Synthetic motor oil in a gun
by Yuk. 03/26/19 01:07 AM
air suspension on a towed trailer?
by columnshift. 03/25/19 11:57 PM
AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
33 registered members (Bailes1992, BrianF, Atesz792, bmod305, Brad_C, alcyon, 2 invisible), 692 guests, and 61 spiders.
Topics286,442
Posts4,908,226
Members67,622
Most Online2,967
Mar 10th, 2019
Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours #4590222
11/30/17 07:22 PM
11/30/17 07:22 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
This is on my Kubota z723 zeroturn mower with a Kohler CV682 22.5hp engine. The oil has 58 hours of use, and unused Rotella T5 10w-30 synthetic blend oil. The engine has 153 hours total on it.
I am new here to BTOG, and not as educated probably about oil as many on the forum. Blackstone stayed that chrome was a bit high and ď....maybe....just maybe this is from break in.Ē SEE NOTES on oil report.
This engine had a warranty issue that I did not tell Blackstone about and it makes me wonder if it is perhaps a cause of the high chrome number. The mower would smoke at times for no reason (basically a new mower). Long story short.... April of this year it went in to have a head gasket replaced under warranty as on cylinder had a leak. The shop could not explain why a mower (at 73 hours at the time) had a head gasket leak, suggested perhaps it was a factory defect. Anyway they replaced reed valves and head gaskets, topped it all off with fresh oil (donít know what they used). And have it back to me. After running the mower for about an hour, I changed the oil again to the Rotella T5 10w-30 (filter also).
Does anyone have anything additional to add about the chrome?
You all confuse the [censored] out of me.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4590232
11/30/17 07:34 PM
11/30/17 07:34 PM
wv
krismoriah72 Offline
wv
Im running this now in a kawasaki teryx 800.. got the 2.5 gallon jugs at autozone for cheap.. there are a few UOAs on here and all look good..however i wouldnt actively search it out unless you get it cheap. Rotella 15w40 is just as good if not better in some ways.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4590365
11/30/17 09:30 PM
11/30/17 09:30 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
No doubt it is a robust oil, and a great reputation.
Sure wish I knew if that chrome comment they made is a sign of something bad, or a residual thing left from the work that was performed.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4590706
12/01/17 09:24 AM
12/01/17 09:24 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
i read it all before i comment.
ok a susvis of 70.7 is VERY interesting.
as the stoners claim you oil went UP and is now firmly a 40wt. (68.2863 is the low point of 40wt)
and did it with a trace of fuel. which there is more than a trace with a lowly flash point of 375.
all of my uoa's with this low of a flash have between 0.5% and 1.0% fuel.
that said, that would mean your 70.7 is actually even thicker.
alum of 6 is nice and low, but what is there thats really alum?
this is motor only right? no tranny?
chrome could be rings or ??? not that high really
iron of 27 could be high, but not really for 58hrs
copper of 4 is low, but what copper is there? part of babbit bearings maybe?
tin 7 could be the same as copper
so at 74hrs this oil went in?
someone's math seems all wrong or we dont know the entire picture.
153-58=95hrs when this oci was done.
so was the oci before that from 74 to 95? (74 being the 1hr after head gasket change)
95hrs on this motor is NOT still breaking in. not this type/use of motor anyway.
granted it can still have residual ppm from long ocis before it, but its way past broken in.
what where the oci's from 0 to 74?
omg i'm gonna agree with the stoners...58hrs is way to much on this oil
unless the motor specs 30wt, i would run a hdeo 15w40 at 40hrs and worry that you die before the motor does.
steve
motorcycle oil myth buster
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4590967
12/01/17 01:07 PM
12/01/17 01:07 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
Thanks for the comments Steve.
Ok let me get out my books and double check a few things cause it is likely when I made my initial post I had some of my hour information off some.
When the mower was received back from the shop it had 94.9 hours on it. I received it back with fresh oil and filter, no idea what type of oil or viscosity. I immediately changed the oil even though it was just changed cause I didnít know what they (the shop) used. It was that point I used for the first time Rotella T5 10w-30. So the Rotella was ran in the mower from 94.9 to 153.2 hours. So the oil was used for 58.3 hours. The color of the oil was not extremely dark upon its drain. Kohler recommends an oil change interval of 100 hours or annually, whichever is first. Prior oci: when new, the oil was changed initially after the first 8 hours of operation. It was changed at the end of each season after that as I never exceeded 100 hours in a year. At the beginning of this season (2017) prior to use the mower had 81.2 hours. Prior to using the Rotella, Kohler branded 10w-30 was all that I ever used.
The engine oil system is a closed system and is not shared with any other mechanical attributes of the mower. Mowers with similar engines can exceed 1000 hours in operation easily.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4593732
12/04/17 08:59 AM
12/04/17 08:59 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
eric
i know how many hours this motor is capable of.
BUT
you can greatly extend that value by a lot by merely doing more frequent oci's.
you dont have an oil filter...probably not even a chunk strainer.
the key to longevity on this motor is getting rid of the particles in the oil since you have no filter
to remove them.
if you were to do a 33hr oci with the cheapest 10w30 you can but it would still be better than the most expensive oil you can buy and doing 100hr oci's.
ie your oil filter is the dump bucket
like i said, if it were me...i'd do 33hr oci's with SRT 15w40 or supertech 15w40
steve
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4594410
12/04/17 09:22 PM
12/04/17 09:22 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
I know there is nothing wrong with sooner OCIs, no argument there. 30 some odd hours seems really soon to me though. But this motor does have a spin on automotive style filter. Identical actually, I use kohlers, but I can get wix, Mobil, and many other brands.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4594727
12/05/17 09:27 AM
12/05/17 09:27 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
oh you do have a filter? my bad.
think about this
50hrs at 60mph is 3000miles in a car.
BUT (thats a big but)
your car doesnt run that 3000 miles with it at the throttle stop wfo!
this motor (like all mowers) barely gets a warmup and then its BAM to the throttle stop and go
until you either stop and refuel or put it away for the next time.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4594933
12/05/17 12:55 PM
12/05/17 12:55 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
That is true, as it stands now the longest run is about 1 & 1/2 hours solid run time at one site.
Somethings still puzzle me though, and apparently it does [censored] also.... how the oil changed viscosity. Now one thing that was disclosed to [censored], but I have not posted here was that when I was changing the oil I forgot that I was going to have an analysis done. So when I tool my sample it was by pouring what was needed from the drain pan and into their bottle. Now my drain pan was not squeaky clean, I am sure there was about a tablespoon or so of oil oil left in it, and probably various dust debris etc.... But the sample came off the top, as it were, but I still cannot help but wonder if that has a part in this. I just cannot see how, especially on the viscosity deal.
This coming season I am trying some amsoil full synthetic 10w-30 that I had (signature series). I have kicked around also acquiring an additional machine. But it would have a briggs vangaurd 37 efi big block on it, and running their 15w-50 synthetic oil.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4595083
12/05/17 03:18 PM
12/05/17 03:18 PM
West Michigan
Balrog006 Offline
Balrog006  Offline
West Michigan
Infitesimal contamination from your drain pan may very well be the culprit here. Run another OCI, sample and test again right from the drain before talking any drastic action.
19 Ridgeline RTL-E >1K factory fill, A01
08 CRV 275K+ VSyn w/ML, A01
04 JD L130 740H, Mobil S 5w30
13 JD 2032r 325H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Balrog006] #4595257
12/05/17 06:02 PM
12/05/17 06:02 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
Yea I think that is my plan. Blackstone (abbreviated as B S earlier and censored) didnít seem to think that the way the sample was collected would have had a huge affect. But there just seems like some weird stuff happening here.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4595773
12/06/17 09:04 AM
12/06/17 09:04 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
eric,
with a response like that, now you know why i call them the stoners
they are such a bunch of idiots that the phrase "they are a moron's moron" comes to mind.
if your sampling changed the copper by just 1 ppm...that was a 25% change!
now, when you pay for anything, would you rather pay 25% more or 25% less?
if the doc says eric you have a 50% chance of prostate cancer. would you rather that really be 25% or 75%?
its only off by 25% either way! yeah i know the answer you dont have to reply.
i dont want to get into the math it to determine the contamination level...it would require the amount of
time before the sample was drawn and even the time it took to take the sample. so...lets forget about it.
however, know this, oils can gain susvis at the end of their life. this site has countless examples of it.
to jump up a grade says a lot. with such low flash says even more (which could more so be from the contamination...ug i got back to it)
in a nutshell this uoa was data, but ultimately it was a waste of money. sorry to say
steve
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4596550
12/06/17 09:45 PM
12/06/17 09:45 PM
KY
Eric502 Offline OP
Eric502  Offline OP
KY
Yea it certainly seems like it.
So... and I am sure this is covered all over here on the forum.... but what is a good lab to use that is an alternative to blackstone.
Re: Kohler CV682 (22.5hp) Rotella T5 10w-30/58hours [Re: Eric502] #4611255
12/22/17 02:01 PM
12/22/17 02:01 PM
FL
stoan Offline
stoan  Offline
FL
I'm on my second mower with a 24hp Kohler and have used various 30 and 10-30 oils. Put Rotella T6 5-40 in it last time, engine seems quieter and the oil stays cleaner looking for longer. Also switched to a Wix 51348 filter, not sure if that has anything to do with the oil staying cleaner, but it's a bigger filter with similar bypass setting.
