Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Web Archive
by Duffyjr
06/22/18 10:25 AM
Sonoma This weekend!
by racin4ds
06/22/18 10:22 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
84 registered (Bandito440, andyd, 2015_PSD, 93cruiser, ammolab, Astro14, 13 invisible), 1548 Guests and 52 Spiders online.
65294 Members
67 Forums
285789 Topics
Page 1 of 3 1 2 3 >
#4588823 - 11/29/17 12:48 PM Thermostat; to drill or not to drill a bleed hole?
Drew99GT Offline
Loc: Colorado Springs
That is the question; just had to put a new stat in my Corolla; the factory ones come with a jiggle valve, the Stant ones do not, so I drill a small hole in the flange and positioned it at 12 oclock when installing. I know the jiggle valves sort of seal when the flow goes through the thermostat, preventing overcooling. I'm curious if just a small hole will make the car not get up to temp in very cold weather. Thoughts? Who's drilled a stat and had a car in very cold weather?
Thanks
#4588832 - 11/29/17 12:52 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
Leo99 Offline
Loc: NJ
I would not drill a hole. I'd use oem if I was worried about whatever it is you're worried about.
Without data you're just another person with an opinion. W. E. Deming
2003 Corolla 250,000 miles
2004 Rav4 359,000 miles
2015 Camry 59,000 miles
#4588836 - 11/29/17 12:55 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
bullwinkle Offline
Loc: Cincinnati, OH, USA
I'm on the other side-a small hole is going to allow MUCH less coolant through than the factory bypass will-DRILL BABY DRILL!
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
#4588839 - 11/29/17 12:57 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
fenixguy Offline
Loc: NC
I only use OEM thermostats and wouldn't drill holes in them. That being said, as small as those air bleed holes are, I highly doubt you'd ever be able to tell a difference in getting up to temp.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4588847 - 11/29/17 01:00 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
redbone3 Online   content
Loc: Reno, NV
Many years ago I blew several Opel water pumps before I learned to drill a bleed hole (In Germany). Drill away.
2014 Passat Wolfsburg, 1995 Miata.
#4588857 - 11/29/17 01:05 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
HoosierJeeper Offline
Loc: WI
If the OEM one has a hole, the replacement needs to.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4588886 - 11/29/17 01:23 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
PandaBear Offline
Loc: Silicon Valley
I wouldn't use that stat if they don't look identical in functionality. I learn 2 painful lessons of going old school all metal radiator from CSF and a STANT radiator cap, that's 2 warped heads and head rebuild.
Edited by PandaBear (11/29/17 01:23 PM)
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#4588901 - 11/29/17 01:41 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
edwardh1 Offline
Loc: Coastal South Carolina
drill.
my oem isuzu had a small hole with a "wiggle valve" to keep hole clean.
two aftermarket stats I looked at did not. I bought a gates and drilled a hole.
you need a hole to allow quicker flow and stat warmup and to bleed air.
small hole size down from 1/8 inch
Edited by edwardh1 (11/29/17 01:42 PM)
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
#4588906 - 11/29/17 01:43 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
mightymousetech Offline
Loc: Ontario, Canada
Return the one you bought and get an OEM.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4588909 - 11/29/17 01:45 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
ARB1977 Offline
Loc: North Texas
That jiggle valve does something. I saw a 6 to 8 degree drop in operating temps on my Toyota 3.4L installed at the 12 o'clock position.
2015 Tacoma 4.0L 60K (as of 02/23/18)
Amsoil SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Factory filter
#4588913 - 11/29/17 01:47 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
Drew99GT Offline
OEM is out of the question; dealer doesn't have one, don't have time to order. I've tried Motorad and it ran too cool; I've had good success with Stant in the past, so that's what I used.
Car is running good now; before, it was overcooling in cold weather and starting overheating yesterday; lower hose (inlet side thermostat) was ice cold - old stat was sticking closed.
Thanks for the input so far fellas, I'll report back after a few days if anything abnormal occurs!
#4588917 - 11/29/17 01:50 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
SatinSilver Offline
Loc: OH
What year is the car, a 1993? smile
#4588918 - 11/29/17 01:50 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
OneEyeJack Offline
Loc: S California
Not having more than an opinion on the subject I'd defer to the OEM setup.
#4588928 - 11/29/17 01:57 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
demarpaint Offline
Loc: NY
I learned the hard way years ago to only use OE thermostats. Since that isn't an option, if the OE part had a bleed hole, I'd be inclined to drill one. My OCD 'might' have me order a thermostat from the dealer and replace the aftermarket part when it comes in.
God Bless Our Troops
#4588936 - 11/29/17 02:05 PM Re: Thermostat; to drill or not to drill a bleed hole? [Re: Drew99GT]
BigD1 Offline
Loc: NC
Altrom Tama brand from NAPA have jiggle valves, and are made in Japan. Tama is what I used on my 92 Toyota pickup.
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
Page 1 of 3 1 2 3 >
