Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
92 registered members (53' Stude, andyd, Astro14, alphadog, 2dogs, 2015_PSD, 12 invisible), 1,897 guests, and 25 spiders.
Topics287,853
Posts4,935,596
Members67,865
Most Online2,967
Mar 10th, 2019
oil pan washer #4587088
11/27/17 11:10 PM
11/27/17 11:10 PM
Coastal South Carolina
edwardh1 Offline OP
edwardh1  Offline OP
https://www.amazon.com/Dorman-097-134-Co...K4NP4417WFPXT3K
which side of the washer goes against the oil pan?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: oil pan washer [Re: edwardh1] #4587100
11/27/17 11:29 PM
11/27/17 11:29 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'm not sure it matters - - what is more important is both surfaces it seals against are perfect.
I never liked copper washers on oil plugs.
They are the hardest to keep from weeping.
Re: oil pan washer [Re: edwardh1] #4587112
11/27/17 11:45 PM
11/27/17 11:45 PM
OR
Spooled Offline
Spooled  Offline
OR
The side with the cutout half circle (shown in the picture) goes against the drain plug. It will screw onto the plug. They work fine, but a torque wrench will make sure it crushes properly. Nissan uses this type of washer.
Re: oil pan washer [Re: Linctex] #4587134
11/28/17 12:55 AM
11/28/17 12:55 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
What if you're the kind of person that's really bad at making decisions ? Especially those 50/50 decisions like this drain plug washer. It's nice when somebody can make that decision for you.
Re: oil pan washer [Re: Merkava_4] #4587237
11/28/17 07:40 AM
11/28/17 07:40 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I'm just glad these special washers are "finally available" from a non-dealer source.
I bought a box for my friend's son's "new" Subaru. He was happy.
Re: oil pan washer [Re: edwardh1] #4587257
11/28/17 08:22 AM
11/28/17 08:22 AM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I guess very few like the white plastic (nylon?) washers like I do. They last for multiple oil changes and don't leak. What more can you ask?
Re: oil pan washer [Re: Spooled] #4587270
11/28/17 08:42 AM
11/28/17 08:42 AM
NC
fenixguy Offline
fenixguy  Offline
NC
^^This^^ I just replaced one on my Frontier. I reused the one that came on it for the last three OCIs. I didn't think it mattered, but it only went on completely one way. The notched side goes toward the plug. It was a bear to get off the old one too. I would go a different route but it came with the OEM Nissan filter.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
Re: oil pan washer [Re: edwardh1] #4587272
11/28/17 08:44 AM
11/28/17 08:44 AM
edwardh1 Offline OP
edwardh1  Offline OP
the toyota oem crush ones are symmetric, go on either way. better design.
wonder why nissan ones are different sided?
Re: oil pan washer [Re: edwardh1] #4587324
11/28/17 09:45 AM
11/28/17 09:45 AM
N.H, U.S.A.
ARCOgraphite Offline
N.H, U.S.A.
Sound like a Nissan washer, I have to snip the thing off with cutters when doing an OC; tried the rotate off and that didn't happen. You don't need a torque wrench to put a drain plug on with a new soft metal crush washer - just tighten until the load spikes and then stop. The washer does the sealing. Same thing with plugs and why you should use new washers on plugs if you pull them.
2019 VW Jetta S,6M OCI#0 2103mi-Castrol Edge Prof? VW508+OE Filter; '17 Subaru Crosstrek CVT OC#6 43467mi-Valvoline Adv 0w20 + SOA Filter
Re: oil pan washer [Re: edwardh1] #4587325
11/28/17 09:49 AM
11/28/17 09:49 AM
N.H, U.S.A.
N.H, U.S.A.
I think my 07 Chevy Silverado Vortec V6 had a rubber insert on the flange of the drain plug. No washer per se. Nice!
Cast pan.
I think the Honda 1.5 was this way too, but I cant really say.
Re: oil pan washer [Re: edwardh1] #4587478
11/28/17 12:25 PM
11/28/17 12:25 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Didn't you read the very small print that says this side up?
2004 Corolla 130880
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: oil pan washer [Re: DBMaster] #4587557
11/28/17 01:26 PM
11/28/17 01:26 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
My favorites, as well.
Re: oil pan washer [Re: Linctex] #4587605
11/28/17 02:05 PM
11/28/17 02:05 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
Re: oil pan washer [Re: edwardh1] #4587607
11/28/17 02:05 PM
11/28/17 02:05 PM
Golden Meadow, LA
mobilaltima Offline
mobilaltima  Offline
Golden Meadow, LA
I use these every time I change the oil on a Nissan. the side with the "cutout" goes towards the plug, but I've used it either way with no leaks. I always torque Nissan plugs to 25 ft lbs, but they give you a range of 22 to 29 ft lbs
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
