2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
what happened to merk
by ernied
06/24/18 08:34 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
2003 Honda power steering problem
by hogpops
06/24/18 03:29 PM
Public Service Announcement: Flush Your HW Heater
by gathermewool
06/24/18 03:25 PM
Fellow 2AZ-FE toyota owners: what oil are you usin
by car51
06/24/18 03:21 PM
lozpxs, danthemanx07, FunktasticLucky, Knuckle078, penncove
65317 Registered Users
26 registered (dishdude, Brad_C, Dyusik, Bailes1992, dogememe, Aero540T), 856 Guests and 32 Spiders online.
65317 Members
67 Forums
285952 Topics
Page 1 of 2 1 2 >
#4588463 - 11/29/17 07:42 AM Oil viscosity questions
Bxnanaz Offline
Loc: SC, USA
Hello BITOGers! Long time lurker, new member.
So I’ve been wondering for a while but haven’t found a good answer. Many people believe that “thicker” viscosity oils protect better. Well with most if not all engines having an oil pump pressure relief valve, wouldn’t the best oil viscosity be as thin as possible to yet still hit that relieve valve pressure spec when hot?
Example: my 2017 Silverado calls for 0W-20. It has a relief valve pressure spec of ~40 until 3500rpm, when it then hits a second stage of flow where it ramps up 60+. I frequently tow 5K+ LBs in the hot summer months and it pretty much always hits that ~40 psi spec before 3500 rpm. In my mind, this is a good viscosity for this engine. What’re yalls thoughts?
#4588471 - 11/29/17 07:47 AM Re: Oil viscosity questions [Re: Bxnanaz]
StevieC Offline
Loc: Ontario, Canada
welcome to BITOG!
The engineers know best. Whatever your manual calls for in the temperature it will be operated under the service category (Regular, Heavy Duty etc.) is what you should use.
That said a quality 0w20 if that is what the manual calls for, is suitable. You can verify this with a UOA to be sure! thumbsup
FWIW there are others on here with Ram trucks doing towing with 20wts in the crank case. wink
Edited by StevieC (11/29/17 07:50 AM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4588478 - 11/29/17 07:55 AM Re: Oil viscosity questions [Re: Bxnanaz]
zeng Offline
Loc: Malaysia
Oil pump relief valve pressure is never a parameter in determining suitable oil grade use or lubricant performance.
It's about engine system protection , say preventing filter bursting.
#4588492 - 11/29/17 08:03 AM Re: Oil viscosity questions [Re: StevieC]
Bxnanaz Offline
Loc: SC, USA
Originally Posted By: StevieC
welcome to BITOG!
Thanks for the response! I have no doubt 20wts can protect my engine more than adequately. Not saying I would trust them for long drain intervals though. I’ve been running about 4,000 mile intervals with 0w-20 M1 AFE. I know it’s probably way too short, but probably 50% or more of those miles are towing miles so I figured might as well be safe. Will do a UOA now that I have about 13k on the truck and have performed my 4th change. (One of which was at 500 miles).
Switched over to Penzoil Platinum seeing as it was on sale and my engine is actually noticeably quieter at idle. Had the ever so slightest tick on M1 that I attributed to DI noises.
#4588512 - 11/29/17 08:28 AM Re: Oil viscosity questions [Re: Bxnanaz]
StevieC Offline
I would recommend using Test Oil's Ohio lab because I know their calibration is top rate.
#4588517 - 11/29/17 08:30 AM Re: Oil viscosity questions [Re: Bxnanaz]
kschachn Offline
Loc: Upper Midwest
The safety of a long drain interval isn't really related to the grade. That wouldn't be my concern.
1994 BMW 530i, 227K
1996 Honda Accord, 262K
1999 Toyota Sienna, 394K
2000 Toyota ECHO, 267K
#4588534 - 11/29/17 08:52 AM Re: Oil viscosity questions [Re: Bxnanaz]
ARCOgraphite Offline
Loc: N.H, U.S.A.
Forget UOA. If you want a little more high load safety margin (I don't know what you mean by protection) substitute a qt or 2 on the next oil change with a 30 grade.
Oil pressure just puts oil into the bearings the pressure doesn't float the shaft, that's the inherent working viscosity of the fluid. So Oil grade e.g: 20, 30, 40 provides your loading safety margin.
BTW, There is no 20wt or 30wt or "weight". Its a misuse of terminology.
2014 Nissan Rogue S CVT, OC#9 41392mi-QSUD10W30 + M110A CHAMP Filter; 2017 Subaru Crosstrek CVT OC#2 ?? mi-SOA/Idemitsu 0w20 + SOA Filter
#4588538 - 11/29/17 08:57 AM Re: Oil viscosity questions [Re: Bxnanaz]
FordCapriDriver Online   content
Loc: Balearic Islands , Spain
It specs 0W-20 mainly because of fuel economy regulations.
If you use 0W-30, 5W-30 absolutely nothing bad will happen, 0W-20 will be fine though aswell, and personally until the warranty runs out i would run 0W-20, because that way if anything went wrong with the engine and they saw you didn't use their specified oil, that may void the warranty.
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4588663 - 11/29/17 10:55 AM Re: Oil viscosity questions [Re: FordCapriDriver]
Bxnanaz Offline
Loc: SC, USA
Warranty is the main reason I’m gonna keep running 0w-20. UOAs will help me determine what I run after warranty
#4588728 - 11/29/17 11:39 AM Re: Oil viscosity questions [Re: zeng]
Linctex Offline
Loc: Waco, TX
Correct.
Hydrodynamic protection between two metal surfaces is the REAL criteria.
Metal making contact with metal = no bueno
#4588738 - 11/29/17 11:49 AM Re: Oil viscosity questions [Re: Bxnanaz]
Bxnanaz Offline
Loc: SC, USA
My thought process was if the relief valve is set a X pressure, and a 0W-20 hits X pressure, why go any “thicker”.? Obviously I was wrong on that.
#4588750 - 11/29/17 11:59 AM Re: Oil viscosity questions [Re: Bxnanaz]
StevieC Offline
Pressure doesn't equate with protection. Flow has more to do with it. That's not to say you don't need some pressure but it's not the be all end all.
#4588753 - 11/29/17 11:59 AM Re: Oil viscosity questions [Re: Bxnanaz]
Loc: N.H, U.S.A.
Don't! UOA is junk science.
Throw some ten dubbya thirty in there b4 its too late, pardner.
Like I say maybe 1 or 2 qts of the mix.
Dealer doesn't have a clue what oil is in there. And 1-2 cst gooey-er oil isn't going to ding ANY alarms.
Don be a fairy trucker 'fraid of the big bad mean dealer. I'm shaken in my boots!
You motor would be proud to be in a Z28 or Vette in the 70's as a High Output option. It putting down some powah! It neeeeds some vis coz city!
Yeah, good luck on that 20 grade. He He.
#4588763 - 11/29/17 12:07 PM Re: Oil viscosity questions [Re: Bxnanaz]
4WD Offline
Loc: Texas
My thoughts are I have that motor and the 0w20 bugs me a bit … the 8 quarts gives me mixed emotions … might hold up to DI better than 6 quarts ~ but 6 quarts of 5w30 is pretty cheap and good for south Texas use …
#4588843 - 11/29/17 01:00 PM Re: Oil viscosity questions [Re: StevieC]
kschachn Offline
Loc: Upper Midwest
Please explain? In a technical way I mean.
1994 BMW 530i, 227K
Page 1 of 2 1 2 >
