My Jeep has a ~3 year old Fel-Pro oil pan gasket . I also bought this Fel-Pro timing chain cover gasket set.
The timing chain cover gasket set came with a black gasket that appears to match the front oil pan holes. If you look at the oil pan gasket on the thicker side, it also has those 4 holes.
Should the two be stacked on top of each other? It just had the oil pan gasket there before..
