2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
Be careful what you wish for...
by Shannow. 09/20/18 04:40 AM
Debating repowering my tower.
by Colt45ws. 09/20/18 01:10 AM
Oil filter for GM 8.1l V8?
by KenO. 09/19/18 11:10 PM
Help! No high beam
by wolf_06. 09/19/18 11:02 PM
Heading for divorce
by barkingspider. 09/19/18 11:02 PM
Oil recommendation: 1991 Nissan D21 truck
by RDY4WAR. 09/19/18 10:04 PM
Cold starting and CCS etc.
by CT8. 09/19/18 10:03 PM
Whine->Dead car(electrical)
by madRiver. 09/19/18 09:59 PM
Differential Allen Drain Bolt Buggered
by Gebo. 09/19/18 09:41 PM
Pick my oil. 25k miles a year
by Serge. 09/19/18 09:41 PM
Ok to use in Kubota? Pennsoil 0w-40
by racinjason. 09/19/18 09:35 PM
Road Hugger GTP A/S Tires
by Bud_One. 09/19/18 09:16 PM
Gravity Bleeding Clutch?hel
by Spetz. 09/19/18 09:10 PM
Drunken Watch?
by StevieC. 09/19/18 09:01 PM
New Forum Member New Truck Owner
by FarmerDude. 09/19/18 08:35 PM
Valvoline DOT 3/4?
by DJ. 09/19/18 08:22 PM
Best grease for AWD actuator disconnect?
by Bman90. 09/19/18 08:14 PM
Reconditioning a 2-Stroke Snow Blower
by Finz. 09/19/18 07:55 PM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
79 registered members (askani79705, Bear, Astro14, BAJA_05, Ablebody, Al, 3 invisible), 1,239 guests, and 46 spiders.
Topics290,700
Posts4,848,552
Members66,021
Most Online3,590
Jan 24th, 2017
New Bosch Distance Plus D3330 damaged ADBV #4589577
11/30/17 07:40 AM
11/30/17 07:40 AM
Tennessee
FlyingVan Offline OP
Tennessee
I was looking through my stash of filters and noticed that the ADBV of this one does not look too good. This is the 3/4-16 filter similar in size to the Fram 3614. If my decoding ring works right, it was built in the Fayetteville plant on November 18, 2014, Line B, 1st shift. Too bad, since it was louver-less. Hehe.
The ADBV was either installed off center and 2 of the holes are not sealing properly, or the ADBV is just cut all the way through in those 2 holes. I did shone a flashlight through the oil exit hole and you can clearly see light shining through the 2 inlet holes, but not on the other ones. If this filter was to be used, unfiltered oil would bypass the media.
I will try to return it, but if I cannot do that I will open it up and post more photos here.
I still have a few D+ and I will be using those without any concerns. I guess this thought me to look over a filter (any brand) before buying it.
2017 Volkswagen Jetta 1.4TSI, 30k
2016 Volkswagen Jetta 1.4TSI, 30k
2011 Volkswagen Jetta Sportwagen TDI, 90k
2004 Dodge Sprinter 2.7 5cyl diesel,774k
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589587
11/30/17 07:57 AM
11/30/17 07:57 AM
Long Island, N.Y.
incognito_2u Offline
Long Island, N.Y.
"Houston, we have a Problem....."
Unfortunately, the average consumer would not even pick up on that defect.
Good catch!
2006 Jeep Commander 3.7 V6 -109k (PUP/XG3600)
2006 Toyota Corolla 1.8 VVTi -77k (PPHM/XG3600)
1999 Toyota Corolla 1.8 -78k (PUP/XG4386)
1998 Toyota Corolla 1.8 -62k (PUP/XG4386)
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589642
11/30/17 09:34 AM
11/30/17 09:34 AM
california
goodtimes Offline
goodtimes  Offline
california
Awhile back I showed a Bosch made by Puro with a adbv installed off center, to one side. This is the same thing it looks like, not cuts. I returned two Boss filters in this size that did have the cuts, although the cuts were tightly sealed. This is one of those once in a while manufacturing glitches. We all know Fram has had their share of them. The other style of Puro filters does not have this issue, the adbv goes into the end cap hole.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589670
11/30/17 10:08 AM
11/30/17 10:08 AM
california
goodtimes Offline
goodtimes  Offline
california
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589746
11/30/17 11:51 AM
11/30/17 11:51 AM
New England, USA
wings&wheels Offline
New England, USA
Good eyes!
I had this exact situation happen once a long time ago. A Mobil 1 filter (Champion made M1-204 if i remember?) bought for my TR6 w/ spin on conversion had the ADBV offset exactly as this. I installed it as it was what I had on hand, hoping it would seal, and when left overnight, the car would take quite a few seconds longer to build pressure. I replaced the filter within a few days.
Lesson learned;I now visually check new filters and only use Mann & Hummel or Hengst on this car.
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'72 Land Rover Series III 88"
'99 Porsche 996/'01 Boxster S (Wife's...)
Pa28-236
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589750
11/30/17 11:59 AM
11/30/17 11:59 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
If you can't return it, call Bosch (Purolator) and see if they'll do anything about it. Unlikely, but maybe you'll get lucky-the D+ was a $12 filter when it was full (OVER) priced!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589799
11/30/17 12:58 PM
11/30/17 12:58 PM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Good Catch.
I REALLY wish they would put the ADB back in the filter mounting bracket so we don't need this thing on a "two dollar" commodity item.
I'm always peeking into boxes at the store before I buy the filter. More than a couple times an employee came up and asked if I needed "help".
I said I'm a BITOG member smile
They say, what? WHO?!
smile smile smile
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: ARCOgraphite] #4589812
11/30/17 01:12 PM
11/30/17 01:12 PM
SF BAY AREA, CA
dogememe Offline
dogememe  Offline
SF BAY AREA, CA
Originally Posted By: ARCOgraphite
Good Catch.
smile smile smile
If you look inside the boxes of a bunch of different filters I'm going to open the box at the counter in front of you when you are ready to make sure you didn't put a Mobil filter in a Microgard box because I'm going to assume you're trying to pull a switcheroo wink
2007 Crown Vic P71 4.6 ~126K Miles, Royal Purple HPS 5W-30, Royal Purple Filter, Daily Driver, 5K OCIs.
2010 Escape FWD 2.5 ~84K Miles, Castrol Edge EP 5W-30, Wix Filter, Rented on Turo, 10-15K OCIs.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4589836
11/30/17 01:33 PM
11/30/17 01:33 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
That ADBV is supposed to get pushed away from the baseplate as the oil enters the filter. In its current state, it would not get pushed away; instead, it would become one giant catastrophic oil flow restrictor. That filter could have destroyed your engine if you had not noticed the defect and installed it on your engine.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: Merkava_4] #4589936
11/30/17 03:10 PM
11/30/17 03:10 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
No not really.
The rest looks fine... I seriously doubt this filter would hurt an engine.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: Linctex] #4589970
11/30/17 03:30 PM
11/30/17 03:30 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
Maybe some if left on and the engine went through many "dry starts" because the ADBV leaked and cause the supply galleries to empty every time the vehicle sat for an hour.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: Linctex] #4590006
11/30/17 04:10 PM
11/30/17 04:10 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
No not really.
Look at the picture again. The ADBV is supposed to work like a pet's door. The door "flaps" open when the pet pushes through. As it is now, it's not a door that can be pushed open; it's a restrictive screen at best.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4590045
11/30/17 04:48 PM
11/30/17 04:48 PM
california
goodtimes Offline
goodtimes  Offline
california
The last picture I posted shows exactly what the valve looks like. One side is off the base plate. There would be no adbv function and a dry start every time in certain positions. Mine was a base down so it would be bad. There still is plenty of flow area total.
Some oil flow would also go past the bare metal where the adbv seals and be unfiltered.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4590166
11/30/17 06:30 PM
11/30/17 06:30 PM
Tennessee
Tennessee
No restriction at all, just that the ADBV is not functional at all and some oil would bypass the media. I don't believe it would kill an engine, at least not as bad as a torn filter.
Re: New Bosch Distance Plus D3330 damaged ADBV [Re: FlyingVan] #4590921
12/01/17 12:34 PM
12/01/17 12:34 PM
Freehold, nj
iluvhonda Offline
iluvhonda  Offline
Freehold, nj
Thx for posting. Gave me another reason to check the boxes at Wally World.
'99 Prelude 264k Penn Plat Euro 5w-30/Honda A01
'17 Civic Hatch EX 5dr Penn Plat 0W-20 15k Honda A02
