Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
19 registered members (2015Corolla, Aero540T, Char Baby, bbhero, Bailes1992, anndel, 1 invisible), 835 guests, and 38 spiders.
Topics295,007
Posts4,925,888
Members66,664
Most Online2,553
Oct 27th, 2018
Are Bando belts stretchy? #4590608
12/01/17 06:29 AM
12/01/17 06:29 AM
West Chester, PA
artbuc Offline OP
artbuc  Offline OP
West Chester, PA
My go to belts are Mitsuboshi, Bando and Gates (from Unitta plant only). Just installed a Bando accessory belt on 07 Subaru OB that drives ps and alternator. Have adjusted tension twice and still get a short squeal on cold startup. Seems like belt should be tensioned enough. My BIL was a master tech who owned his own garage for many decades. He said that particular Subaru application requires a highly tensioned belt and that Bando belts are too stretchy to work. He calls them rubber bands. He says use a Mitsuboshi which is what came on the car from factory.
I found one other thread here where someone had trouble getting enough tension on a Bando belt accessory belt which seems to corroborate what BIL says. What is your experience with Bando belts? On timing belts and serpentine belts with automatic tensioners, maybe stretchy Bando belts are ok, but not so much with a manual tensioner.
Re: Are Bando belts stretchy? [Re: artbuc] #4590617
12/01/17 06:44 AM
12/01/17 06:44 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I don't have any of these brands' characteristics down but I do know that seeking accessory belts for the 5 Saabs in my sphere resulted in AMAZING, STUNNING, MIND-BLOWING variations in quality.
So a "Bando" belt, or any other, being stretchy comes as NO SURPRISE.
How do you source belts from Gates Unitta plant only? Where is Unitta?
Re: Are Bando belts stretchy? [Re: artbuc] #4590618
12/01/17 06:45 AM
12/01/17 06:45 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I have never owned a vehicle that required the belts to be stretched excessively.
Maybe your pulleys are getting worn?
Re: Are Bando belts stretchy? [Re: Kira] #4590643
12/01/17 07:16 AM
12/01/17 07:16 AM
West Chester, PA
artbuc Offline OP
artbuc  Offline OP
West Chester, PA
Unitta was a Japanese company bought by Gates or maybe just a JV with Gates, not sure about the specific financial arrangement. Gates Unitta belts are mostly OEM only. If you get one aftermarket it is only luck as you can not specify COO when buying Gates belts.
Re: Are Bando belts stretchy? [Re: artbuc] #4590656
12/01/17 07:29 AM
12/01/17 07:29 AM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
All I can say is Bando serpentine belts on auto tensioners for my all applications have had no problems. They are my go to OEM replacements.
~Shade tree mechanic for friends and family.
Re: Are Bando belts stretchy? [Re: artbuc] #4590661
12/01/17 07:32 AM
12/01/17 07:32 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Most belts will need a tweek or two. I never used Bando but I will never get another Gates. Every one has squeeked or squeeled. I never had problems with Dayco or Goodyear which I think goes by another name.Maybe there is a contaiminant on a pulley and retensioning temporarily quiets it.
The "thinking" man's friend.
Re: Are Bando belts stretchy? [Re: artbuc] #4590703
12/01/17 08:20 AM
12/01/17 08:20 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
In my formerly owned 04 Sienna, the Mitsuboshi was the only one that works for P/S belt.
The Gates was squeeling badly everytime it starts.
I usually have good experience with Gates but not for the Toyota.
  • 2017 Toyota Sienna
Re: Are Bando belts stretchy? [Re: artbuc] #4590726
12/01/17 08:51 AM
12/01/17 08:51 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Belts are hit and miss depending on application.
We use belts on the engine and on our truck powered cleaning equipment. The eqpt mfgr always recommended Bando for years and has now switched to some imported belt.
Draw your own conclusions...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: Are Bando belts stretchy? [Re: artbuc] #4590777
12/01/17 09:32 AM
12/01/17 09:32 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I only buy cars with spring loaded serpentine belt tensioners so I don't have this problem.
Re: Are Bando belts stretchy? [Re: artbuc] #4590792
12/01/17 09:43 AM
12/01/17 09:43 AM
MN
Tundragod Offline
Tundragod  Offline
MN
I have a cold morning squeak on my 08 Accord with original belt, 99k miles, don't know which brand in there but Bando belt (after market) is ordered. Will see how it works out.
12 Highlander limited, 08 Accord EXL 4, 04 MDX Tour, 02 CRV EX, 1995 Virago.
Re: Are Bando belts stretchy? [Re: Linctex] #4590795
12/01/17 09:45 AM
12/01/17 09:45 AM
West Chester, PA
artbuc Offline OP
artbuc  Offline OP
West Chester, PA
Hopefully not at 91k miles.
Re: Are Bando belts stretchy? [Re: artbuc] #4590801
12/01/17 09:58 AM
12/01/17 09:58 AM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I have 2 Bando belts on my Accord (manual tensioners). They developed a morning chirp after a hundred miles which a quick re-tightening took care of. Still nice and quiet now after 30k miles.
2018 Hyundai Elantra VE -- 6K
2013 Honda Pilot EX-L 4WD -- 57K
2002 Honda Accord EX-L -- 212K
Re: Are Bando belts stretchy? [Re: artbuc] #4590802
12/01/17 09:59 AM
12/01/17 09:59 AM
Quebec, Canada
MarioT Offline
MarioT  Offline
Quebec, Canada
I also had issues adjusting belt tension on my Elantra with Bando belts...
Bando is used from factory, but they do seem they strech a bit over a few weeks.
Alternator belt started to squeal badly when cold/humid outside, re-tightening a 2nd time did the job.
82kmiles on the car, 60kmiles for the engine, nothing unusual to note about the pulleys.
2015 Mazda5
2009 Hyundai Elantra
Re: Are Bando belts stretchy? [Re: artbuc] #4590873
12/01/17 11:00 AM
12/01/17 11:00 AM
Frogland / Brittany
Popsy Offline
Popsy  Offline
Frogland / Brittany
Just replaced an OEM Bando in my Mitsubishi, was squeaking at startup, even after re-tightening.
Replaced by an Italian made Denso, far less stretchy (but the Bando was 3 y.o and like 50000Km), so far no noise, even with less tension.
96 Barchetta, Motul 300V 5W40 | 98 Barchetta, Quartz 9000 energy 5W40
05 Forfour 95, SHU 0W40 (gf's car) | 10 Colt Ralliart, 300V 0W40
Re: Are Bando belts stretchy? [Re: JMJNet] #4590923
12/01/17 11:34 AM
12/01/17 11:34 AM
California
nthach Offline
nthach  Offline
California
I have a Gates as the water pump belt on a Prius and it seems to work fine. I have a Bando for the PS belt and Gates for the alt/AC belt - both are doing fine, Gates feels a bit more rigid than Bando but I do need to tighten the PS belt a touch.
