Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
PARTS PLUS PH 2876 CUT OPEN
by 53' Stude. 04/17/19 06:18 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
40 registered members (Billbert, billt460, A1O, bbhero, Bailes1992, 7 invisible), 654 guests, and 27 spiders.
Topics287,673
Posts4,932,031
Members67,838
Most Online2,967
Mar 10th, 2019
Total Quartz 7000 10w40 #4588735
11/29/17 12:46 PM
11/29/17 12:46 PM
Europe
Ether Offline OP
Ether  Offline OP
Europe
When looking at the MSDS and TDS documents for this oil,are the more knowledgeable members able to determine if this product is a blend of Group 1 and Group 3 base oils,or is it Group 1 and Group 2 with something else? I have been told previously that the pour point figure is a typo. I am very interested to know an approximate of this oils composition.
http://htsuppliesltd.co.uk/wp-content/uploads/2016/01/Material-Safet-Data-Sheet-Quartz-7000.pdf
http://www.total-distributor-partners.com/media/15337/quartz_7000_10w-40_-_08.2013.pdf
Re: Total Quartz 7000 10w40 [Re: Ether] #4588964
11/29/17 03:34 PM
11/29/17 03:34 PM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
What is the real pour point?
Iíve used this oil, and it wasnít the best performing 10W40 I tried in cold weather (in my car).
Sorry, canít help for your question.
96 Barchetta, 300V 5W40 | Forfour 95, SHU 0W40
Mazda 6 2.3, M1 AFE 0W20 | Colt Ralliart, 300V 0W40
Re: Total Quartz 7000 10w40 [Re: Ether] #4588984
11/29/17 04:01 PM
11/29/17 04:01 PM
Europe
Ether Offline OP
Ether  Offline OP
Europe
No worries.Pour Point is apparently -42
Re: Total Quartz 7000 10w40 [Re: Ether] #4589010
11/29/17 04:26 PM
11/29/17 04:26 PM
Brittany / Canada
Popsy Offline
Popsy  Offline
Brittany / Canada
-42 seem plausible, but low! Well, if Shell HX7 pp is -45ļ, why not.
25% gr I and 15% gr III according to the pdf? Whatís the rest?
Or maybe 25% gr I, 15% gr II, and rest is gr III plus additives, etc. Itís a heavy 10W40, so either some serious gr I, or serious VII! But pour point is low...
(Iím just guessing here, need to wait for real experts)
Re: Total Quartz 7000 10w40 [Re: Ether] #4589112
11/29/17 06:20 PM
11/29/17 06:20 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Pour Point is irrelevant, which is why they've been replaced with CCS and MRV. It's a 10w-xx which means it is out of spec for pumping at -30C and cold cranking at -25C.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Total Quartz 7000 10w40 [Re: OVERKILL] #4589174
11/29/17 07:34 PM
11/29/17 07:34 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Yes, and I've seen rather low pour points for a 15w-40 (i.e. RP 15w-40), around -45 C as I recall, despite me not choosing it as a winter fill. wink Of course, I've seen poor pour points (type that three times fast) in a 5w-30 that I did use for winter.
Plain, simple Garak.
Re: Total Quartz 7000 10w40 [Re: Ether] #4589369
11/29/17 10:29 PM
11/29/17 10:29 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
At a complete guess, because I'm no expert, and taking the MSDS at face value.....
I think Hydrotreated is Group I, so their are two of these for a total of 40%.
Group II is Hydrocracked. Group III is Catalytic Dewaxing and Hydroisomerization, neither are listed.
Ref: https://bobistheoilguy.com/forums/ubbthreads.php/topics/4564282/
The rest is the add pack at about 8.5%. Certainly not everything is listed and the MSDS only works in very rough figures.
My completely amature guess would be: about 40% Group I and about 10% for the add pack and about 50% Group III (remainder).
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Total Quartz 7000 10w40 [Re: Ether] #4590791
12/01/17 10:42 AM
12/01/17 10:42 AM
Europe
Ether Offline OP
Ether  Offline OP
Europe
Does the Viscosity Index of 160 point towards a load of VII, or could it mean a heavy Group 3 base or something else maybe.Does colour give any clues to the type/types of base oils that are used.
Re: Total Quartz 7000 10w40 [Re: Ether] #4591332
12/01/17 07:10 PM
12/01/17 07:10 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
All good questions Ether, and I have no answers for you.
I always assumed that a semi-synthetic was a Group II & Group III mix, and maybe for the thinner US market ILSAC oils it is. But I was shocked to discover that thicker Euro 10W40 oils could be a Group I & Group III mix.
Very few companies tell you what Groups are used in their products, so it's mostly guess work.
Two points I've settled on, if it passes a good standard then it should be a good oil and there is little use in double guessing how they got there. There is a lot of chemistry involved with dispersants, detergents, anti-oxidants, etc that focusing on one component isn't very useful.
Second, if I really don't want any significant amount of Group I base in my formulated oil, then I buy a full synthetic and be done with it.
I have a bit of 10W40 SN & A3/B4 semi-synthetic at home, various brands, some may be Group I & III (with more Group III ?) while some may be Group II & III (with less Group III ?) either way - I'm going to use it without concern. They should all be fine for 6k miles / 10k KM / 12 months.
