Oil for 08 camry
Va
Have a Toyota 2.0l 1az fe. Car is spec a huge range, 5w 30 to 20w 50. 60000 miles.
The temperature here doesn’t usually go lower than 77f
What should I use.
It’s on gtx 20 50 now and previously10w 30 Mobil 1
Any good 5w20 or 5w30; I would use semi-synthetic like Max Life or synthetic like Mobil 1
Basically what the factory called for.
Xw20 and xw30 are generally (not always) resource conserving for “better efficiency”.
I would use whichever oil doesnt burn too quickly without sacrificing too much MPG.
I generally stick to 10w30 and i think its pretty warm down here.
I recommend trying quaker state products. I had less burnoff than most other brands/formulas and good performance from these quaker products Ive used in my Toyota Camry
QS HiMi API SN 10w30
QS ultimate durability full syn 5w30
Trying Valvoline for the first time this oil change, hope its good!
Originally Posted By: JohnnyJohnson
What should I use.
10w-30 and don't look back!
yup this. If you can find some rated for diesel engines as well, it would be better yet.
What should I use.
I do have rotella 10w -30 and Mobil 1 in 10-30 flavor.
