0.5 quarts of make-up oil added through this OCI, also castrol magnatec 5w30. This is the full synthetic version. Last time I added 1 quart of make-up oil, close to the end of the OCI (within last 1.5k miles probably). Filter was an ACDelco PF457G (the older hengst version), last time was wix xp. Oil life monitor indicated 10% left.
Driven 90% on the freeway, 14 mile commute each way. TBN is too low for me, I would like to keep it above 2. I'll just run 9k mi at the most from now on. Pretty satisfied with a $25 oil change. The viscosity held up very well again.
