Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
Leak/drip left front 13 Ram 4x4?
by irv. 09/22/18 06:22 PM
5w20 oil choices
by 53' Stude. 09/22/18 06:05 PM
site security
by RF Overlord. 09/22/18 06:02 PM
Richmond Raceway
by Warstud. 09/22/18 06:01 PM
Redline D6 ATF substituting for Toyota WS
by Patrick0525. 09/22/18 05:29 PM
XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
HondaTech250, SandCruzer, sbgti96, cosmoblau, Sarrge
66044 Registered Users
29 registered members (Bailes1992, 10ecfarmer, Brigadier, aquariuscsm, BlakeB, 2 invisible), 971 guests, and 39 spiders.
Topics290,866
Posts4,851,550
Members66,044
Most Online3,590
Jan 24th, 2017
too much oil added in cylinder? #4588289
11/29/17 01:06 AM
11/29/17 01:06 AM
Massachusetts
Frankws6 Offline OP
Frankws6  Offline OP
Massachusetts
I was servicing my generator for long term storage. The instruction booklet recommended adding a tablespoon of oil into the cylinder through the spark plug hole and rotating the engine to lubricate the cylinder and prevent corrosion. I accidentally tipped the oil can a bit too much and probably a good 3 tablespoons dripped in. I rotated the engine and reinstalled the spark plug. Could I damage the engine next time I start it? I'm nervous about hydrolocking (oil locking in this case) the engine, fouling up the spark plug, or causing valve damage. My guess is that I'm overreacting and what excess oil there is will just seep past the cylinder rings through the months. Should I suck up any oil from the cylinder?
Re: too much oil added in cylinder? [Re: Frankws6] #4588298
11/29/17 01:24 AM
11/29/17 01:24 AM
Seattle
Superflop Offline
Superflop  Offline
Seattle
Give the cord a good couple yanks with the plug out.. reinstall and call it a day.
2002 saab 9-5 2.3t wagon
2014 dodge grand caravan
Re: too much oil added in cylinder? [Re: Superflop] #4588308
11/29/17 02:11 AM
11/29/17 02:11 AM
MI
HorseThief Offline
HorseThief  Offline
MI
Look down the cylinder while you're doing it to make sure it all comes out whistle
Seriously though, put a towel over it unless you want oil mist everywhere.
I saw a brown dog
Re: too much oil added in cylinder? [Re: Superflop] #4588349
11/29/17 05:29 AM
11/29/17 05:29 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
not now though, that'd be pointless. put a note on it for the it comes out of storage
Re: too much oil added in cylinder? [Re: Frankws6] #4588392
11/29/17 07:06 AM
11/29/17 07:06 AM
Ontario, Canada
StevieC Offline
StevieC  Offline
Ontario, Canada
I would imagine that most of it will have seeped back down past the rings during long-term storage. I wouldn't worry at all. If you are concerned pull the cord a few times with the plug removed first.
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: too much oil added in cylinder? [Re: Frankws6] #4588468
11/29/17 08:45 AM
11/29/17 08:45 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The pull cord will break long before you do any damage to the engine internals from hydro-lock. Remove the spark plug and blow some out, otherwise it'll probably drain over the storage period.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 113K
'85 GMC C3500, 454, 130K
'82 Mercedes 300CD, OM617 turbo, 169K
'67 Suburban, 350, 331K
Re: too much oil added in cylinder? [Re: Frankws6] #4588583
11/29/17 10:54 AM
11/29/17 10:54 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
You have guessed correctly.
Re: too much oil added in cylinder? [Re: Linctex] #4590565
12/01/17 05:49 AM
12/01/17 05:49 AM
Nebraska
Duffyjr Offline
Duffyjr  Offline
Nebraska
I'm asking this in relation to my 23 year old 5hp Tecumseh on my MTD blower and not a newer OHV. Is it possible for the oil to find its way to the carb back thru the valves if you pulled the cord to many times?
89 GMC Sierra T5 10w30/Wix
08 Lucerne CX NAPA Blend 5w30/Napa Gold
18 Toro Super Recycler T5 10w30
Re: too much oil added in cylinder? [Re: Duffyjr] #4591084
12/01/17 03:28 PM
12/01/17 03:28 PM
Minnesota
Lenny5160 Offline
Lenny5160  Offline
Minnesota
I don't see how the air (or anything else in the cylinder) would be made to flow back toward the carb.
Reversion can and does happen, but I can't see it at 'manual pulling' speed.
