Question about new Peak OEM coolants
by PD001. 12/17/18 10:21 AM
Rev X
by Big_3_Only. 12/17/18 10:04 AM
Cleanliness
by WyrTwister. 12/17/18 08:12 AM
Gear whine
by odotb. 12/17/18 07:38 AM
Honda Pilot Oil specs US vs Overseas
by parshisa. 12/17/18 06:23 AM
Advisory on Roku TV's
by LoneRanger. 12/17/18 05:44 AM
Chevy Commercial Parody
by 02SE. 12/17/18 02:37 AM
Fluctuating Tachometer Fixed!
by jerseyguy123. 12/17/18 02:10 AM
2015 MB GLA250: OEM oil vs Mobil1 Formula M
by SlavaB. 12/17/18 12:39 AM
Shotgun Ammo
by user52165. 12/16/18 10:24 PM
Bought a Model 3 for wifey
by JeffKeryk. 12/16/18 09:01 PM
Maybe I'm crazy.
by TRDPRO85. 12/16/18 07:50 PM
Pacer EON E-11 Synthetic Motor Fluid
by Brandon9797. 12/16/18 07:46 PM
Reuse transmission fluid??
by FFeng7. 12/16/18 07:35 PM
Amsoil SS color change
by BigShug681. 12/16/18 07:21 PM
Why don't owner's manuals specify the oil type
by OilUzer. 12/16/18 07:13 PM
belt tensioner problems
by mobilaltima. 12/16/18 06:57 PM
stantaur, Brandon9797, Landngroove, DanielH, Cpcz9382
66700 Registered Users
95 registered members (99Eclipse, Anduril, atikovi, aquariuscsm, 2012AccentSE, AdditiveOCD, 11 invisible), 1,993 guests, and 45 spiders.
Topics295,179
Posts4,929,310
Members66,700
Most Online2,553
Oct 27th, 2018
Infiniti First to Market with Variable Compression Engine ? #4588633
11/29/17 10:36 AM
11/29/17 10:36 AM
Idaho
SubLGT Offline OP
SubLGT  Offline OP
Idaho
Quote:
...At the Los Angeles Auto Show, INFINITI revealed the all-new QX50—a premium mid-size SUV featuring the first production application of the VC-Turbo variable compression ratio engine, transforming on demand…
...The VC-Turbo changes its compression ratio seamlessly with an advanced multi-link system, continuously raising or lowering the pistons’ reach to transform compression ratio—offering both power and efficiency, on demand….
...As the angle of the multi-link arms changes, it adjusts the top-dead-center position of the pistons—and the compression ratio with them. An eccentric control shaft changes the compression ratio of all the cylinders at the same time. As a result, the engine capacity varies between 1,997 cc (for a low 8:1 ratio) and 1,970 cc (high 14:1 ratio)….
...Equipped with the VC-Turbo engine, the QX50 delivers gasoline fuel economy of 27 mpg (US combined, front-wheel drive; 26 mpg all-wheel drive). In front-wheel drive specification, this offers a 35% improvement in fuel efficiency over the V6 gasoline engine in the previous QX50, while the new all-wheel drive model’s 26 mpg represents a 30% improvement...
More technical details here:
http://www.greencarcongress.com/2017/11/20171129-qx50.html
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588651
11/29/17 10:51 AM
11/29/17 10:51 AM
PimTac Offline
PimTac  Offline
As I understand it, the Mazda SkyActiv can change its compression ratio depending on certain circumstances. It may be more common than we know.
Cannot see signatures any longer so it doesn’t matter.
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588655
11/29/17 10:53 AM
11/29/17 10:53 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
There are too many extra reciprocating parts in there to make me comfortable. The 4 banger in my Camry gets 35.7 MPG in a 25~ mile drive to my daughter's house. I'm happy with that.
Thick oil is better grin2
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588669
11/29/17 11:01 AM
11/29/17 11:01 AM
PimTac Offline
PimTac  Offline
Reading that insert further this is a different way than what I was thinking. Mazda just keeps valves open at certain points in the combustion process to achieve the effect. Infiniti is going with a complicated method involving the rods. I would be cautious yet I applaud Infiniti for their innovation.
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588671
11/29/17 11:03 AM
11/29/17 11:03 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I will wait until Nissan (Infinity) has their failures like early CVT's first and then when the bugs are worked out have a look.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588695
11/29/17 11:17 AM
11/29/17 11:17 AM
Southeast
meep Online content
meep  Online Content
Southeast
I really like the skyactive solution. lots of moving parts in the infinity design. I wonder if infinity found a wider performance/efficiency range or other advantage with their design? There's got to be additional losses from the multiple friction points and inertial mass, so there must be another payoff. I tell you what, when one of those throws a rod, the carnage will be unmatched.
2018 F150
2015 crv (wifey!)
Re: Infiniti First to Market with Variable Compression Engine ? [Re: andyd] #4588712
11/29/17 11:27 AM
11/29/17 11:27 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
1000's and 1000's of reliable flight hours say your fears are unwarranted
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588715
11/29/17 11:30 AM
11/29/17 11:30 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Nissan doesn't build aircraft and I'm thankful! LOL
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4588853
11/29/17 01:02 PM
11/29/17 01:02 PM
North Texas
ARB1977 Offline
ARB1977  Offline
North Texas
Since turbos are more common now and days. How about variable waste gates. More psi when needed. Instead of reaching a certain psi to releave pressure.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Infiniti First to Market with Variable Compression Engine ? [Re: Linctex] #4589358
11/29/17 09:17 PM
11/29/17 09:17 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
This design is used in airplane engines? I didn't know that. Please elaborate.
Re: Infiniti First to Market with Variable Compression Engine ? [Re: ARB1977] #4589503
11/30/17 01:19 AM
11/30/17 01:19 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
That's been done for a long time. Some vehicles change the boost pattern based on settings, and some based on atmospheric conditions.
I remember one of the rags doing a high altitude test of "hot" wagons, and the SAAB was walking away from a 540i wagon due it's boost pressure having elevated to 28psi to compensate for the lower air density.
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4589512
11/30/17 02:14 AM
11/30/17 02:14 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
I remember 1980s magazine articles on Nissan working on that engine...it's been in development for a LONG time
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4590403
11/30/17 09:16 PM
11/30/17 09:16 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
It is certainly an interesting concept. Variable compression along with variable valve timing could really optimize efficiency and power.
If this design proves reliable it could really be a game changer. I would definitely let someone else buy one and be the Guinea pig to test reliability!
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4590438
11/30/17 10:07 PM
11/30/17 10:07 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
- variable compression
- variable valve timing
- multiple cylinder deactivation
- direct fuel injection
That should be a nice reliable engine. crazy crazy
Re: Infiniti First to Market with Variable Compression Engine ? [Re: SubLGT] #4590759
12/01/17 09:19 AM
12/01/17 09:19 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Just needs a CVT! LOL
