Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
Lubricant Additives - A Practical Guide
by wemay. 09/24/18 01:39 PM
Fram Ultra--Any Real Competition?
by IndyFan. 09/24/18 12:59 PM
Used generator price.
by Eddie. 09/24/18 11:55 AM
More energy concerns about Bitcoin
by OVERKILL. 09/24/18 10:01 AM
Soot loading from DI engines - Size of particles
by StevieC. 09/24/18 09:58 AM
New TV bad picture some channels
by raaizin. 09/24/18 09:35 AM
Crown Victoria HVAC repair
by emmett442. 09/24/18 08:44 AM
albert001, LG_Electronics, TCam, OzFrog, Kursk
66062 Registered Users
112 registered members (92saturnsl2, 53' Stude, 65convertible, 46Harry, 77GrandPrix, 12 invisible), 1,887 guests, and 33 spiders.
Topics290,952
Posts4,853,069
Members66,062
Most Online3,590
Jan 24th, 2017
0w20 higher visc than 5w20? #4591120
12/01/17 04:07 PM
12/01/17 04:07 PM
Kentucky
hcbarger Offline OP
hcbarger  Offline OP
Kentucky
08' Mazda6i Kendall FS5W30 MCFL2017B 193575mi
96' Cherokee Sport Kendall SB5W30 Champ filter 173,581mi
16' Mazda6 Mazda filter Mazda reccomended castrol syn 0w20 30276mi
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591121
12/01/17 04:08 PM
12/01/17 04:08 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Pretty normal.
2018 RAM 1500 Big Horn EcoDiesel
2016 Grand Cherokee SRT
Re: 0w20 higher visc than 5w20? [Re: OVERKILL] #4591127
12/01/17 04:14 PM
12/01/17 04:14 PM
Kentucky
hcbarger Offline OP
hcbarger  Offline OP
Kentucky
Thanks. Probably going to do the 0 considering the abnormal cold we're expecting.
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591135
12/01/17 04:19 PM
12/01/17 04:19 PM
wi
dave123 Offline
dave123  Offline
wi
it will never know a difference in Kentucky.
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591137
12/01/17 04:20 PM
12/01/17 04:20 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
HTHS is where the protection is, and they are about the same.
It's a weird data sheet 'though
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591142
12/01/17 04:26 PM
12/01/17 04:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I don't think Kentucky ever gets cold enough to where someone genuinely needs 0w-20
Not like in North Dakota or Minnesota....
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591149
12/01/17 04:33 PM
12/01/17 04:33 PM
Kentucky
hcbarger Offline OP
hcbarger  Offline OP
Kentucky
This vehicle is making a two week stint in Toronto in January. I know it's not like spending a lifetime there, but still...
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591152
12/01/17 04:34 PM
12/01/17 04:34 PM
MN
oil_film_movies Offline
MN
Its not a "weird" data sheet.
0w20 uses thinner base oils than 5w20, although the 0w20's higher kv100 is due to use of more VII, which increases viscosity on that hotter end of things.
Also, +0.4 cSt isn't much diff anyway.
Kendall does seem to be great oil to use. I hear those oils can go a whopping 2,000 miles between oil changes, as the 2-finger logo touts. Revolutionary it is. Others will follow.
Seriously though, the good amount of Ti in it is cool. (Castrol uses far less Ti.)
Re: 0w20 higher visc than 5w20? [Re: oil_film_movies] #4591158
12/01/17 04:42 PM
12/01/17 04:42 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Not necessarily. M1 EP and AP 0w-20, which you and I recently discussed, just has more PAO on it versus a 5w-20, which can be made with Group III for example wink
Now of course that's likely not applicable here, but figured I'd mention it, as that's sometimes the case.
Re: 0w20 higher visc than 5w20? [Re: oil_film_movies] #4591163
12/01/17 04:46 PM
12/01/17 04:46 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
OK then...
look at the line that says "HTHS".
Then look a the line straight after it that says [email protected]
Then look at the values in the 30 grades
Re: 0w20 higher visc than 5w20? [Re: OVERKILL] #4591180
12/01/17 05:04 PM
12/01/17 05:04 PM
MN
MN
Not necessarily. M1 EP and AP 0w-20, which you and I recently discussed, just has more PAO on it versus a 5w-20, which can be made with Group III for example wink Now of course that's likely not applicable here, but figured I'd mention it, as that's sometimes the case.
I see what you're saying.
For example, if you made a full syn 5w20 using entirely GroupIII, as I think Kendall has, you could "convert" that 5w20 product in to a 0w20 by substituting some PAO in for some percentage of the GroupIII, knowing that PAO would allow the cold cranking 0w maximum to be met. (PAO makes seals shrink, so alterations in seal swell chemicals may have to be made, and then you might need some esters for additive solubility... a can o' worms....http://www.machinerylubrication.com/Read/28601/switch-to-synthetic ).
If staying with all-GroupIII for your 0w20, which is what I assume Kendall did here, you would have to use thinner oils and boost the hot kv100 upward via more VII added.
Also, they might have over-shot the minimum new-oil kv100 knowing there probably would be VII permanent shear happening. Good idea to do that.
So that kv100 might (likely will) shear down at mid- to later life of the oil in the sump, but your cold 0w cranking should still be OK since VII mostly affects the hot temperatures, not extreme cold cranking.
Re: 0w20 higher visc than 5w20? [Re: hcbarger] #4591185
12/01/17 05:08 PM
12/01/17 05:08 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The thinner the oil at startup the better. Period.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: 0w20 higher visc than 5w20? [Re: Shannow] #4591186
12/01/17 05:08 PM
12/01/17 05:08 PM
MN
MN
OK then...look at the line that says "HTHS".Then look a the line straight after it that says [email protected] Then look at the values in the 30 grades
You're right. I saw that. So many data sheets from other makers have these stupid errors in it. How hard is it for a big oil company to get an engineer to review and edit these things before releasing it to the public?
Thread subject was just looking at the kv100 line, and over-shooting the kv100 isn't a bad idea, so that part isn't weird.
Re: 0w20 higher visc than 5w20? [Re: mightymousetech] #4591191
12/01/17 05:14 PM
12/01/17 05:14 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
OK, got evidence of that ?
If you are well within the pumpable range, then I disagree with you.
If you are at the limits of pumpability...different matter...and this isn't
Re: 0w20 higher visc than 5w20? [Re: oil_film_movies] #4591202
12/01/17 05:26 PM
12/01/17 05:26 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Exactly. Or, if it is already PAO based, just use more PAO.
Example:
M1 EP 5w-20 MSDS:
versus:
M1 EP 0w-20 MSDS:
Which would lead one to believe that the VII treat rate is likely quite similar, they just use more PAO in the 0w-xx IMHO.
