Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
111 registered members (1WildPig, ABerns, 2012AccentSE, 2K2AcuraTL, 69Torino, 1leater, 9 invisible), 2,182 guests, and 171 spiders.
Topics286,196
Posts4,904,009
Members67,576
Most Online2,967
Mar 10th, 2019
Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] #4588326
11/29/17 03:33 AM
11/29/17 03:33 AM
WA
John_Dude Offline OP
WA
0.5 quarts of make-up oil added through this OCI, also castrol magnatec 5w30. This is the full synthetic version. Last time I added 1 quart of make-up oil, close to the end of the OCI (within last 1.5k miles probably). Filter was an ACDelco PF457G (the older hengst version), last time was wix xp. Oil life monitor indicated 10% left.
Driven 90% on the freeway, 14 mile commute each way. TBN is too low for me, I would like to keep it above 2. I'll just run 9k mi at the most from now on. Pretty satisfied with a $25 oil change. The viscosity held up very well again.
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: John_Dude] #4588411
11/29/17 07:47 AM
11/29/17 07:47 AM
Northern Ontario, Canada
Danno Offline
Danno  Offline
Good reported but pushed the oil change a little too deep evidenced by the low TBN number.
Try 7000 - 8000 miles next time.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: Danno] #4588674
11/29/17 12:05 PM
11/29/17 12:05 PM
Massachusetts
deven Offline
deven  Offline
Massachusetts
I disagree. The viscosity is within range, the wear metals are low and TBN is not below 1.0 which is when the oil is depleted. I would personally stay at 10,000 mile OCI with this oil. Its the sweet spot for it.
Proud user of ROYAL PURPLE products!
2016 Acura RLX Sports Hybrid(Royal Purple HPS 5w30 + M1-110 oil filter)
KEEP IT SIMPLE STUPID. IT'S ONLY OIL
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: deven] #4588850
11/29/17 02:02 PM
11/29/17 02:02 PM
Chicago / IN
vinu_neuro Offline
vinu_neuro  Offline
Chicago / IN
TBN can be above 1.0 with elevated TAN. It's why TAN is also needed and why TBN retention isn't the be all and end all.
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: John_Dude] #4588915
11/29/17 02:49 PM
11/29/17 02:49 PM
WA
WA
I read that blackstone kinda pulled the 1.0 minimum tbn out of their [censored]. Oil manufacturers generally look for tbn to fall to either 1/3 or 1/2 of the voa amount when it's depleted. Dont have a tan option with wix so I'll consider 2 my baseline.
I figure that the oil becomes acidified from blow by, which if excessive would cause oil consumption. With half a quart over 9.5k mil the rings are probably pretty tight still.
I'm impressed that the magnatec has slowed my oil consumption. I used to see 1 quart consumption over 5-6k mi, this was my 2nd run with magnatec. I wonder if the pao or esters are swelling the seals, although the oil pan has been dry the whole time. Could be the valve stem seals.
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: John_Dude] #4588998
11/29/17 04:17 PM
11/29/17 04:17 PM
WA
WA
This was actually the older synthetic blend version of magnatec.
Re: Magnatec 5w30 - 9.5k mi [2007 Cobalt - 125k mi] [Re: vinu_neuro] #4589768
11/30/17 12:20 PM
11/30/17 12:20 PM
Massachusetts
deven Offline
deven  Offline
Massachusetts
If the TAN was elevated you'd most likely see more skewed numbers and the viscosity would suffer along with elevated copper and tin numbers as well. This was told to me by a well known gentleman who used to decipher UOA's for a living and was a member here a long time ago.
