silly wiper problem
by bowlofturtle. 09/20/18 10:33 PM
Canadian Tire Shell Rotella T-6 in Pails
by Snagglefoot. 09/20/18 10:04 PM
Best diesel fuel for cold weather?
by Dickm. 09/20/18 10:03 PM
Type 1 Diabetics - New Research
by StevieC. 09/20/18 10:00 PM
Tire Sizing and Options
by NewEnglander. 09/20/18 09:59 PM
2013 Scion FR-S | Transmission Fluid Questions
by nicknak. 09/20/18 09:47 PM
Meguiar's Liquid Cleaner Wax $5 WalMart, Amazon
by The_Cams. 09/20/18 08:42 PM
Winter oil recommendation
by Neptune. 09/20/18 08:27 PM
M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Direct_Rejection, donatom, Sylent_Snyper, Ajizzle, nicknak
66033 Registered Users
77 registered members (Ablebody, A310, 69Torino, AMC, alphadog, ABCarr, 12 invisible), 1,362 guests, and 38 spiders.
Topics290,738
Posts4,849,384
Members66,033
Most Online3,590
Jan 24th, 2017
1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM #4589816
11/30/17 01:16 PM
11/30/17 01:16 PM
Michigan
Buzzinhalfdozen Offline OP
Michigan
This oil was put in back on June 4th 2017. It's done a majority of highway and long trips 250-500 miles back in summer. It's been short tripped about 2 miles every day since September with longer travels on weekends 500 miles round trip. I typically drive conservative but I'm not afraid of using the throttle for fun highway merging.
Lc20 was used according to the directions for full interval.
FP plus was used according to directions in fuel till September.
Fram ultra xg8 oil filter. Air filter changed about half way through interval.
1999 Jeep Cherokee sport 4.0L
2015 Jeep Cherokee 3.2L
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4589838
11/30/17 01:34 PM
11/30/17 01:34 PM
Ontario, Canada
StevieC Online content
StevieC  Online Content
Ontario, Canada
Looks like you might have a coolant leak into the oil. (Potassium)
Also not really great numbers for that oil with that many miles. IMO. I wouldn't want to see double digits that high.
FWIW.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4589917
11/30/17 02:52 PM
11/30/17 02:52 PM
Deplorable in apple valley, ca
Chris142 Online content
Chris142  Online Content
Look for a cracked head right under the oil fill cap
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4589935
11/30/17 03:08 PM
11/30/17 03:08 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Seems like high iron, lead & copper. Aluminum OK.
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4589946
11/30/17 03:17 PM
11/30/17 03:17 PM
Soviet State of Washington
PimTac Offline
PimTac  Offline
I wonder what would prompt this analysis company to put a caution or alert? That green check mark seems misleading
2017 Mazda CX-5 Grand Touring
Valvoline Advanced Synthetic 0w20
Mobil 1 M108A EP filter
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4590091
11/30/17 05:27 PM
11/30/17 05:27 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Maybe lab knows some 4.0s shed iron. Id say report looks very good aside from that iron count smile
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Buzzinhalfdozen] #4594186
12/04/17 05:23 PM
12/04/17 05:23 PM
Storrs, Connecticut
jeepman3071 Offline
jeepman3071  Offline
Storrs, Connecticut
That doesn't look too abnormal to me, but honestly I wouldn't run the oil that long. 4.0's do shed a lot of iron, and I'm thinking this just isn't the best oil for it.
OP: Is this a regular Cherokee or Grand Cherokee? I assume regular by the title but you never know. Reason I ask is the 0331 head that cracks started in the Grand Cherokee in 1999 and the regular Cherokee in 2000. You can tell that it is the 0331 head if you have coil pack ignition instead of a distributor.
Regardless, I don't think you have a coolant leak. I honestly think the best oil for these engines is a good 10w30 conventional. My UOA with Pennzoil 10w30 had single digit iron wear, but it was also lower miles.
2000 Jeep Cherokee 4.0L (180k) - Pennzoil 10w30, Napa Gold 1516, Magnefine trans filter
2009 BMW 328i (33k) - Castrol Edge Euro 0w40, MANN HU816X
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: StevieC] #4594268
12/04/17 07:07 PM
12/04/17 07:07 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Originally Posted By: StevieC
Looks like you might have a coolant leak into the oil. (Potassium)FWIW.
Then I wonder why the lab said NO for coolant under the heading Contaminants. shrug
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: jeepman3071] #4594392
12/04/17 09:11 PM
12/04/17 09:11 PM
Michigan
Michigan
This is the regular Cherokee. With the distributor ignition. Im not worried if it has coolant leak. Before I learned of oil analysis you just made sure it wasn't cloudy. This drained clear.
I don't normally run oil this long either but thought I'd give it a go.
I have a bunch of 5w-40 and 0w-40 oils from last year's AutoZone clearances that I've been using. I grabbed some Rotella t5 10w-30 when it was on sale for $15 at autozone. Probably going to use that after winter. If I ever run out I'll be sure to give the penzzoil conventional a try though!
Re: 1999 Jeep Cherokee 4.0 Penzzoil Ultra Euro SM [Re: Merkava_4] #4594424
12/04/17 09:35 PM
12/04/17 09:35 PM
Ontario, Canada
Ontario, Canada
Because the lab has idiot techs. It happens. Potassium in oil is not a good thing.
