Quote:
...At the Los Angeles Auto Show, INFINITI revealed the all-new QX50—a premium mid-size SUV featuring the first production application of the VC-Turbo variable compression ratio engine, transforming on demand…
...The VC-Turbo changes its compression ratio seamlessly with an advanced multi-link system, continuously raising or lowering the pistons’ reach to transform compression ratio—offering both power and efficiency, on demand….
...As the angle of the multi-link arms changes, it adjusts the top-dead-center position of the pistons—and the compression ratio with them. An eccentric control shaft changes the compression ratio of all the cylinders at the same time. As a result, the engine capacity varies between 1,997 cc (for a low 8:1 ratio) and 1,970 cc (high 14:1 ratio)….
...Equipped with the VC-Turbo engine, the QX50 delivers gasoline fuel economy of 27 mpg (US combined, front-wheel drive; 26 mpg all-wheel drive). In front-wheel drive specification, this offers a 35% improvement in fuel efficiency over the V6 gasoline engine in the previous QX50, while the new all-wheel drive model’s 26 mpg represents a 30% improvement...
More technical details here:
http://www.greencarcongress.com/2017/11/20171129-qx50.html
