T5 228,880 mi. Original Owner.
M1 10W-30 HM
"It's never a mistake to buy tools, defined broadly. They're not a cost, they're an investment." - J.B. Peterson
