Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
Any golf cart experts?
by HawkeyeScott. 09/20/18 09:15 AM
EU Subaru 2.5 FB engine oil
by IMPALA08. 09/20/18 08:16 AM
02 Focus head replacement
by Eric Smith. 09/20/18 08:08 AM
A5/B5 or A3/B3
by ka9mnx. 09/20/18 07:53 AM
2018 Mazda 3 2.5 Castrol or Mazda Moly
by mazdamonky. 09/20/18 07:44 AM
What fuel are you running?
by Matagonka. 09/20/18 07:25 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
87 registered members (arthuro, Aichiguy, 92saturnsl2, alexmarjanovic98, 4 invisible), 1,712 guests, and 46 spiders.
Topics290,723
Posts4,849,096
Members66,021
Most Online3,590
Jan 24th, 2017
Toyota Owners: Spec for ATF? #4588213
11/28/17 11:19 PM
11/28/17 11:19 PM
Bucks County, PA
Hot_Ajax Offline OP
Hot_Ajax  Offline OP
Bucks County, PA
Getting ready to change ATF. What is allowable ATF's? Of course the owner's manual specifies to use Toyota ATF. Are there others that will get the job done without the visit and expense of the dealership? Thanks in advance. Hot Ajax
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588246
11/28/17 11:59 PM
11/28/17 11:59 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Ive heard Maxlife and M1 work well. I have only used OEM until now. I might switch to a full syn M1 or even Maxlife once my DD becomes a 2nd vehicle.
ATF from the dealer isnt too pricey regardless..i think its rebadged Mobil 3309 ATF. Im sure you can find it at Target or elsewhere.
Your Toyota spec T-IV or WS? That will be question 1. The above assumes it specs T-IV
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588250
11/29/17 12:05 AM
11/29/17 12:05 AM
USA
Reddy45 Offline
Reddy45  Offline
USA
Dude we need to know the vehicle and the year..
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588257
11/29/17 12:14 AM
11/29/17 12:14 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
The year might make a big difference.
For my 03 4Runner, I use Red Line D4. Later 4Runners use a different fluid.
Re: Toyota Owners: Spec for ATF? [Re: Rolla07] #4588259
11/29/17 12:16 AM
11/29/17 12:16 AM
Bucks County, PA
Hot_Ajax Offline OP
Hot_Ajax  Offline OP
Bucks County, PA
Rolla: It specs for Toyota WS. Not too pricey? It's ridiculous. Last time I bot it was around $11 per quart. So what other brands does that conjur up? Thanks for jumping in. Hot ajax
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588272
11/29/17 12:34 AM
11/29/17 12:34 AM
Seattle-ish, WA
Oro_O Online content
Oro_O  Online Content
Seattle-ish, WA
Maxlife is a well-matched, much cheaper, and higher quality substitute for WS. WS appears to have multiple global manufacturers that range from adequate to poor in overall quality. Get as much WS out via your preferred method and put in the LV Maxlife equivalent.
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588277
11/29/17 12:42 AM
11/29/17 12:42 AM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Ouch..didnt know WS was so pricey..T-IV up here is 6-7$ a quart. Go with the Maxlife per the poster above smile
PP 0w20 & ST 4967
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588313
11/29/17 02:33 AM
11/29/17 02:33 AM
BC, Canada
userfriendly Offline
BC, Canada
without the bother of starting a new topic... What ATF for a 2006 Highlander Hybrid CVT?
Re: Toyota Owners: Spec for ATF? [Re: userfriendly] #4588381
11/29/17 06:50 AM
11/29/17 06:50 AM
Roswell GA
eagle23 Offline
eagle23  Offline
Roswell GA
Maxlife will probably do well here, too. The Toyota CVTs do not use CVT-specific fluid. Toyota specifies WS.
The reason for the ATF variation is the design of Toyota's CVTs are different from most others. All are CVT, but how they go about accomplishing it is different.
I have a 2013 Avalon hybrid, and use Redline D6.
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588515
11/29/17 09:29 AM
11/29/17 09:29 AM
california
goodtimes Offline
goodtimes  Offline
california
https://www.amazon.com/dp/B072MZLXWV/ref=sspa_dk_detail_0?psc=1
I wouldn't go with anything but OE, Toyota or this kind where they say it is specifically engineered for Toyota. If you read down in the link, Idemitsu tells a lot about why to avoid multi application fluids.
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588566
11/29/17 10:37 AM
11/29/17 10:37 AM
MN
ZebRuaj Offline
ZebRuaj  Offline
MN
If you fear the warranty or don't want to DIY it, stick to the dealership + WS.
Post warranty, Maxlife ATF drain and fill's in all my Toyota's + family's fleet. Fraction of the cost and no problems to date.
~Shade tree mechanic for friends and family.
Re: Toyota Owners: Spec for ATF? [Re: goodtimes] #4588568
11/29/17 10:38 AM
11/29/17 10:38 AM
Michigan
khittner Offline
khittner  Offline
Michigan
Unless you've got some kind of pump, you'll have to pay someone to do the work on your probably-"sealed" Toyota transmission. I've used MaxLife in my wife's '11 Highlander, which called for WS. It worked fine, but I bought a stash of Amsoil LV for pretty cheap from eBay, so that's what's been in it for the last 65k miles, and it's shifting fine.
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588740
11/29/17 12:50 PM
11/29/17 12:50 PM
California
nthach Online content
nthach  Online Content
California
I get OEM fluids for not much more than MaxLife. With that said, I've had success with MaxLife and Castrol's IMV fluid. Some Toyota trannies are picky about fluid viscosity even though ML/Castrol IMV synthetic are the same viscosity as used T-IV. The 2nd gen Siennas are prone to this. But I've used MaxLife in a Lexus LS400 and it seemed to work fine... confused
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588803
11/29/17 01:32 PM
11/29/17 01:32 PM
Cincinnati
quint Offline
quint  Offline
Cincinnati
I have used Maxlife in both WS and T-IV applications with no violent explosions yet.
1993 240sx convertible
2001 Sequoia
2012 Mazda 2
2012 Mazda 3 Totaled 3/16/18, R.I.P
2017 Mazda 3
2017 Kia Rio
Re: Toyota Owners: Spec for ATF? [Re: Hot_Ajax] #4588978
11/29/17 03:52 PM
11/29/17 03:52 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
There are plenty of examples of Maxlife ATF being used in WS spec'ed vehicles without incident.
While this is anecdotal evidence, there is a lot of it.
I decided a while back after a lot of reading and research to use Maxlife ATF in my Scion that is a WS vehicle. ~4 qts drained from he drain plug and same amount of Maxlife ATF added. No problems in 10,000 miles (actually seems to shift a little better).
___________________________________
1994 Honda VT1100C: Peak 15w-40, Tough Guard, 3k mile OCI
2002 Ford F150: Havoline HM 5w-20, Ecogard Filter, 5k OCI
2012 Scion xB: QSUD 0w-20, Car Quest Blue (Wix) Filter, 5k OCI
