Originally Posted By: car51
DuckRyder: filter looks very good. Thank You for c&p
You are welcome of course. Filter has more gunk (note use of highly technical term) in the bottom than expected but is a solid piece for sure and the gunk is the cars fault not the filter...
Originally Posted By: mcwilly
Nice! I put one of those on my echo.
11,000kms on it so far. Another 5k or so to go.
Does that XG8A have the same size gasket? That would be a lifetime filter on the echo!
I think the gasket is larger on the XG8A, I will check today, though I realize you are probably joking.
Originally Posted By: sw99
Looks like stout little filter for sure. Thanks for the C&P.
You are welcome of course. It is a nice filter.
Originally Posted By: aquariuscsm
The oil holes are very smooth,no burrs. They look very precisionly cut.
Yep, typical Fram tapping plate, nicely made with no rough edges.
Originally Posted By: Run
Can't go wrong with the Ultra. Thanks for sharing.
No problem on the sharing naturally . Fram definitely has a hit with the Ultra... I only have one complaint I’ll get to in a minute...
Originally Posted By: dlundblad
Looks very good. Very tiny indeed.
Originally Posted By: bbhero
Ain't has small as the 6607
That's got it beat for sure. Very good job here Robert. You add a lot of good information/work here.
I was thinking that the 6607 was about the same size, I always get confused as to whether the Prius takes this on or the 6607 but the threads are different if that is the one I am thinking of...
I do try to add value, My pictures are not coming out as well as I would like lately - need to try to fix that... Thank You though.
Originally Posted By: Sayjac
Another boring FU (a good thing) at a substantial fci. The shorty 4967 is the SAE thread equivalent of the metric 6607. Not many cases in my observation where the longer but otherwise same specs 4386 and 7317 respectively won't fit too. Also noticed the addition to the corner of the pics.
Thanks for c&p.
Welcome of course. A longer filter would in fact fit Toyota even sells a longer version under TRD guise. This was 2 OCI and intent is to run the new one at least this long with ~10,000 OCI vs factory recommended 5000. Thought you might like the corners.
Changing this filter reminds me why I detest the “SureGrip”. This filter is sort of up in a hole you can get your hand on it pretty easily, but exerting any actual force is another story entirely. It would be very very easy to change if you could get the cap wrench on it, but you can’t because of the SureGrip. It is pretty tight to get any sort of strap or plier type oil filter wrench up there (again getting it to grab the filter is one thing, actually turning it is quite another) which is why the filter is a bit mangled. I wish FPS were easier to get.
FRAM seems pretty fully committed to the SureGrip, but I wish they would stop. Clearly with the “PRO series” they have realized it may not be desirable and I would think that an ever increasing number of vehicles have access issues.
