What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
Shassis, Santo, aligoodn, memyself, MichiganKid419
65274 Registered Users
81 registered (2015_PSD, 77GrandPrix, BigCahuna, Aero540T, 6 invisible), 1394 Guests and 43 Spiders online.
65274 Members
67 Forums
285627 Topics
Page 1 of 5 1 2 3 4 5 >
#4588780 - 11/29/17 12:19 PM When should I do the first oil change?
Twodogs10mm Offline
Loc: Oregon
Hi, I have a new 2017 Ram 1500 5.7 Hemi. I am trying to decide when and which oil and filter to use for the first oil change. Right now it has about 1200 miles on it.
Are there any reasons to leave the factory oil (dino pennzoil I think) a specified time for break in?
I am thinking full synthetic but which one? Manual says 5w/20 which meets ms-6395.
Any thoughts or recommendations would be appreciated.
#4588788 - 11/29/17 12:25 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
Trav Offline
Loc: MA, Mittelfranken.de
It should have been out of there 700 miles ago at least. I go 100 miles and dump it, then 500 then 1K then normal oci intervals.
Yes engines still shed metal and no engines are not built any cleaner than years ago, machining metal is dirty business there is no way around it.
Edit: The old argument "the filter will catch it" is a bit bogus also, there is a tight clearance oil pump before the filter that can get scored by metal particles especially ferrous metals.
Edited by Trav (11/29/17 12:29 PM)
#4588794 - 11/29/17 12:27 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
fenixguy Offline
Loc: NC
I'd change it now. Then change it again at ~2-3,000. Then go for a full OCI per the manual or oil life monitor. Or you could just run the factory fill for the full OCI and it will be fine either way.
As far as which oil to go with, pick whichever color bottle you like or whichever one is cheapest. You really can't go wrong.
welcome
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4588798 - 11/29/17 12:29 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
StevieC Offline
Loc: Ontario, Canada
Pretty much every off the shelf oil meats the MS-6395 specification for both Conventional and Synthetic so no worries there... I would use Pennzoil because Chrysler seems to be in bed with them for recommended oil and PUP is a good oil performance wise. M1 is also a great choice.
I have always dumped the Factory Fill at the 1,000km (600 miles) and then run the second fill a conservative 5,000km (3K miles) and then run the 3rd fill to whatever I feel comfortable running. I'm not saying this is necessary just that I have always done it and it's worked for me.
Personally I use Amsoil and have really nice UOA's of it in my Chrysler engine as well as other vehicles I have owned. Just FWIW.
Edited by StevieC (11/29/17 12:32 PM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4588809 - 11/29/17 12:35 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
Jeffs2006EvoIX Offline
Loc: Imperial Valley, California
Congrats on your new Truck.
I have always changed my oil on a new vehicle before it hits 1000 miles. Then I would change it before it hits 3k miles then at 5k miles then do 5k intervals from there on.
Dodge is sponsored by Pennzoil (joke here)
I think you can run Pennzoil Platinum Synthetic 5w20 with confidence in this nice truck of yours at 5k intervals with no problems thumbsup
Jeff
Edited by Jeffs2006EvoIX (11/29/17 12:36 PM)
"You don't have to be crazy to do this... But it helps." Bob Ross.
#4588819 - 11/29/17 12:41 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
OneEyeJack Offline
Loc: S California
An early oil and filter change can do no harm and might help. You pick.
#4588824 - 11/29/17 12:49 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
bigt61 Offline
Loc: Virginia
I think an early change is a waste of time and money. Follow the OLM and use dino up until the 30k mark for best break-in, - then switch to full synthetic. Keeping it topped off between changes is important.
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
#4588825 - 11/29/17 12:49 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
anndel Offline
Loc: Hawaii, USA
Change it now then usual OCI per owner's manual for the next change. I went 1,000 miles on each of our cars/trucks and then 5,000 miles after the 1st oil change. So far engine's been fine for our 24 year old Toyota p/u, 12 year old Toyota Avalon and 2014 Toyota Tacoma.
#4588827 - 11/29/17 12:50 PM Re: When should I do the first oil change? [Re: Trav]
demarpaint Offline
Loc: NY
thumbsup
God Bless Our Troops
#4588864 - 11/29/17 01:08 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
HondaBroMike Offline
I overrode my MMS that tells me to change my oil for the FF at a ridiculously low <4000 miles. It's been proven or surmised through UOAs that a little fuel in the oil doesn't impact wear, and eventhough it thins the oil's viscosity, the TBN tells you your oil is still protecting from acids and other by-products. I changed my FF at almost 6000 miles and what makes this noteworthy, for me anyway, is the MMS was dictating around 4000 miles! Needless to say, I plan on sticking with the MMS like the bible and koran combined, lol.
Edited by HondaBroMike (11/29/17 01:09 PM)
#4588986 - 11/29/17 03:05 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
Eddie Offline
Loc: Florida, Cape Coral
I usually use about 2,500 miles or 1/2 the normal recommended mileage. Early changes are a waste of time and money in the modern engine with an oil filter. Ed
CX5 Touring 2.5L :-)
#4588995 - 11/29/17 03:12 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
eyeofthetiger Offline
Loc: South Carolina
My new Fiesta has 1700 miles now. I plan on doing the first oil change at 2000. Slightly arbitrary, but I am not waiting 10,000 miles for the OLM to come on.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
#4589031 - 11/29/17 03:39 PM Re: When should I do the first oil change? [Re: Twodogs10mm]
Yah-Tah-Hey Offline
Loc: Columbus,Nebraska
Follow the OEM maintenance guide.
#4589106 - 11/29/17 05:11 PM Re: When should I do the first oil change? [Re: Yah-Tah-Hey]
fdcg27 Offline
Loc: OH
I agree with this.
I used to believe that a couple of early drains were important to long engine life so I used to do them.
Not anymore.
If the manufacturer thought it mattered, then they'd specify it.
Heck, the OM for the newer Accord is pretty adamant about not doing an early drain of the FF, but what does Honda know?
17 Forester 12K MSS 0W-20
12 Accord LX 86K PP 5W-20
09 Forester 95K M1HM 10W-30
01 Focus ZX3 118K PP 5W-20
96 Accord LX 104K T5 10W-30
95 318i
#4589123 - 11/29/17 05:26 PM Re: When should I do the first oil change? [Re: Trav]
Ihatetochangeoil Offline
Loc: On the road Midwest
welcome
^^^^This. +++
And this is why: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4505662/Found_this_in_my_canister_oil_
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4022760/Re:_Break-in_for_new_vehicles#Post4022760
This subject is unsettled on BITOG. User Kschachn criticized early change out, but he offers no "published technical justification" for an engine lasting past its warranty period...But Trav is the master. You'd do well to listen to him.
Originally Posted By: kschachn
There is no published technical justification for an early changeout of the factory fill, nor for the stepped routine Fitch describes in his article. I don't know where he gets his supposed information from.
Jim Fitch has published more articles and holds more patents than most BITOGERS have years of education and experience. (beginning with kindergarten). I'm not going to offer further info on Mr. Fitch's credentials. Most people know how to google.
Originally Posted By: Ihatetochangeoil
Honestly sir, I can find no published technical justification for an engine to last past its warranty period.
Do whatever lets you sleep at night. Hope you enjoy your new truck. Cheers2
